Finally got a few minutes (and some ramps!), install was easy and quick, just needed to get over being a little nervous under that 2 ton beast, lol. I haven't hung out under a car since I was younger and stupider, I'm in my 30's now. Transmission mount was the easiest, just unbolt the old, and bolt/torque the new (make sure you use NM instead of ft lbs on your torque wrench). The differential was a little trickier, mainly man handling that differential upwards so you can slip in the washer and bushing, but the rest was easy.
I'll give impressions later, but it did feel firmer off the line and when shifting up and down. If you try you can still make the ride a bit jerky though, but you need to try hard. I'll see the real difference in traffic when the transmission gets heated up. I'll post next week.
Race Ramps stored away for next time, they are so light.
Stock Pieces, bolt for Differential, bracket for Transmission.
For 034 Transmission Mount Install, front wheels on ramp. Wheel Chocks all around, and jack stands just in case.
Loosened stock transmission mount bracket.
Installed.
Rear wheels up for Apikol Differential Mount Install.
Stock
Installed, from front facing rear, still loose, only way to even see if its in the right place!
From Bottom, torqued.
