Page 61 of 64 FirstFirst ... 11515960616263 ... LastLast
Results 2,401 to 2,440 of 2525
  1. #2401
    Jan 15 2017
    Which 255/35/19 is.... At least on my car
    choppstixxx had 245/45/17 stock, the owners manual has all the info required.
  2. #2402
    Established Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    30/32 seems really low to me. IIRC mine says 38/42
    2011 A4 Avant Prestige S-Line
  3. #2403
    Jan 15 2017
    I'm actually curious too now, im running the same tire size. IIRC the door sticker lists the absolute highest load condition pressures, I know S4's run slightly higher pressures due to the heavier engines.
  4. #2404
    Active Member Two Rings LGHT's Avatar
    Jun 07 2018
    CA
    can you add a backup camera to the stock radio for a 12 a4 avant?
  5. #2405
    Established Member Three Rings choppstixxx's Avatar
    Apr 24 2017
    2003 Honda S2000
    Penfield, NY
    From what I gathered a lot of people with 19's running 255/35/19 keep them around 38-41psi. I am gonna settle on 40, I don't usually have anything heavy in my car or passengers for that matter. I rather have a little more wiggle room when hitting pot holes/bumps and not worry about bending/curbing a rim.
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1of 589
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
  6. #2406
    Jan 15 2017
    Quote Originally Posted by choppstixxx View Post
    Time to ramp up my pressures too i guess! wear patterns in a few k miles will tell
  7. #2407
    Oct 23 2014
    '77 MGB Roadster
    Buffalo, NY
    My new tires in the same specs have been set at 40 PSI as well after drawing the same conclusion from the forums. I'm just glad I checked them when I left the shop that did the mount and balance, because 51 PSI isn't acceptable.
    2011 A4 P+ QGM | Sport Package | 6MT | MMI | B&O
    GIAC (stage) | Eurocode HFC & Alu Kreuz | Stasis Exhaust | H&R RSB | DV+ | CR-15 | ECS Intercooler w/ Piping & Street Shield | P3
    the egyptian prescription
  8. #2408
    Apr 24 2017
    2003 Honda S2000
    Penfield, NY
    Going on a trip to Boston this weekend, so I wanna get this sorted before I put 600+ miles on my tires hah
  9. #2409
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    I normally run 34/32 on 245/40/18 97y xl's in normal load due to pot holes and 36/36 fully loaded. Essentially matching the specs for the 19's...
    Maybe I can lower it due to XL tires? Or does the higher rated tire require the higher PSI?
  10. #2410
    Senior Member Three Rings keiffr's Avatar
    Feb 19 2014
    2006 Land Rover LR3 SE
    San Francisco Bay Area
    +1 - I run 40psi rear and 37psi front. Even treadwear on 255/35/19 Hankook Ventus V12 evo2 tires that I've put over 25K miles on. I rotate every 5K miles and still have 7/32 tread depth.
    2011 A4 2.0T TFSI Quattro P+/ Phantom Black
    IE Stage 1 / A5 S-Line Y-Spoke 19x8.5 Wheels Offset: ET32 / 255/35/19 General G-Max AS-05 Tires/ Solowerks S1 Coilovers
  11. #2411
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by keiffr View Post
    How do you rotate them?
  12. #2412
    Feb 19 2014
    Back to Front
  13. #2413
    Active Member Two Rings AudiInMPLS's Avatar
    Apr 20 2018
    2018 Forester Touring
    Minneapolis
    Why does the gas pedal move/click after starting the car and then moving a few feet forward?
    I noticed it on a rental first, then on my car, and then on a brand new Q7.
    So I have to assume this is normal behavior for an Audi?
  14. #2414
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by AudiInMPLS View Post
    Mine doesn't click. That would drive me nuts
  15. #2415
    Apr 20 2018
    Minneapolis
    Searching online, the consensus is that the slight pedal feedback when first accelerating after a engine start is the ABS check?
  16. #2416
    Feb 03 2017
    NH
    Yup
    2013 A4 Premium - [ Exhaust tips / Rubber Floor Mats ] APR Stage 2 | CR-15 | ECS Luft Technik | 034 HFC |
  17. #2417
    Jan 15 2017
    Happens to me too, guess it's normal!
  18. #2418
    Dec 21 2017
    United States
    Anybody know if the power steering pump is the same in both the 1.8t and 3.0? Year is 2002, and i noticed a price difference and of course id prefer the cheaper one. Thanks in advance!
  19. #2419
    Senior Member Three Rings Slim0531's Avatar
    Aug 05 2014
    2010 Santorini Black Land Rover LR4
    Anyone knows if there is an aftermarket company that makes LED tail lights for 2014 A4? Spyder makes them but for only up to 2012 A4.
  20. #2420
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by blinkerfluid9 View Post
    2002? Wrong forum section
  21. #2421
    Jul 24 2017
    Cleveland, Ohio
    Do bumpers have clear coat on them? I have a couple scratches that I'd like to lightly sand out, but not sure if they have clear coat on them. Thanks.
  22. #2422
    Established Member Three Rings tominabox1's Avatar
    Nov 08 2017
    DFW
    Quote Originally Posted by RobM View Post
    Yes, they're the same paint as the metal parts
    2014 A4 Quattro // Sport Package, Black Optics, Bang and Olufsen
    IE Stage 2, CR-15 Strut Brace, USP High Flow Cat, Spulen turbo inlet pipe, aFe filter
  23. #2423
    Jun 07 2018
    CA
    Where is a good site for small misc accessories? I need to end caps for a b8 roof rack cross bar. It's the little black oval cap that goes on the cross bar. Tried the usual places online, but can't find anything.
  24. #2424
    Mar 28 2009
    Minneapolis, MN
    Quote Originally Posted by LGHT View Post
    The OE bar? I have a set of OE allroad crossbars that I'm about to throw away because it's missing pieces. Send me a PM and if they're the same part, I'll ship them to you for the price of shipping.
  25. #2425
    Jun 07 2018
    CA
    Wow thanks for the offer, but the all road probably won't fit because mine is a 2012 A4 Avant. Either way I did find the part number of mine should be 8K9071209D. If it is the same I'll be glad to pick up shipping and need 2 if your going to toss it anyway.
  26. #2426
    Senior Member Three Rings Olde_English's Avatar
    Dec 07 2016
    Singlespeed Specialized Epic Hardtail and Cannondale CAAD 10
    Newark, Delaware
    I have a light malfunction that comes on every ride at some point, whether its right away or after acceleration. Ive checked all my lights and I cant figure out what it is.
    Is there anyway to check to see where the fault comes from.
    I read if you press "set" it would tell me, but that did not work.
    Thanks.
    2009 METEOR GREY B8 A4 AVANT | JHM K04-R | AWE TUNING | APR DP/HFC | GFB DV+ | LUFT-TECHNIK INTERCOOLER | LUFT-TECHNIK INTAKE
  27. #2427
    Jul 02 2017
    Knoxville TN
    What does the fault say? On mine if I have an active bulb alert when I open the driver door it shows up on the display.
  28. #2428
    Jul 02 2017
    Knoxville TN
    Double post
  29. #2429
    Dec 07 2016
    Newark, Delaware
    Not my pic but this is the same alert that I have.
    https://static.cargurus.com/images/s...1600x1200.jpeg
  30. #2430
    May 27 2017
    San Francisco
    I'm looking into replacing my post face lift 3 spoke steering wheel with a flat bottom wheel. I've seen a bunch on ebay that have the same button config as mine but the part numbers are for a Q5. Are A4 steering wheels interchangeable with Q5 wheels, ie: plug and play?
  31. #2431
    Dec 03 2016
    nowhere
    Quote Originally Posted by Olde_English View Post
    Scan for codes.
    Could be the low beam and Led control module.
    -or-
    could be the light switch itself.
    HEAR
  32. #2432
    Aug 05 2014
    Is the throttle body hose part # 8K0145737J compatible with 8K0145737S? It’s just the last letters that changed.
  33. #2433
    Established Member Three Rings Richieru456's Avatar
    Apr 30 2017
    New Haven, CT
    Quote Originally Posted by Slim0531 View Post
    How offen should I clean the intake filter and the MAF?
    B8.5 gear shift retrofit | Led interior lights | Led license plate light | Led backup lights | Honey comb fog grille | Rs4 “quattro” grille | Afe dry filter | Ecs turbo inlet hose | Usp hfc w/ custom downpipe | SUMITOMO HTRZ-III on Enkei EKM3 | custom Euro plate | Carbon fiber interior trim | Audi logo flog lights | Audi logo seat belt covers | “quattro” seat stopper
  34. #2434
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by Richieru456 View Post
    Air filter is generally recommended to be changed with the oil. MAF I wouldn't do more than every 50k miles or so personally.
  35. #2435
    Nov 30 2017
    New England
    Quote Originally Posted by tommyz2kool View Post
    You’ve gotta make sure the airbags will match up. I doubt those wheels come with airbags because they’re incredibly difficult to ship if not impossible.
  36. #2436
    Established Member Two Rings jc_B8_A4's Avatar
    Jul 19 2017
    Bloomsburg, PA
    Would the multi-function steering wheel controls from a b8 s5 three spoke wheel work on an air bag from a four spoke b8?
  37. #2437
    Jul 10 2018
    Poland
    What is the easiest way to replace plastic pressure pipe? What tools do i need?
    Mine is cracked.
    https://www.audizine.com/forum/showt...e#post11844430
    I bought a new one.
  38. #2438
    Senior Member Three Rings dennej1985's Avatar
    Jul 23 2012
    Wyoming
    This may sound dumb but I don’t have a ton of turbo experience. After a few modifications I am noticing a noise from the turbo that I haven’t heard before. Specifically when I come off throttle under boost I’m getting a descending sound like air leaving a pipe. Looking up youtube videos of compressor surge it sounds like that but non interrupted and “chattery” I guess? My sound is one smooth descending note. Like a low pitched whistle almost. Does this make sense to anyone? Normal or no? Installed a few parts lately including a turbo inlet, a downpipe and a gfb DV+ and a tune.
    Now: 2012 A4 Quattro |2.0t|6 MT|Prestige|S-Line|Sport|Titanium|IE Stage2|IE HFC+Downpipe|ECS FMIC+Charge Pipes|GFB DV+|VMR|AFE|
    Past: 2003 A4 Quattro Avant 1.8t, 5 MT
  39. #2439
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    I have a b8.5 and was curious to know what bulbs are the led beams.... h7?
    R.I.P. Sam - 7speed
    You're always one decision away from a totally different life
  40. #2440
    Apr 27 2018
    Anyone else have light refraction/glare caused by having tint on the rear window?
    I've had it since I got the windows tinted back in the winter (30%) it has never really went away.
    Searched and couldn't find much about it. I know it's common on other vehicles (can be anyway) but is a factor of the rear window angle and defrost line thickness.
    Sent from my ONEPLUS A3000 using Audizine mobile app
