Results 1 to 5 of 5
    Established Member Two Rings olliocity's Avatar
    Jun 17 2013
    Glasgow, United Kingdom
    help finding some parts for partial b&o retrofit
    Hi folks,
    Can anyone help? I'm retrofitting the front of my car with the b&o system. I'm looking for 2 things;
    First is the b&o microphone courtesy light unit in black.
    Second are adapters for the speaker connections, I'd rather not have to butcher the factory wiring.
    Anyone able to point me in the right direction or anyone who has an aftermarket install in place of their b&o who would do me a part exchange?
    Marc
    Jul 16 2008
    Finland
    Speaker connectors are the same. The door tweeters are run by the amp, so you'd need to run wires all the way from the amp to the tweeters. You probably get a fault code for the missing rear speakers as well.
    The interior light is the same, so you only need the B&O microphone. That is, unless you're also swapping to a black light unit at the same time.
    ______________________________________
    2013 A4 B8.5 Avant 1.8tfsi quattro, Ibis White. Mods: 8x18 OZ Leggera HLT for winter, OEM RS4 9x19 for summer, OEM trunk organizer rails, Underseat storage bins, S4 pedals, LED interior lights, H&R Sport, tint.
    Veteran Member Four Rings oascom's Avatar
    Jan 08 2013
    New Jersey
    Seriously I don't think it's worth the money. You can better sound for less than retrofitting.
    APR, Eurocode, AWE, P3, aFe , CTS, Spulen, H&R, 034Motorsport, STaSIS
    Jun 17 2013
    I started down this route, I've changed out the sub for a high quality one with its own amplifier, the back door speakers have also been changed out for good quality aftermarket ones.
    I had started getting parts together for the front buy I changed my mind for a couple of reasons.
    I didn't fancy having another big amplifier in the back of the car, had trouble finding speakers that would fit and I picked up set of front b&o speakers and amplifier for next to nothing. I think with the mods I've already done it will sound good enough for me.
    The sound from the 3g mmi radio/amplifier unit isn't great at all.
    Jun 17 2013
    Thanks, the Dash speaker connections are different, the non b&o has 2 dash tweeters and one mid, the b&o is the reverse of this. Do you have any idea what the part number is for the b&o mic? I'm struggling to find one.
