    Active Member One Ring tylerherring's Avatar
    Mar 22 2012
    Texas
    Changed Air Filter - Now car won't run
    I changed my air filter last night and didn't start my car. Stock air box. This morning the car won't run. I pulled the air box lid and it runs fine. Shook the wires going to the ICM's and no change in idle. Put the lid back on and connect it to the MAF. Car won't run. It surges up and down and eventually dies out.
    With the air box off, if i put my hand in front of the MAF it immediately starts running bad. Not completely covering the MAF, just very slightly impeding air flow.
    Any ideas what is going on?
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Unplug the MAF. Does it run?
    Sent from my SCH-I535 using Tapatalk
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Aug 05 2011
    Memphis, TN for now!
    Quote Originally Posted by tylerherring View Post
    Get back out there and check everything! Maybe something got into the intake and is blocking your air flow sensor.
    Was car running correctly before? Or is this just some regular maintenance gone wrong?
    Mar 22 2012
    Texas
    Runs without the MAF.
    I found the air flow straighter grid on the ground. Put it back into the MAF, unhooked the battery for 10 min to reset the computer. It runs great. That's what I get for working in the dark. Thanks for looking everyone.
    Aug 05 2011
    Unhooking battery does not reset our computer codes... so in the future you'll see some codes for the car running funny possibly. Just keep that in mind.
