Results 1 to 19 of 19
Hybrid View
    Active Member Two Rings reilly85's Avatar
    Sep 24 2009
    Chicago
    chugging engine at cold start. *Video inside*
    Hey guys,
    This is day two of my car chugging when I start it. Once the engine warms up it's fine but I'm worried about this sound. My guess is that it's the cam tensioner or some injector clogged.
    It's a 2005.5 A4 B7 Avant just hit 65k miles. Only mods is K&H drop in air filter and 034 Turbo inlet hose
    Here is a video so you can see what I'm talking about.
    Any advice would be very helpful.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Are you getting any codes ever?
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    easiest way to diagnose this one might be logs...
    Sep 24 2009
    Chicago
    Quote Originally Posted by Jake@JHM View Post
    Nope nothing... Thats the odd part.
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    what is that terrible metalic ringing ?
    Sep 24 2009
    Chicago
    That is the cam. which I have brought to an Audi dealership 3 different times now to try to get them to replace it under the extended warranty, but they wouldn't because they said it didn't qualify for the repair.
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    I have the same problem. Only under 30 degrees though. I've tried everything. Plugs, coils, n80, carbon clean, fuel filter, MAF sensor, checked intake manifold while I did the carbon clean. only thing left is to change my fuel injectors... I have nothing else to swap.. Took it to the stealership twice and they cannot find the cause. They did smoke test and ran logs. Granted they checked it once it was warm, but I assumed the logs will pick up a misfire. It didn't. After speaking with the techs for awhile, they pretty much agreed I should do a carbon clean. It didn't solve it.
    Sep 24 2009
    Chicago
    eyesolution : Dang that sounds like a nasty time. Did ever get new injectors?
    Sep 23 2012
    Atlanta
    Quote Originally Posted by reilly85 View Post
    Not yet. I have them sitting in my car awaiting to be cleaned and installed. Just waiting on the weather to warm up.
    Senior Member Three Rings Rastboostin's Avatar
    Feb 21 2012
    Chicago
    I know the first (and second time recently) my oem PCV went bad, it did this exact same thing.
    2004 VW R32 - United Motorsports Stage 1 ECU, Forge CAI, USP 2.5" Test Pipe, APR Cat-back Exhaust.
    PAST: 2008 A4 Quattro S-Line 6-speed - APR 93 II+ ECU, APR Carbonio CAI, APR HPFP, JHM 3" Catless Test Pipe, APR Cat-back Exhaust, Southbend DXD Stage 3 Daily Clutch w/ LW FlyWheel, CXR FMIC, GoFastBits DV+, RAI Catch Can, RS4 Rear Sway Bar, 034 RS4 "Street Density" Motor Mounts, Koni FSD/Eibach Pro Kit, ECS Snub Mount, ECS X-Drilled/Slotted Rotors.
    Sep 23 2012
    Atlanta
    Their was a thread on here. That the OP confirmed new fuel injectors solved his cold start issues.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    My issue of something similar (my car eventually started dying)... I started poking around more this morning to find the intake manifold cap to have popped off!! wtf such a simple fix when I tested it by taping it closed.
    Sep 24 2009
    Chicago
    Quote Originally Posted by Sanjman View Post
    Wow that's crazy. I'm getting into the shop tonight and I hope it's something simple the like, otherwise I'm going to have to get rid of the car.
    Veteran Member Three Rings doady22's Avatar
    Feb 28 2010
    ft collins colorado
    I had this exact issue, this morning it was -20F. Mine did however go away after 15 mins of driving. I've replaced my spark plugs, coilpacks this past year so its not them. Keep us posted on what you find out.
    Sep 24 2009
    Chicago
    Just was able to get it into the shop today and they came back with a handful of problems. Once I get the full details on what exactly is going, on I'll post them up here. Sorry for the delay.
    -Pat
    Aug 31 2011
    Lathrop
    Ruh Roh,
    Keep us posted!
