Results 1 to 6 of 6
Thread: Tire rotations?
    Established Member Two Rings mkayA3's Avatar
    Feb 09 2014
    Beverly Hills
    Tire rotations?
    Hi guys,
    My 2012 A3 TDI is currently at 13,700 miles. I was looking over the service checklist for the upcoming 15,000 mile service and saw nothing about rotating the tires. I then searched more in depth and found that they rotate the tires at 5,000 miles and then NEVER AGAIN??? That can't be good on a FWD vehicle. My fronts are definitely more worn than my rears due to my, ahem, 'spirited' cornering style. Do you guys have any experience with this policy of rotating the tires once and then never again? Should I rotate them at 15k? Thanks!
    Veteran Member Four Rings singleframe's Avatar
    Apr 24 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    on my FWD A3 I used to rotate my tires every 10-15K or so. def recommend doing so!
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
    Feb 09 2014
    Beverly Hills
    Quote Originally Posted by singleframe View Post
    Thanks. Will be rotating them at 15k
    Veteran Member Four Rings RickFLS4's Avatar
    Sep 21 2012
    2012 Audi Q5
    Palm Beach County, FL
    I rotate my S4 and Q5 tires every 5K miles.
    2015 BMW M4
    Past: 2013 S4, 2011 A6 3.0T (accident victim), 2008 Lexus LS-460, 1998 Lexus GS-300, 1994 Lexus ES-300, various GM/Ford/Chrysler cars prior to 1994
    Feb 09 2014
    Beverly Hills
    Quote Originally Posted by RickFLS4 View Post
    Sep 21 2012
    2012 Audi Q5
    I think it is referenced in the 5K service because that service is included. After that, everyone is on their own and I find 5K is worth it because it does extend the life of tires in my experience vs. going 10K. I have Michelin PSS tires and think the tread life warranty actually requires rotation on some interval, perhaps 5K.
    2015 BMW M4
