Results 1 to 19 of 19
    Established Member Two Rings audipmpn's Avatar
    Nov 01 2009
    1993 Corrado VR6 SLC, 2010 Touareg 3.0 TDI
    Tampa, FL
    Replacing knock sensors?
    SO I am getting a service light on my Manual 2001.5 S4 Avant saying that my signal is too low for one of my knock sensors. I found one cheap and ordered one but I have heard to loosen them and re torque them to 20 f/lb of tq first.
    Since my light came on my boost went from spiking at 18lb to spiking at 13...maybe even 12lb.
    I also have no other CELs
    Car is stage 2 with custom tune.
    Anyone have experience with this or experience changing them? I have an idea where they both are but would appreciate any help/suggestions.
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I had re-torqued mine when I got a CEL and it did the trick.
    2016 S3
    Instagram- @Thisisastickup
    Nov 01 2009
    Tampa, FL
    Quote Originally Posted by b6Hate4 View Post
    Are they hard to get to? I know there is one on each side of the block but couldn't really see them with a quick glance.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    I have 2 newer sensors if you need any
    Sent from my SCH-I545 using Tapatalk
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by audipmpn View Post
    They are under the intake manifold
    Jun 01 2008
    Apopka, FL
    I/M removal is required, they're directly in the center of the block, there's no way to get to them otherwise.
    As mentioned, you may try to retorque rather than replace, but whether you want to dis assemble the top end twice to save $50 is up to you, and if there's surface corrosion, I would also sand that down. They need good contact with the block to 'detect' the knock.
    http://www.ecstuning.com/Audi-B5_S4-.../Knock_Sensor/
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Would an AUX pump leak cause me to throw a code like this if it has disrupted the clean contact on the block?
    16711 - Knock Sensor 1 (G61): Signal too Low
    P0327 - 35-00 -
    Wondering if I should get a new sensor or try to clean the surface area. Have to do my AUX pump anyway.
    EDIT: Code doesn't throw a CEL, just comes up when I scan VIA Vag-com
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Veteran Member Four Rings ilyafil's Avatar
    Nov 03 2011
    Bay Area , CA
    There's probably corrosion on the sensor to block contact area. Clean it up and re-torque. Should be good to go. Knock sensors rarely go bad.
    "Basically the B7 is the girl you bring home to mom, and the B5 is her slutty sister."
    For Sale: Neuspeed Sport Springs
    Nov 01 2009
    Tampa, FL
    Anyone know if a DIY anywhere to do them with proper walk through and torque specs? I am fairly new to the 2.7 motor.
    Oct 27 2011
    TOYS
    Philly Suburbs
    Have you checked the knock sensor wiring connectors?
    Nov 01 2009
    Tampa, FL
    I looked at one quick this morning and it looked good but am not sure where the second connector is. The Brown one I found was on the passenger side.
    I forgot to mention the PO changed them both out very recently.
    Nov 03 2011
    Bay Area , CA
    There should be a troubleshooting procedure in the Bentley manual for this. You can download it for free. I suspect the PO installed the sensors incorrectly.
    Jan 31 2008
    Quote Originally Posted by ilyafil View Post
    Alright, I'll give it a go. Hopefully it fixes my issue and I won't need to pull my IM off twice. Won't be the end of the world if I end up having to though.
    I figure since it says signal too low, maybe it doesn't have a good connection with the block. If I can pick one up from the dealer for under $50 i'll just replace it.
    Oct 27 2011
    TOYS
    Philly Suburbs
    The dealer will charge you oem list (MSRP is $77 from GAP) +markup. I was in need of a head gasket and MSRP is $88 and the local audi stealership wanted $110.
    Nov 01 2009
    Tampa, FL
    Where can I download it for free?
    Nov 03 2011
    Bay Area , CA
    Right here: http://bit.ly/1eFt5IV
    Oct 27 2011
    TOYS
    Philly Suburbs
    my 5 year old son asked me the other day, "why do you guys say google? why, why? what is google?"
    I laughed
    Then I said "google is the answer to all your questions!"
    Nov 01 2009
    Tampa, FL
    Sorry, I did that...but at work so since it said porn in it my work blocked it and I thought it was a non working link. MY BAD lol
    Jan 31 2008
    Yup just found that out. I'm gonna try to clean it first see what happens and re torque it. Worst comes to worse I do it again in the spring when it's nice out.
    Sent from my SCH-I535 using Tapatalk
