Page 94 of 94 FirstFirst ... 4484929394
Results 3,721 to 3,731 of 3731
  1. #3721
    Jan 10 2013
    2009 A4 Avant 2.0T 79K
    Texas
    Can I use a 1K0951605C alarm horn on a car that came with a 1K0951605F alarm horn? The C's are more plentiful and cheaper.
    2009 Audi A4 Avant 2.0T 81K
  2. #3722
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Quote Originally Posted by Veedubber12 View Post
    F supercedes C, so they are compatible.
    Sent from my SM-S911W using Audizine Forum mobile app
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
  3. #3723
    Jan 10 2013
    Texas
    Quote Originally Posted by eljay View Post
    Hell yea!
  4. #3724
    Jul 16 2018
    Atlanta
    That's not what Audi says. But Audi says the B8.0 A4 came with 1K0 951 605 C. That has been dropped as of Nov '17. You can instead use 1K0 951 605 F, but this is forward interchange only. F can be used in place of C, but C is not qualified to be used in place of F.
    My Aug '08 build came with C:
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H03 1301
    So I would wonder if Veedubber's actually came C originally, and someone has already replaced it once with F. If so, the original spec was C, so you could use C again (as there appears no other changes to support the F; this would be unlike the white cap PCV that had a matched ECM software update, making going back to black cap not possible).
    From the VCDS scan of a 2011 avant:
    Component: LIN BACKUP HO H05 1501
    Notice the hardware (Hxx) and software values are newer, but the p/n is unchanged.
  5. #3725
    Jan 10 2013
    Texas
    Interesting, I wouldn't be surprised if it's been replaced. every single audi I've owed the alarm horn eventually stops working.
  6. #3726
    Aug 13 2015
    NS
    Thanks for the correction.
    Interesting, I always thought that supercession means that there's a new revision of a part as the old one is no longer made, but that old part still works.
  7. #3727
    Jul 16 2018
    Atlanta
    Audi is posting the statement a lot it seems in the parts catalog. But it's easy enough. The new part might have changes/enhancements. So it can sub in for the old part in the old application. But there's no validation that the old part could sub in for an application that was built around the new part. Forward only supercession.
    That's why when things like control modules are looked at, you can see the complete supercession chain from the oldest used rev. But I always say, don't use a rev older than whatever your car came with. (and by older, I mean older in the chain; it's not unheard of for the chain to go to a later letter and then come back to an earlier letter).
  8. #3728
    Aug 13 2015
    NS
    That makes sense. Thanks!
  9. #3729
    Apr 26 2014
    San Diego, CA
    Picture for reference, taken from the K04 install DIY.
    In the picture, to the right of the turbo PCV line, there is a black rubber vacuum hose (with the part number stamped on it). Toward the bottom of that hose, directly above the compressor inlet, that hose is secured to the head with a black plastic clip. Mine is broke and that hose is rubbing and slowly wearing against the silicon hose on my intake.
    Question:
    • Does anyone know the part number for that specific clip?
    2013 A4 Quattro Green Black Iridescent / APR Stage 3 K04 E85 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
  10. #3730
    Jul 16 2018
    Atlanta
    Quote Originally Posted by adamazing View Post
    believe it's N10670001
  11. #3731
    Apr 26 2014
    San Diego, CA
    Always coming through in the clutch. Thanks Smac!
