Platform: Audi b6 A4 1.8TQTip So yesterday I'm in my car, turn for car on, put it in reverse, go back 7 inches lol and the car dies, try to start and no start so I automatically think it's the fuel pump being that the car has 113K miles with the original fuel pump. Ordered a new fuel pump but got the wrong one because of the 2005 VIN split with has different pumps so while the original pump was out I decided to test it so I ran it to a 12V source and the pump works like new so now I'm confused so I put the original pump back in, I change the fuel filter then I go to check for a spark.... No spark and now the fuel gauge on the cluster doesn't even move. Next thing I do is replaced the Crank Position Sensor, note:I've spent over $350 and the car still isn't starting. Changed the CPS and still no start so I do a little bit more research and now I'm at the point that the ECU is fried which is mind boggling because it just died out of no where but I notice when I turn the key no "check engine" light appears, I'm still waiting to get my VAGCOM cable but I'm at a lost and I need this car running ASAP. Can someone help and please advice if I should buy an ECU or not. I'm aware if I buy the ECU I will have to get the immobilized swapped. Please help.
