Page 1 of 6 123 ... LastLast
Results 1 to 40 of 217
    Deactivated Four Rings
    Jul 16 2007
    2000 A4 Avant 1.9L BT
    Irvine, CA
    GIAC ECU & S-Tronic Performance Software for 2013-2014 Audi S6/S7 are Now Available!
    GIAC Software is now available for all 2013+ MY Audi S6/S7 4.0T models!
    GIAC software calibrations for the 2013+ Audi S6 equipped with a 4.0L biturbo V8 are now available! Our 4.0T ECU software is calibrated to offer dramatic improvements over the factory tune, with a complete ECU recalibration created to work in conjunction with our optional S-Tronic performance software. GIAC is proud to be the first software calibrator with a complete ECU & transmission performance recalibration.
    Improvements to the ECU include:
    Click on plots for full resolution images:
    • Dramatic power gain, adding 77 horsepower and 123 ft. /lbs. of torque at the wheels over the OEM software calibration on 91 octane fuel. Using 100 octane fuel and GIAC’s Race mode adds a peak to peak net gain of 103 horsepower and 141 ft. /lbs. of torque at the wheels over OEM.
    • Entire powerband improvement with gains as high as 106 horsepower and 141 ft. /lbs. at the wheels on 91 octane fuel. For 100 octane, power gains reach as high as 140 horsepower and 149 ft. /lbs. at the wheels
    • Complete recalibration of power requests, air/fuel ratio, timing and boost for maximum power gain at wide open throttle.
    • Throttle response improvement for a drive-by-cable like feel, instant feedback
    • Improved throttle response for a drive-by-cable like, instant feedback
    • Speed limiter increase to redline in final drive gear
    • Proper torque request recalibration to work in conjunction with GIAC S-Tronic performance transmission software
    • Included options: Pump Performance, Stock, Race and Valet modes, as well as a GIAC Flashloader Handheld Switcher Device.
    • Pump fuel performance mode calibration for region-specific octane rating.
    MSRP for this engine calibration, switching options and handheld switcher is $1500.00.
    GIAC is also proud to announce the release of performance DSG transmission software for the 2013+ C7 S6/S7 models. This GIAC exclusive software includes both U.S. and international models. This software complements GIAC performance engine software and is installed in minutes using regular GIAC flashing tools through the OBDII port. Installation of the GIAC product does not require removal of the DSG computer from the car. This quick upgrade supports higher torque levels, faster shift speeds and higher limiters in your DSGs mechatronic to ensure you get the most from your S6 or S7.
    GIAC S-Tronic software features:
    • Shift points raised +200 RPM in drive, sport and manual modes
    • Torque control optimization for faster, smoother shifting
    • Clutch pack clamping pressure increase to support higher torque levels
    • Launch control raised +200 RPM, with full torque on launch
    • Torque requests and limits raised
    • Part throttle torque control recalibrated for a more responsive feel
    Like our other DSG software, GIAC S-Tronic performance DSG software for 2013+ S6/S7 models is currently available for customers who have the corresponding GIAC engine calibration. GIAC engine software is updated with the proper modifications for use with GIAC’s DSG performance software. The GIAC engine and transmission calibrations for the C7 have been designed to work in concert to provide the ideal 4.0T driving experience. GIAC is proud to offer the most complete and potent performance option for the C7 S6/S7. MSRP for S-Tronic performance software is $700.00 and is available at all GIAC dealers. The software is flashed in minutes through the OBD2 port.
    Until February 14th, 2014, customers who purchase the GIAC Performance Engine and S-Tronic software as a combo will receive a $200.00 discount.
    Current part numbers available:
    2013:
    ECU: 4G0906014B (Versions 0002, 0004, 0006)
    TCU: 4G1927156S (Versions 0007, 0009)
    2014:
    ECU: 4G0906014E (Version 0002)
    TCU: 4G9927156C (Version 0002)
    Oct 24 2013
    Boca Raton, FL
    YAS Please.... i think im ready, anything against tuning when under 5,000 on the odo?
    Apr 08 2013
    Are there any issues with running the DSG software with another ecu reflash such as Unitronic or APR? I know the DSG software is likely recommended for use with GIAC software but unfortunately when I was looking for a tune 6 months ago you guys didn't have anything available.
    MoTeC m1 powered Seadoo RXTX
    c7 s6 [email protected] gone
    997.2 TT-S [email protected] COBB/BBi
    Apr 08 2013
    Also, any 1/4 mile and 60-130 info you guys could share?
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    I would be lying if I say I'm not interested.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by ecpChris View Post
    Due to the changes we have to make in the ECU calibration, it's not an option.
    Jul 16 2007
    Irvine, CA
    1/4 mile data coming up shortly. In terms of top end power, it had no problems pulling on an M6 at the airstrip which traps significantly higher than a stock S6. I should be getting some 60-130 data in decent DAs shortly. At the airstrip, our vboxes were in the the Porsches that we brought.
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by S6Jouster View Post
    The engine/clutchpacks are well broken in at that mileage.
    Apr 08 2013
    Quote Originally Posted by Austin@GIAC View Post
    Damn, that's a shame. Tough pill to swallow to go full tilt after getting a competitor's software already. Thank you for the prompt response
    Veteran Member Three Rings TheChef's Avatar
    Aug 30 2010
    Houston TX
    A few questions.
    1) 93oct numbers?
    2) All numbers show look to be tune + exhaust. Do you have tune only numbers?
    3) What was the thought process behind enabling full torque when launching? Any issues with equipment reliability? I know APR chose to limit initial torque for the first few feet based on there research and findings.
    Just some thoughts. I am sure many will cross shop this with APR. As it stands the 91 and 100 octane wheel numbers are well short of APR, but I know you cannot compare two cars on two different dynos exactly, hence the request for the performance times.
    #ProjectS7 2013 & 2014 SEMA Feature car w/ HRE
    Glacier White. Quilted. Innovation. Carbon. LED. Big Red Brembos.
    Partner's: HRE Performance Wheels. Audi. APR. H&R. Michelin. TiKore. EVOKlass. Eurowise. Mothers.
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by TheChef View Post
    A few questions.
    1) 93oct numbers?
    Torque control on launches is something controlled by the TCU (properly, at least). It is possible that because they were trying to control it through the engine, that was their a bit of a battle between the ECU & TCU happening. Though the launches are quite a bit more violent, the launch itself is very smooth in terms of power transition. Further, the tires can now break loose a bit (which they don't really with the stock launch comparatively) which is better for the drive train than a shock launch with no wheel spin (unless you're on some sort of semi-slick). Zero issues thus far with this type of launch.
    93 octane numbers will be posted by one of our east coast dealers shortly.
    Also, you forgot #2
    Jul 16 2007
    Irvine, CA
    A few questions.
    1) 93oct numbers?
    Milltek themselves claim that their exhaust makes ZERO power gains and is simply for sound. Our baselines were performed with the system in place, so any gains that might've been there would've been present in the baseline numbers as well.
    Are we looking at the same data? In terms of software power gains, I'm not sure how 77 whp is less than 62, or 103 whp than 87. You need to make sure that you're comparing peak gains to peak gains, and not "most power gains throughout the powerband" to our peak gains. Some number presentation can be very misleading.
    Aug 30 2010
    Houston TX
    A few things off the top of my head....several exhaust companies have shown gains of 20-30 both HP and TQ. So that is really odd for Milltek to state that there system makes "no power" and its for sound only - and if accurate, pretty poor. My guess is it has to contribute to the gains a BIT no? As a neutral reference point that is tied to no one in particular, AWE's system shows on there website: Peak gains of 18hp and 6 ft-lb tq and Max gains of 27hp and 31 ft-lb tq.
    Regarding performance: I was looking at APR's peak power vs the GIAC graphs above.
    91 octane at the wheels.
    APR Stage 1: 465/524.
    GIAC Stage 1 plus Miltek Exhaust: 458/485
    100 octane at the wheels.
    APR Stage 1: 490/565
    GIAC Stage 1 plus Miltek Exhaust: 484/503.
    ...again, I know you cannot compare HP/TQ of two different cars on two different dynos, that I agree with. At the same time, I don't for a second believe an exhaust adds nothing on this car. I ripped out the whole stock system and the restriction in the factory system is insane - and one of the reasons that people are getting big gains from just exhaust....
    Im interested to see the performance numbers and 93 numbers from your east coast shop. Hopefully sans exhaust.
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    Deactivated Two Rings
    Jun 14 2012
    Orange County, CA
    nA few things off the top of my head....several exhaust companies have shown gains of 20-30 both HP and TQ. So that is really odd for Milltek to state that - and if accurate, pretty poor. My guess is it has to contribute to the gains a BIT no? As a reference point, AWE's system shows on there website: Peak gains of 18hp and 6 ft-lb tq and Max gains of 27hp and 31 ft-lb tq.
    The most accurate way of comparing two cars on different dynos is to look at the power delta. Our baseline numbers are of the car with an exhaust and stock software. In that regard, the exhaust is factored into our power claims. Even with the upgraded exhaust, our stock measured numbers are lower than APR. If you look at the delta, we are claiming higher power gains. You must factor in the baseline number to compare.
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Let's not confuse what I wrote on the website.
    We're adding over 150 ft-lbs of torque over the stock calibration and have headroom to add even more should we choose do to so. For safety, our calibration simply ensures the clutches are fully engaged before delivering all of the torque. It has nothing to do with controlling torque properly, which this final step actually takes place in the ECU, not the TCU. We tested these changes and found no measurable difference in acceleration - just increased safety for the clutches. Furthermore, being as we were first to market on a very new engine and vehicle platform, we chose the safest route we could. We're now coming up on a full year of ownership on our S7 with many miles on the clock at higher output levels than what we currently advertise. : )
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by Arin@APR View Post
    I was directly referring to what The Chef had stated, nothing to do with your verbiage on the website. I don't know the background of your testing, only what worked well for us. It definitely wasn't meant to be a shot at you nor would it have been brought up had he not mentioned it.
    Established Member Three Rings gatorguy's Avatar
    Jun 12 2013
    BMW M5, Ford Expedition Limited
    Metro Orlando
    I assume like the other tunes, it can't be done by direct port programming?
    2013 Estoril Blue S6
    20" Giovanna Sardina's|ECS Spacers|Custom Spoiler|30% Ceramic Tint|Blacked out filler panel|Escort Max hardwired|Escort ZR4 Laser Shifters|Opti-coat 2.0|Stasis Rear Sway Bar|Audi Puddle Lights
    Aug 23 2008
    Auburn, AL
    Thank you for clearing that up Austin. :)
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by gatorguy View Post
    Correct. The initial ECU bench flash will unlock the ECU for OBD2 port programming, after which the ECU can be updated through the port. That is, assuming that the dealer doesn't update the software, which wipes out the unlock.
    For S-Tronic upgrades, it is an OBD2 port flash.
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    Glad to see more competition, looking forward to track timed
    Sent from my Z10 using Tapatalk 2
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
    Jun 12 2013
    Metro Orlando
    Ok, good to know.
    Senior Member Three Rings Ara's Avatar
    Dec 11 2006
    Can the car be flashed back to stock using the OBD port after the initial unlock? Where can i get it in SoCal (LA area)?
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by Ara View Post
    Yes, it can. I will PM you with a few dealers and for some more information.
    Stage 2 Banner Advertiser Four Rings Alex@TAG's Avatar
    Nov 15 2011
    ABT RS5-R, SQ5, 488 Pista
    San Diego, CA
    We can certainly help you out! We are in North County San Diego.
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    AUTHORIZED DEALER: HRE Wheels || FlowForm || Vossen || ABT || TechArt || AWE Tuning || APR || KW Suspension || Milltek || BBS || Brembo || Michelin & more!
    Active Member Two Rings fastmd's Avatar
    Dec 24 2013
    Central NJ
    Do you have dealers/installers in NJ? If you can flash back to stock via obd2 port, would it still be flagged at the dealer?
    2013 Audi S6 Ibis White
    2014 Porsche 991 C4S
    2008 Dodge Viper ACR-hardcore Orange/Black
    2006 Dodge Viper SRT-10 Vert GTS blue
    Too many normal cars/toys and watches
    Nov 15 2011
    San Diego, CA
    GIAC ECU & S-Tronic Performance Software for 2013-2014 Audi S6/S7 are Now Ava...
    Regarding the tune itself - i have logged about 5000 miles on this so far and i haveto say, its been incredible. We were part of this file from the start and the car feels extremely strong and pulls like a freight train from the time the turbos spool and kick in, to until just before redline. One of the big key differences for me (since i really am not one to drive the car too hard all the time) is the drivability at the Lower RPM's. The abundance of torque that the car has now is just astonishing.
    I drove the car initially WITHOUT the DSG file and the vehicle reacted OK to the tune. It seemed as if the lagged a bit, and the car understood what was going on however once the car would shift, it would take a second for the power to come back on fully. Once the DSG file was installed, the car really felt more comfortable with the new updated ECU tune. The Shift times greatly improved, and it seems like even in normal "D" mode and in "S - Sport" the shift points optimized the car to be in the proper torque and power range to ensure a much smoother power delivery. I HIGHLY recommend doing both at the same time.
    As im sure you have seen - the matte blue S6 is a good customer of ours - and he has put about the same amount of miles on his car as we have, however he drives it MUCH harder than we do on a daily basis. He has yet to have any CEL issues, or any heating/oil temp issues at all which is great! We have put the car repeatedly through its paces at a recent airstrip event where we were doing top speed run after run, and the car held up very well, and pulled strong pass after pass.
    We are very excited to get more real world examples and review for you guys. We are flashing a few customers this week and i will make sure i get them to chime in on the boards.
    TAG MOTORSPORTS
    (866) 748-4388
    Feb 11 2013
    C7 S6
    North San Diego
    awesome, can't wait to see a video comparison of giac vs apr
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    Senior Member Two Rings vic55's Avatar
    Apr 15 2013
    The Orange County
    any RS7 tunes in the works???
    2018 E63S Edition 1
    2017 RS7 Performance
    2017 Audi R8 V10
    2016 AMG GTS
    2012 Mercedes Benz C63 AMG Black Series
    Jul 16 2007
    Irvine, CA
    Quote Originally Posted by vic55 View Post
    Absolutely. In the works now.
    Senior Member Three Rings ///M Traitor's Avatar
    Feb 05 2013
    Austin, are you able to remove the 200 Launch Maximum that is coded into the TCU?
    Apr 11 2013
    UAE
    my car needs just 1000 miles for the 30k service.. bad news is that my appointment is on 26th of this month and I really can't wait just to get it out and drive it for a tune and a DSG tune.
    will try to get a before and after vids of the car and the speedo.
    Mar 20 2009
    Quote Originally Posted by ///M Traitor View Post
    Great question, if so this dsg software pays for its self.
    Gone
    B8 S4
    Jun 12 2013
    Metro Orlando
    Quote Originally Posted by sciblades View Post
    I thought you looked into this when you hit the limit and said the unit itself had to be replaced?
    Dec 11 2006
    Still waiting for that pm.
    Jul 16 2007
    Irvine, CA
    Sent.
    Jul 16 2007
    Irvine, CA
    Yes, we are able to remove it.
    Dec 24 2013
    Central NJ
    Sent you a PM about your tune.
    Senior Member Three Rings mik34's Avatar
    Feb 04 2010
    Manitowoc, WI
    This could be the deciding factor for GIAC over APR. I'm nowhere near the 200 limit, but after a tune I'm sure I'll use it even more.
    Sold: 2013 : Ice Silver, Carbon inlays, APR tuned, 21x10 HRE S101, AWE exhaust, Carbon fiber mirrors from RS6, Drilled rotors, H&R lowering module, Escort 9500ci, Ceramic brake pads, Deval carbon fiber rear diffuser, Xpel Ultimate, Opticoat
    Sold: 2009
    Whoever said money can't buy happiness...doesn't own a (tuned) S6.
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by fastmd View Post
    We are located just outside of Philadelphia and can help you out with that!
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
