Dynamat!
Getting the door off is never a problem. Getting the new door on most certainly was. Just could not get the bolt to go into the threads cleanly.
In any case old scratched door off.
With the new door on this is the stock sound deadening I'll be replacing.
Top half of door done.
And bottom.
Just knocking on the door there is a huge difference in sound. The door sounds much more solid. I'm excited to see what the full results are.
In other news I still have grinding and clunking galore. I'm starting to worry something is wrong with the pilot bearing or throwout bearing. When revving the motor in neutral with the clutch engaged there is a distinct whirring noise. If I push the clutch in the noise goes away. :(
