Results 1 to 19 of 19
    Senior Member Three Rings DugiHowser's Avatar
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    Trunk lid frozen! Common problem?
    Hey everyone,
    Sorry to keep posting my problems but seems to be one little annoying issue after the other.. Last week it snowed and was pretty damn cold and I tried to open my trunk and it won't budge! I thought it was frozen around the edges so I pored hot water and still nothing. I then thought the lock froze so I tried to unlock with my key and still nothing.. I hear something turning or unlocking when I unlock the trunk lid but it just won't budge. Is the latch frozen or broken? Am I just out of luck till it warms up? Is this common?
    02 B5 Nogaro Avant 6MT - All STOCK!
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    It's brick out. It's just frozen
    Senior Member Three Rings Breppinq's Avatar
    Apr 05 2012
    VW ATLAS, VW JETTA GLI MK4
    Long island, NY
    just frozen when u open it spray some silicone spray on a rag or white lithium grease and rub it on all the weatherstrips like on the doors/trunk/hood all that
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    wheww! thanks guys
    Jun 01 2008
    Apopka, FL
    I would use a specially formulated seal conditioner. silicone and greases will help in the short term but dry out the already 14 year old rubber in the long term.
    Apr 05 2012
    Long island, NY
    i hear Aerospace 303 protectant is good
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    Quote Originally Posted by Breppinq View Post
    Where should I look for that? Pep boys, advance auto?
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Use this stuff on all of your rubber trim...
    http://www.amazon.com/einszett-91480.../dp/B004B8GTQG
    It will help prevent this and keep your rubber from drying out. There is little you can do if the push button/lock for the trunk release is stuck however, it kills me that these cars don't have a pop open trunk!
    Looking for a good shop north of Boston, call Eurosport Performance
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    Quote Originally Posted by Smitty2A4 View Post
    Said the same thing! But my push button isn't really stuck, it just won't release. I mean could it be that frozen that I can't force it open? After poring hot water through?
    Veteran Member Four Rings Shhmaudi's Avatar
    Nov 16 2009
    Ducati 1299 panigale, Raptor, Tesla Y, MK2 TTRS
    Sandy eggo
    Quote Originally Posted by CELison View Post
    Lol I love socal
    Old: 1.8T Stg 3, Noggy stg 3, Silvaro tag 3 B5 |JHM Trans W/Carbon Syncros 4:1 diff|Tial 770|I.E Rods|Built 2.8 Heads W/ supertech RS4 intake, Y pipe, manifold etc...
    Current: 2013 TTRS Nimbus grey| HRE FF01| 034 RSB w/endlinks| 034 CF intake| 034 dogbone mount & CNC shifter bushings| Miltek DP custom 3in exhaust| Autotech HPFP| AEM 3-1 gauge|Schroth racing belts| S3 shifter| Revised injectors| Ceramic coated/ PPF
    May 30 2007
    Boston, MA
    Quote Originally Posted by DugiHowser View Post
    I had my drivers side door freeze shut earlier this winter, it was really bad I remember freaking out about it and then I just gave up before I broke the handle, so I think its certainly possible that it could be that frozen.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    you're probably making matters worse. next time your trunks open take a peek in there... the rain (or hot water) obviously doesn't get channeled right to the seals, it gets channeled around them. your hot water probably never got to the important part. although i'm sure you've added to the ice buildup in the channels.
    This is common on all vehicles on all seals. water on the contact surface of the seals forms an ice-bond to the closed panel. put it in a heated garage for a bit, drive it, or you can try heatgun/hotwater, but like i said, if you don't get it unstuck the first time, you could end up making things worse =D the muscle-it-open tactic has been known to tear/remove weather stripping too.
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    Quote Originally Posted by james 408 View Post
    If my Avant project wasn't in pieces in my garage I would love to park in it to unfreeze it.. I'll just have to wait till it warms up a bit I guess
    Senior Member Three Rings Delmed83's Avatar
    Feb 19 2013
    The Gummi-Pflege stuff is OK. I have the actual weatherstrip lubricant from AUDI which cost $80 for a small bottle back when I bought it in 2010. I still have half of it.
    Part# G 052 172 A1
    Black 2013 B8.5 A4
    Previous rides:
    Silver 2001.5 B5 S4 - EPL Stage 3
    Black 2001 B5 A4 - Dahlback Stage 2
    Black 2006 B7 A4 S-Line APR Stage 2+
    Dolphin Gray B7 S4
    May 20 2012
    San Jose
    Quote Originally Posted by Delmed83 View Post
    Part# G 052 172 A1
    $80!?!?! Does it contain Ferdinand Piech's urine or something?
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by oppositelock View Post
    Essenz Von Pierch
    For men.
    Jan 09 2014
    02 Silver S4 Avant
    Newington CT
    Its made out of Panda!
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    You could try opening from the inside. Leaving one of the seats down will also get more heat into the trunk.
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    1/2 gallon gas and matches u defrost everything
