you're probably making matters worse. next time your trunks open take a peek in there... the rain (or hot water) obviously doesn't get channeled right to the seals, it gets channeled around them. your hot water probably never got to the important part. although i'm sure you've added to the ice buildup in the channels.
This is common on all vehicles on all seals. water on the contact surface of the seals forms an ice-bond to the closed panel. put it in a heated garage for a bit, drive it, or you can try heatgun/hotwater, but like i said, if you don't get it unstuck the first time, you could end up making things worse =D the muscle-it-open tactic has been known to tear/remove weather stripping too.
