View Poll Results: Report Failure of S-Tronic Transmission
Voters
627. You may not vote on this poll
  • B8 (2010-2012) S4; Under 20k Miles; No Issues
    14 2.23%
  • B8 (2010-2012) S4; Under 20k Miles; Problems
    12 1.91%
  • B8 (2010-2012) S4; Over 20k Miles; No Issues
    124 19.78%
  • B8 (2010-2012) S4; Over 20k Miles; Problems
    115 18.34%
  • B8.5 (2013+) S4/S5; No Issues
    292 46.57%
  • B8.5 (2013+) S4/S5; Problems
    70 11.16%
Page 1 of 8 123 ... LastLast
Results 1 to 40 of 281
    Feb 25 2013
    MI
    Post B8/B8.5 DSG Problem Poll (Any Kind of Failure)
    There's been discussion about reliability of the B8 DSG (DL501) and mostly speculation about how widespread the problem is. To weed out very low mileage B8's, will further partition that set. We can include the B8.5 S5, but not the B8 S5 or B8.5 RS5 since they are mounted to different engines (although feel free to argue for inclusion). It goes without saying this sample is preconditioned on being a member at audizine, but there are enough people here (IMO) to prevent any kind of "only members with mech unit failures join" bias argument. Decided to make this about "failure" rather than "mech failure" since any kind of early transmission failure (less than 50k miles) should be viewed as highly problematic IMO.
    Purpose: Get some actual numbers about DSG failure rates. Help prospective buyers and current owners have an idea of failure probability.
    The major failure modes we know of are
    1) Mechatronic Units Failing - the ECU that controls the DSG shifting is packaged within the oil cooled system, with the PCB exposed. The failure of this unit is either due to the chemical properties of the oil reacting with board, the heat from this oil or some combination of both. The result can be a bucking sensation on the 1-2 shift or 2-1 shift. Replacing this unit can cost anywhere in the 5-8k neighborhood;
    2) Gear Change Sensor Failure - TSB relating to the "drive range sensor". Can show up as the warning "Gearbox Malfunction You Can Keep Driving" but no bucking sensation. Not sure of cost, but guessing somewhere in 3k range? Someone have source?;
    3) Clutchpack Failure or Premature Wear - Caused by driving the transmission hard or long-term wear. Haven't heard of anyone with this problem, so including it in the poll but doubt it factors in much.
    Background - The VW/Audi group released a worldwide recall for the 7 spd transverse unit, which can only be found on the jetta hybrid in NA. This recall pertained to replacing the DSG fluid - from synthetic to mineral. The failure was described by VW/Audi as " electric malfunctions could occur in the gearbox power supply if synthetic gearbox oil is used" source. This unit (DQ250) uses only a single oil circuit, compared to the dual oil circuits in the logitudinal DSG.
    There was an update to the DSG in 2013, the ratios were changed, not sure what else. The center differential was also changed (not that this matters). This transmission should be in the B8.5 S4/S5 and RS5. (If anyone has details about technical differences, please post!)
    Also, if you debate any of the technical info provided, please provide the correct info with source and I will update the OP.
    Veteran Member Four Rings raudiace4's Avatar
    Nov 06 2013
    2019 E63s, 2023 M3CX, 2018 SQ5
    Northern Suburbs, IL
    2012 DSG, just crossed 20K miles this weekend. No problems. Stock ecu.
    2019 E63S PTG1000 | Blackboost | RWCarbon | Signature Forged | RedStar
    2018 SQ5 | H&R | RocEuro | Wagner Tuning FMIC
    2023 M3 Competition Xdrive
    Gone:
    2012 S4
    2013 S4
    2014 E63
    2016 S4
    2017 C63S coupe
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    Still (extremely) low on mileage, <2k, so I'll wait to vote until I get more on the odo. So far no issues. Stock till this point, not from here out.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    A few technical tidbits that I have come across. The major issue with the transverse DSG, internally known as DQ250, is that this transmission is using only one oil circuit. The oil with all the gunk from the rest of the transmission is over time corroding the electronic circuits in the mechatronic unit.
    The longitudinal DSG, internally known as DL501 among other things utilizes two oil circuits. Putting the mechatronic unit on its own oil circuit. This is the transmission in the B8 and B8.5. There have been improvements along the way, but I don't have any details. I believe from what I read is that early production units had some issues.
    The RS5 has a different Quattro Gmbh tuned mechatronic unit. The biggest changes are much faster hydraulics and software changes such as a true manual mode that allows one to hit redline and bounce off the rev limiter, but otherwise it is the same DL501 transmission. In addition, the RS5 calls for regular transmission fluid changes. The first one at 15k miles and then I believe every 10k miles or something like that.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    based on all that I have read it seems to be more of an issue with the 2010 & 2011 than the 2012+.
    I hope I did not just jinx myself. No issues so far...
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    2011 29k miles, no tune, no issues
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Feb 25 2013
    MI
    Quote Originally Posted by superswiss View Post
    Interesting info, thanks. I'd agree with you that the single oil circuit should make things worse, however, we've seen similar issues with the longitudinal DCT's so it could be the fundamental flaw is letting the electronics bathe oil, single or dual circuit. But the single circuit probably exacerbates the problem. Interesting that their recall move was to put in a mineral based oil. Anyone know how this would change the chemistry or cooling properties? Maybe speed up the service intervals?
    That's interesting about RS5 10k fluid flush, I agree that it definitely has a differently tuned box. It's probably best to keep it out of the polls. Doesn't the RS5 also have additional oil coolering units or capacity? Not sure if these are used on either of the transmission circuits.
    Sep 29 2009
    I'll toss some knowledge to this thread:
    http://drivelinenews.com/transmissio...mission-works/
    Jan 07 2013
    Quote Originally Posted by drob23 View Post
    What I know for sure is that the RS5 has better air management. It has air ducts that channel more air to the transmission and brakes for better cooling. It does appear to have a different oil pan as well, which was actually prone to leaking. I had a leak and now have an updated design.
    Feb 12 2013
    Boston, MA
    My 2011 S4 crossed 79k this weekend, no indication of issues from my end and the car's service history does not show any transmission work in the history other than regular service.
    The car is stock power train other than 3 k miles with a modified intake (no big deal)
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Quote Originally Posted by IanCH View Post
    Wow! Great to hear!
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Feb 16 2011
    Baltimore, MD
    2010 S4 mechatronic replaced at 45k miles
    I noticed the signs of a bad mech unit probably around 30k miles, but it wasn't that big of a deal at the time for it happened once in a blue moon.
    The issue was getting worse as the car put on more miles. I had the infamous rear end bang when coming to a stop only after the car was warmed up or hot, or in traffic as well as the banging between P-R-N-D and vice versa when stopped after a hot day.
    I ended up being able to replicate it for the dealer and after a few weeks they had it replaced at ~45k all under warranty.
    I was TD1 at the time (APR stage 2, custom exhaust, intake, etc), but dealer replaced under warranty anyway as per direction from Audi of America.
    Car has been smooth as silk shifting ever since the replacement, and unlike a few others, I did not lose my DSG fart.
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    There's been discussion about reliability of the B8 DSG ...and mostly speculation about how widespread the problem is....
    I get the whole "people only join the forum to post their problems" angle, but it seems like almost 50% of the owners here with 2010 DSG's have had the mech unit replaced. ... because what I've seen here leads me to believe it's a big systematic issue.
    So, how do you feel about the poll results disproving (so far) your contention that the B8/B8.5 DSG has "a big systematic issue"?
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Feb 25 2013
    MI
    Quote Originally Posted by zcd2.7t View Post
    Hard to say, I don't think 20% fail rate or whatever it is for the B8 is good by any means, but 23 results doesn't exactly prove much. Hopefully, more people will see this and we'll get somewhere around 50-60 submissions for the B8. One thing this does show that the b8.5 might have fixed the problem. Wish we knew why, other than lower miles...
    Although, I see you cross quoting me from another thread, and yea, 50% seems too high for sure.
    Jan 19 2010
    MI/CA
    ....but 23 results doesn't exactly prove much. Hopefully, more people will see this and we'll get somewhere around 50-60 submissions for the B8...
    39 voters as of 3:40 pm CST, 5 with problems = 85% with no problems.
    I'd be thinking of something else to worry about if I were you, like what your spacers are going to do to your wheel bearings...
    Aug 18 2011
    To be fair, 16% of responders have had issues. That is a very high number, especially considering that more than half have had problems with <20k miles.
    2013 Audi S4 Moonlight Blue | S-Tronic | Sport Diff | APR stage II | APR TCU Tune | Roc Euro Intake | Eurocode AluKreuz | Eurocode USS sways and endlinks
    Feb 25 2013
    MI
    Yea and half of those have B8.5's, 20% of the prefacelift. As of 3:40 CST 5 failures and 19 nothing => 21% failure
    In my eyes 20% chance of having a 8k repair is a "big systematic problem", would you not agree?
    Feb 25 2013
    MI
    Not sure exactly why you're attacking me, but thanks for your concern.
    Jan 19 2010
    MI/CA
    I would only agree that you're grasping at straws at this point, having found out that your contention that "at least 50% of the DSG owners have had issues" (paraphrased) isn't even in the ballpark.
    Your subsequent suggestion that all of these issues (which you went to great lengths to specify should NOT be only complete failure) would cost $8K to repair further undermines your argument, since the bulk of them won't cost that much, and most would be repaired under warranty, costing the owners nothing.
    Wait, you mean cars have PROBLEMS?!?!? <smacks forehead> Whoda BELIEVED it?!?!?! /sarcasm
    Jan 19 2010
    MI/CA
    ... Enjoy proving me wrong...
    That's the funniest thing about this - I'm not attacking you - your own poll is proving you wrong.
    The irony is perfectly awesome.
    Oct 16 2012
    pa
    If anything it was us having a debate, no hard feelings and I hope this poll helps out the community either way. Even if we got to 100 votes I don't think it would be all that accurate but would give us more information than we have now
    Feb 25 2013
    MI
    Did you not read post 14, I already admitted that I was wrong and 50% was too high. Good job, you got me.
    Quote Originally Posted by saxon View Post
    And it was a good debate, not sure why things are being cross posted but whatever, hopefully this serves to give us a better idea of the failure rates rather than inferring from some intense threads.
    Jan 19 2010
    MI/CA
    ...not sure why things are being cross posted but whatever...
    "Things" you wrote are being cross-posted to make certain that the context for this poll is understood by those who might not bother to read the other thread.
    Context can be a b*tch when trying to make a point, which is why some prefer that it be left out....
    Feb 25 2013
    MI
    One big thing I take away from this poll is the failure rate of the facelift appears to be way down. This bodes well for people wanting to tune, but hesitant to do so if the mech unit might grenade itself. Might be too early to make this call, but knock on wood...
    Feb 12 2013
    Boston, MA
    I'm not saying I dont think they did revisions to the trans to stop problems but sampling a ton of cars that average ~10k miles right now is not a good indicator.
    Feb 25 2013
    MI
    Point taken, although people have been driving the 2013's since July 2012, so I'm sure there's a few high mileage guys with at least 40k. But yea, premature to make any definite conclusions.
    Feb 25 2013
    MI
    Lots of DSG problem talk, bumping this thread to get more data from anyone who hasn't seen it.
    Veteran Member Three Rings Luna's S4's Avatar
    May 22 2013
    Cannondale, two Orbeas & a Trek
    Northern Cal
    Thanks! Missed it originally. 33k on the 2011 and all fun, no problems. Tuned and tracked a few times.
    I have posted this information in another thread. Feel compelled to update this post from over a year ago.
    At 38,200 miles had a Gear fault Warning message. Fault 179d00 cooling electrical valve error. TSB 2030477/6 advises replacement of the electrical harness. "Removed the electrical harness, cleaned all the electrical contacts and installed the new spacers. Installed the new harness and reinstalled the mechatronics..."
    All this on the LAST day of Four Year warranty. No charge to me.
    2011 S4 DSG Prestige w/ Revo! Bilstein B16 PSS10! H&R RSB! AP Racing BBK! Michelin PSS!
    Established Member Two Rings iant's Avatar
    Jun 10 2012
    Newport, South Wales, UK
    It is interesting that exactly one third (12 out of a total of 36) of B8 owners, that have responded with over 20K, have had problems (as of 19:30 GMT)
    Would you fly on a plane with that failure rate????
    Jan 17 2011
    RSQ8
    LA / SF
    Quote Originally Posted by iant View Post
    We aren't exactly risking our lives with a transmission failure.
    Also, majority of people coming to a thread with a title like this one has will be looking for answers to their problems.
    Feb 25 2013
    MI
    Quote Originally Posted by MilesM View Post
    I've followed this thread and the only time the sample makes any kind of useful growth is when it's on the front page. It's not proposing facts, but it's clear that the early DSG's had high failure rates and the facelift ones have *yet* to see these problems. Whether it's 30% or 20% or 15%, it's not good. The hope is that Audi will extend the warranty on the transmission like they've done before (not due to this thread lol).
    Nov 06 2013
    Australia
    2013 B8.5 with APR STage 2+ 8000km and no issues. did two 1500km runs - with only quick petrol breaks and various levels of enthusiastic driving - and have had no problems at all.
    Feb 25 2013
    MI
    This thread definitely makes me feel pretty comfortable going to Stg 2 in the near future...
    Jun 10 2012
    True (in most cases) but what I was referring to was quality levels, hardly 3.4 parts per million defect is it
    Totally agree about the majority of people....
    Veteran Member Three Rings Bikel's Avatar
    Jun 19 2013
    missed this poll first time around... 65k and no DSG issues whatsoever.
    2010 S4 | Prestige | Ibis White | DSG w SD | ADAC Grille Badge
    May 07 2013
    Eastern PA
    Hey guys, it's been a little while since I've been back on AudiZine but I have been floating Around here and just came across this thread.
    I have a 2011 S4 DSG that just passed 42k. On my daily drive I notice that I have a terrible knock/thump. It seems that if I am on a hill I need to accelerate extremely slow to get rolling or the thump will occur and it sounds horrible. If I'm not on a hill (flat road) from a dead stop I need to accelerate pretty slowly to get rolling or I will get the thump, it's not as bad as if it were on a hill but it still does not sound good.
    My car is totally stock and always warmed up. I hope this is not a problem and is just totally normal. I am still under warrantee so I figured I better ask.
    Jake
    May 27 2010
    2010 Touareg, 2007 Jetta GLI
    Vancouver, Canada
    looking at the poll numbers, any proportion like that should be unacceptable to a manufacturer. I know it's bias but it still proves the point that there are major issues with the transmission.
    2007 VW GLI - AWD Conversion, a diet and 600+HP coming soon - Racing @ 2014 Pikes Peak Hill-Climb
    2011 Audi S4
    Oct 18 2013
    Long Island, New York
    Bump for this. I'm interested to see more contributions.
    2013 B8.5 S5. 8200mi and no DSG issues.
    Current Car:
    2013 Brilliant Black S5:///Super white interior LEDs///Giac Stage Dual Pulley///AWE Supercharger Pulley///APR 187mm Crank Pulley///GIAC DSG Tune///AEM WM Injection w/ throttle body spacer///AFE Intake Filter
    Previous Car:
    2007 VW BMP GTi: 367whp 12.9@114mph///DSG///APR Stage 3///WM injection w/ throttle body spacer///Unitronic Stg 3 DSG software///
    Mar 01 2006
    Kitchener, ON
    Quote Originally Posted by yourownhero View Post
    Bit curious on this...
    So for me it kind of started especially in Dynamic mode. Is it limited to 1-2 and 2-1 which it occasionally does, I noticed going 3-4 in Auto mode recently.
    2023 Audi S3 / Stronic // Daytona Grey
    Past
    2018 VW Golf R // 6 MT // Deep Black Pearl
    2010 Audi S4 // Stronic // Phantom Black
    2001 Audi S4 // 6 MT // Light Silver Metallic
    Jan 11 2012
    Earth
    2010 with 46k miles, fresh out of warranty and VERY concerned Although 15-20% is a high % of failure (IMO), I'm trying to be positive and also look at the 80-85% as being a majority who hasn't had any issues. Any of the higher mileage guys (70k+) want to chime in?
    Also would like to bump for more entries.
    So does this mainly effect modded cars or is it pretty much the same whether modded or not? I've seen it mentioned both ways.
