Page 61 of 77 FirstFirst ... 1151596061626371 ... LastLast
Results 2,401 to 2,440 of 3053
  1. #2401
    Established Member Two Rings ADG05's Avatar
    Oct 17 2008
    Santa Monica CA
    Quote Originally Posted by Rob O View Post
    Scrolled through that last 10+ pages and don't see anything ...
    Anyone running 295/40/20 on 20x10 ET30 on a B9 yet? I see a number of references to ET25 (and 10.5 wide), and plenty of Gen 1s with that or similar fitment. I'm looking at going this way next week on our 2018 SQ and would love for it to just bolt on. I have some 5mm spacers if needed; hoping at least the fronts clear (brakes and fenders) so any spacers would just be to "flush up" the rears. Will also be installing links. 8-)
    Check out the green SQ on page 41. Not the exact specs but some good photos so you can get and idea of how it will space out.
    2018 SQ5 Daytona Gray | BBS CI-R | Airmatic Links | Instagram: @raudi_sq5
  2. #2402
    Feb 14 2004
    SQ5, E93 M3, 2018 Raptor, L322 RRSC
    Portland, OR
    Quote Originally Posted by ADG05 View Post
    If I plug his fitment (plus spacers) and tire size (which are incorrect for 20s) into willtheyfit alongside my fitment/tire size, it looks like my set up will work without spacers. Barely. Might still need 5mm in rear, but it's that front knuckle that causes all the pain and he seems to clear so mine should too ... in theory.
    The fronts -- 20x10.5, ET35 + 7mm spacer with 295/35/20 tires -- from the Azores Green with FF01s referenced on page 41 is ORANGE ... Mine -- 20x10, ET30 with 295/40/20 -- is GREEN
    Audi: Navarra Blue metallic 2018 S5 Sportback Prestige / Matador Red metallic 2018 SQ5 Prestige
    Non-Audi: Alpine White 2012 E93 M3 Convertible / Ruby Red metallic 2018 Raptor / Stornoway Gray 2008 "full fat" Range Rover Supercharged /
  3. #2403
    Oct 17 2008
    Santa Monica CA
    [QUOTE=Rob O;13123971]Thanks!
    I believe it would clear with possible a small spacer. The bigger question is the amount of poke. I think it would be minimal but all tires are slightly different.
    Hit up Mops. He did a set up of BBS wheels that I think were 9.5 et 25 and it sat pretty flush. Maybe he can give insight on inner clearance.
  4. #2404
    Veteran Member Three Rings SDV325's Avatar
    Jan 20 2014
    12' S4
    Calgary, AB
    Silly questions, but is the CB for the Q5/SQ5 is 66.6 as well, same as the B8/B8.5? Is there anything holding someone back from using 19" wheels for winter, mainly have to clear the brakes?
    Looking at picking up a SQ5 shortly and it comes with a single set of wheels, need to pickup a set for winter, seeing what i can run. Plus way more tire options for 19's and some 20's vs 21's
    2014 Audi SQ5 Technik - Estoril | Lunar | EPL STG 1 | B&O | NAV | RocEuro | 034 Transmission Insert |
    2015 Toyota Rav4 - Family Wagon
  5. #2405
    Sep 28 2010
    '19 SQ5 / '19 RS5 SB
    Boone, NC
    With the Gen 1, 20x10.5 ET35 required an 8mm spacer for 295/40. Not quite sure what the Gen 2 will require. If they'll introduce Black Optics already, I'll start playing with 10.5/295 day 1 😠
    Quote Originally Posted by SDV325 View Post
    Yep, same bore as the B8.5, and 19's will work just fine. I ran stock S5 19's on my SQ, and the rotors cleared the barrels with plenty of room to spare. You just need to make sure you get enough offset to clear the calipers. So your only obstacle will be what spacers are needed if any.
    034Motorsport | Advan | AG | Akrapovič | AWE | BBS | BC Forged | Brembo | Capristo | Deval | Forgeline | H&R | KW | Milltek | OZ | Rotiform | Sparco | Stoptech | TSW | Unitronic | Volk | Vorsteiner | Work | and many more
  6. #2406
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    295/40 mounted on my Volk G25 20x10 et 25. Will hopefully settle a bit. I’m loving the 295/40 tire.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
  7. #2407
    Jan 20 2014
    12' S4
    Calgary, AB
    S5 Rotors are about +35 offset i believe? What tire size looks the best for a 19? 245/50/19? Thinking if finding a set of 19's to run in the winter. Michelin makes a Pilot Alpine PA5 SUV spec tire that i want (love the PA4)
  8. #2408
    Sep 28 2010
    Boone, NC
    19x9 ET33.
    And yep, with say a 20x9, most run a 255/45, so with a 19x9... 255/50. And 245/50 would work just fine too, but 255 are plenty narrow, so they'd be my selection.
  9. #2409
    Mar 21 2017
    20x9 et40
    265/45-20 Continental DWS06
    17.5 mm spacer up front
    20.0 mm spacer at the back
    Still needs the little OEM fender mud guards.
    No clearance issues at all.
    2017 Q5 3.0T S-line
  10. #2410
    Jan 08 2016
    Los Angeles, California
    Anyone know the minimum wheel load rating we should keep an eye out for when going to aftermarket wheels?
  11. #2411
    Feb 14 2004
    Portland, OR
    Quote Originally Posted by Pittdawg View Post
    Not something you really need to worry about with the Q/SQ5; it doesn't have a high enough payload or tow rating to warrant load ratings beyond what most wheels (for passenger cars like this) will have anyway.
  12. #2412
    Feb 14 2004
    Portland, OR
    Okay ... so I believe my SQ5 may be the first B9 with 20x10, ET30 and 295/40/20 rubber. Shop found no clearance issues and didn't see any rubbing in their shakedown. I was prepared with 3mm and 5mm spacers JIC, but they weren't needed. WOOT!
    Vossen Forged ML-X2 in Brushed Space Grey finish, with lightening pockets and custom engraving.
    Also had lowering links installed. Custom / made to spec based on measurements directly from my car. Currently sits about 35mm lower than stock in Dynamic (seen here).
    I only stopped by the shop today to see how it came out and take a couple phone snaps, so I've not driven it yet to confirm 'zero rub'. I'll pick it up tomorrow morning, then go for a spirited drive on one of our local twisties, then report back.
    Preview of how it looks until I can get out for proper photos. I was worried about going down a size, since 21s are perfectly matched to the SQ5 body and the OE 21s, specifically, look great. After seeing it though ... I think this setup looks tits. And since the car is my wife's daily, I'm hoping the ride will be a bit more compliant (our roads are shit) and the fat sidewalls of these tires will afford some better rim protection (my wife curbs ever wheel, and these cost more than $7k).
    Lowering links:
    Snaps:
  13. #2413
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    I need a fresh diaper.
    That looks amazing.
    --Jerry || 2016 SQ5 P+, Glacier White; Tech, Nappa, Black Optics, 21's.
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: 13' Q5 3.0T '12 Q5 3.2, '08 A4 Avant 3.2, '06 A4 Avant 3.2.
  14. #2414
    Oct 17 2008
    Santa Monica CA
    [QUOTE=Rob O;13138196]Okay ... so I believe my SQ5 may be the first B9 with 20x10, ET30 and 295/40/20 rubber. Shop found no clearance issues and didn't see any rubbing in their shakedown. I was prepared with 3mm and 5mm spacers JIC, but they weren't needed. WOOT!
    WELL DONE!!!!!!!!!!!
  15. #2415
    Jan 08 2016
    Rob O those wheels look great on your ride very classy!
  16. #2416
    Feb 02 2017
    Beaverton, OR
    Rob - the Matador is looking good!
  17. #2417
    Feb 17 2018
    SE PA
    Rob,
    Looks great! Any more pictures of the fitment/poke? I want to run 295's on my 2018, but am concerned with how they will fit in the front. Thanks!
  18. #2418
    Sep 28 2010
    Boone, NC
    @Rob O
    Well done!! 👏🏼
  19. #2419
    Feb 14 2004
    Portland, OR
    Quote Originally Posted by DarkProphet View Post
    Rob,
    I took several photos during a shakedown run after collecting it yesterday. I can officially say there is no rub and zero clearance issues with this set up. I drove roads that put it to the test, and aside from soaking up the tarmac with those beefy sidewalls ... no drama.
    Lowered about 35mm from stock (in Dynamic setting here), 20x10 ET30 with NO spacers, 295/40/20 Conti DWS06 tires.
    There is some poke up front; rears are perfect. My shop thinks we might be able to shave another 2mm off, but I'm fine with how it looks. She chunky.
  20. #2420
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    It's really beautiful in Portland this time of year. That last shot is great. Oh, nice car too!
  21. #2421
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Well done Rob, she looks stellar!!!!
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
  22. #2422
    Jan 03 2007
    SF Bay Area, CA
    Money, it's gotta' be the shoes.
  23. #2423
    Senior Member Two Rings nsaneS4's Avatar
    Sep 18 2006
    2002 S4 Avant, 2002 S6 Avant
    Redondo Beach, CA
    Quote Originally Posted by IanSQ5 View Post
    - Year and model: 2014 Euro SQ5
    - Wheel brand and model: Vossen CV-T (ET42 prior to spacers)
    - Wheel specs 22x10.5
    - Tire specs: 265/30 Falken 452
    - Spacer info if you have them: 10mm Front, 15mm Rear
    Custom StillStatic/AH Exclusive H&R Race Coilovers (est 140mm drop, will go lower once more custom chassis parts are made)
    Custom front control arms
    -1.5 camber front and rear
    Looks good. I have a similar setup. Have you noticed that one side is more flush than the other? My right rear is flush with the fender but my left rear is tucked about 5mm. I think either my subframe is shifted or just the fenders are off front one side to the other.
    2002 Nogaro Blue S4 Avant (Stage 3)
    | 6-speed | Sport Package | Nogaro Blue Alcantara | 1 of 1 with Sunroof Delete |
    2014 Lava Grey SQ5 (Daily Driver)
    | Prestige | Magma Red Leather | AirLift 3P | Inno 624 Cargo Box |
    2002 S6 Avant (RS6 Avant Project)
    | TDI 6-Speed Conversion | Coilovers | Rohana RC7 |
    2009 Meteor Gray TTS Coupe (APR Stage 2+) SOLD 2017
    2001.5 Nogaro Blue S4 (Stage 2) SOLD 2012
  24. #2424
    Mar 13 2014
    Newcastle, England
    Quote Originally Posted by nsaneS4 View Post
    Not from memory, camber may be set different? Car has been sold to my friend and he now is back running the CV-T's and have not noticed any difference in fitment.
    Euro SQ5
    C6 Carbon Interior, Exterior and Engine Bay
    Custom yellow stitch and yellow seatbelts
    StillStatic/AH Exclusive Race H&R with custom Air bags (25" ground to fender)
    Aiflift 3P Management
    C6 Carbon Chassis mods
    DTUK Tuned 370Bhp 774Nm
    Rotiform DUS 22x10.5
  25. #2425
    Mar 07 2017
    Stock with Stock Tires 15/20 spacers.
    BBS CHR II 21x9.5 with Stock Tires 15/20 spacers.
  26. #2426
    Established Member Two Rings KCarrAvant04's Avatar
    Jan 29 2010
    '15 Audi Q5 3.0T, Daytona Black Optics
    Fresno, CA
    Quote Originally Posted by kpykng1 View Post
    Touren TF01 22x9 5x112 +30mm
    Continental ExtremeContact DWS06 265/35 22
    Really wanted to get some Vorsteiner V-FF 103 from Mops but I was on a extreme budget. So I found these on eBay and I've had good luck with my eBay finds, so why not.
    Looks like the seller up'd the price of them since I got them.
    https://www.ebay.com/itm/22-Inch-Tou...53.m2749.l2649
    How's the ride compared to stock wheel size?
  27. #2427
    Senior Member Three Rings buggravy's Avatar
    Jun 25 2016
    2016 SQ6, 2019 SQ5, 2019 Tacoma
    Calabasas, CA
    Shameless plug. Black BBS CI-R w/tires for sale in the classifieds. Perfect OEM+ fitment.
    https://www.audizine.com/forum/showt...1#post13147181
    '16 SQ5 - Sepang Blue w/Black Optics - APR Stage 1 | BC Forged RS45 w/DWS06 295 | Magnaflow | 034 RSB, endlinks, X-brace, trans insert | ROW suspension | TAG blackout badges | Carbon Fiber mirror caps
    '19 SQ5 - Quantum Gray w/Magma and Black Optics, Vorsteiner V-FF 105 w/DWS06 295
  28. #2428
    Established Member Two Rings goosh's Avatar
    Dec 12 2009
    Tampa, FL
    I just got back into an S4 and now looking at all of these is making me regret my decision! I can't pull my boat with the car and you guys have put together some beautiful SQ's!!!
  29. #2429
    May 06 2007
    Michigan
    Quote Originally Posted by goosh View Post
    My S4 lasted a year before I jumped into the SQ. Enjoy the next 12 months ;)
    Current: 2014 Ice Silver SQ5 - Black Optics retrofit / KW SC Coilovers / 034 Trans Insert / BBS CH-R 20x10.5 Satin Black (S) / Stock 21s (W)
    Sold: 2012 Monsoon Grey S4
    Sold: 2010 Brilliant Black A5 2.0T
    Sold: 2003 Denim Blue A4 1.8T
  30. #2430
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by buggravy View Post
    Like all his other sister wives, I love me some Mops. But damnit if this doesn't make two of your sets that I could've snagged if patience was a virtue I possessed. Sigh.
  31. #2431
    Apr 26 2014
    DFW
    The SQ5 is a great vehicle (gen.1). It's what brought me to Audi. I was looking for a mid-sized C/SUV and didn't even know they existed until visiting the dealership. The salesman made me abuse that poor vehicle on the test drive, so I ordered my '14 when we got back to the dealership. When it got totaled, I didn't hesitate to get another one. I don't tow with it, but I do with the Q7, which has a lesser-powered version of the same engine. The gen.1's supercharged V6 is so strong and willing to give more.
  32. #2432
    Sep 28 2010
    Boone, NC
    Quote Originally Posted by VroomVroom View Post
    I love you too Jerry! 👋🏼 😁
  33. #2433
    Sep 18 2006
    Redondo Beach, CA
    New shoes!!!!!
    Wheels: Brixton Forged CM10 Targa Series
    Size: 22x10.5 et20f et13r (w spacers)
    Finish: Candy Red over brushed centers, clear over brushed step lips, gloss black barrels, titanium assembly hardware
    Tires: Goodyear Eagle F1 265/35
  34. #2434
    Veteran Member Three Rings cmoore86's Avatar
    Nov 11 2014
    2015 RS5, 2015 SQ5
    San Jose, CA
    New shoes!!!!!
    Damn the Brixtons look great! Missed your text yesterday with the pics. Looks like things worked out perfectly. Thanks again for driving up to pick them up!!
    2018 Audi [] SQ5: Navarra Blue | Ceramic Pro | BBS | AWE | JB4 | Black Optics |
    Sold - 2015 Audi RS5: Sepang Blue My Sepang Blue RS5
    Sold - 2015 Audi SQ5: Sepang Blue cmoore86 2015 SQ5
  35. #2435
    Sep 18 2006
    Redondo Beach, CA
    Quote Originally Posted by cmoore86 View Post
    They were definitely worth the wait. Thanks again for meeting up and allowing me to take these off your hands. The offsets actually worked out pretty well. I really couldn’t be more pleased.
  36. #2436
    May 14 2011
    93 Alpine White VR6
    Ottawa
    Has anyone put OE 20" peelers on a new gen Q5 yet?
    Figured I'd ask in here before starting a new thread. Search didn't bring back anything.
    If you drive an old audi, you need these facemount bbs e75s (1 of 8)
    __________________________________________________ __________________________________________________ ___________________
    13 Ibis White Q5 3.0T - Daily Driver
    05 Dolphin Grey B6 A4 1.8T - Winter Beater
    93 Alpine White Corrado VR6 - Garage Queen
    16 Platinum Grey Golf Sportwagen 1.8T - Wife Mobile
  37. #2437
    Sep 28 2010
    Boone, NC
    Mops On The Move
  38. #2438
    Jan 03 2007
    SF Bay Area, CA
    Tighter than a Frenchman in spandex.
  39. #2439
    Jun 25 2016
    Calabasas, CA
    @mops, so so good.
  40. #2440
    Sep 28 2010
    Boone, NC
    Thanks babes :)
