Results 1 to 4 of 4
    Senior Member Two Rings MrSnickelsnizer's Avatar
    Dec 03 2012
    michigan
    Pilot bearing question?
    Quick question. I am installing a new pilot bearing, it came with the ecs ra4 conversion kit, and I think I might have tapped it to far into the crank. Is the bearing supposed to sit somewhat flush with the crank flange where the flywheel bolts on? Or are you supposed to tap it in till it stops? I stopped before it bottomed out and just wanted to check with you guys since there is no mention of it in bentley. Thanks guys.
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    i tapped mine in till it stops. No problems 1k miles later...
    Dec 03 2012
    michigan
    Ugh..... Nevermind. I found this just after posting and I definitely tapped it in too far. Scroll down about half way through the link and you will see it is supposed to sit flush. WHY IS THERE SO MUCH ROOM TO DRIVE THE BEARING BACK THEN............ The hole in the crank is like a mile deep. Probably two actually. Thanks anyway.
    http://forums.vwvortex.com/showthrea...ting-now/page4
    Dec 03 2012
    michigan
    Shit now you are making me not want to fix it :/
