Results 1 to 6 of 6
    Established Member Four Rings Ac101's Avatar
    Apr 21 2013
    Ct
    A6 2.7t swap into a4
    ANYONE GOT A DIY ??? Or could help ...
    Do I need anything more ???
    1 car is for old people
    5 cars is just a thing
    8 cars is a hobbie
    could never keep a car more than a month
    Oct 30 2009
    Miami, FL
    DIY is this:
    1 - Pull S4 subframe with everything attached
    2 - Bolt into B5
    3 - Swap over everything that's different between the two
    It's not particularly hard, just takes some common sense.
    2018 S5 Coupe - stock for now
    Apr 21 2013
    Ct
    Do I need the oem ecus from the a6?
    8 cars is a hobbie
    Dec 05 2007
    Sheesh. Think about it logically. It's a 2.7t. What other car has a 2.7t? Oh, the B5 S4. Ever wonder if you can run the B5 S4 ECU (I know the answer, but you need to look at it like that). It is going into a B5 A4. Then, what else is necessary to make it work?
    Sorry to come off like an a**, but it is like you decided to take on a project you have no idea about. People who do projects do extensive research before jumping into it. A 2.7t swap into a B5 A4 is simple. Why? Because the B5 S4 has the same engine and the B5 A4 has the same chassis. As mentioned above, swap over parts that need to be swapped over from the B5 S4 and it will literally be a plug and play conversion.
    Apr 21 2013
    Ct
    Lol thanks for the help man ! I'll rebuild the tranny and motor as I pull it out then swap it over !
    8 cars is a hobbie
    Nov 03 2011
    All Over!
    Quote Originally Posted by Ac101 View Post
    What year is your B5 A4 bud?
    1986 Type 85 Audi 90 quattro
