I recently just finished up a custom turbo swap on my 05.5 B7 A4 last week. Long story short, I deleted the divertor valve, switched to a manual blow off valve and recirculated it back into the turbo intake pipe post MAF. Im running a Greddy boost controller, even with the boost cranked up It will only hit 4-5 psi then the throttle is closing to 35-40%. I am wondering if having the factory boost controller and DV deleted is causing my ECU to back out of throttle.... I should be running at least 10 psi with the controller backed all the way out so it has to have something to do with MAF/MAP/TPS correlation.... BTW, I'm running a Borg Warner GM3, custom 1.5'' header, 3'' turbo back CATless, 40mm BOV,50mm WG, 2.5'' intercooler piping, 3'' FMIC, AEM WM, intake flapper delete and Maestro Stage 2... Before the swap I had it dyno'd on the heartbreaker- 181 hp and 250tq @ 19 psi uncorrected... Need to get this boosting so I can hit the dyno again to see how much of a gain it'll make.... I'm wondering if I need to upgrade to the 3bar MAP? I'd appreciate any insite on this issue I'm having!
