Results 1 to 21 of 21
    May 17 2012
    Houston, TX
    Can you fit 4 tires with back seats folded down and in trunk?
    I am going to pick up 4 new tires and may not be able to use our jeep. If that the case, can I fit 4 255/35/19 tires with the rear seats folded down and into the trunk? Wondering if anyone has done this. Im hoping to not rub against the doors or seats too much but i'll bring extra towels/clothes to protect everything just in case.
    Veteran Member Four Rings PitchS4's Avatar
    May 14 2007
    2021 SQ5 | 2019 Jeep GC Limited
    Northern VA
    Yes I have before
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    I did this I was fine. I put two in the back seat, and two in the trunk. With a shit load of towels for the seats and door.
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Veteran Member Three Rings S4Phantom's Avatar
    Jun 10 2012
    I do it 2x a year when I swap my tires. I lay the seats down and slide them all the way up and they fit. Its tight but it works and I dont have to worry about them messing up my seats
    2011 Phantom Black S4 Prestige Titanium Pkg., Sport Diff., Alu Kreuz, Milltek Non-resonated exhaust with oval tips, AWE Carbon Fiber intake, Stage 1 GIAC, Black powder coated Titanium Pkg wheels
    Veteran Member Four Rings aka5's Avatar
    Apr 23 2012
    yupppp
    May 17 2012
    Houston, TX
    awesome. thanks!
    Veteran Member Four Rings audibmi's Avatar
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    get some tire totes. they have handles to lift and will save your interior. four wheels/tires will lay flat if you position them correctly.
    Senior Member Three Rings mscottdemarco's Avatar
    Jun 29 2013
    had a 13 Audi S8 and a few a4s.. Now have a 15 q7 tdi, and a 19 q5 2l
    Denham Springs, LA 70726
    I fit 4 rims with tires and 3 tires in the backseat of my b7 once. the other tire had to go in the passenger seat.
    May 17 2012
    Houston, TX
    I bought 4 tires and tire totes from tire rack and going to pick it all up as the facility is not too far from me and I'm headed up that way for work.
    Will put all the tires in the totes as they will be stores for winter anyways. Worked out well to save shipping.
    Aug 05 2013
    N/A
    Quote Originally Posted by mscottdemarco View Post
    They should all fit if they're 18" in a B7. I've done it and only had to move the front passenger seat up a bit to situate them similar to the picture above. I'm hoping to be able to do the same with the B8 when it's time for new tires and it seems that it's possible. It is bigger too... but so are the tires. lol
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    get some 55 gallon garbage bags roll tire inside a bad and put them in back seat/trunk. That way it wont be messy
    2019 SQ5, 2021 Q7
    Veteran Member Three Rings Time4Audi's Avatar
    Jan 15 2007
    Massachusetts
    Quote Originally Posted by audibmi View Post
    ^^^^ This is exactly what I did when I swapped my Winters on - the tech who helped me loved the tire totes - very helpful in keeping the inside of the car clean. One other reccomendation I would make is to wash the wheels that are coming off the car soon before they are to be removed...
    Aug 05 2013
    N/A
    Speaking of totes. Where and what brand did you guys pick up? Did you just get the Tire Rack ones? I think I'm going to do this for the next time I need to buy tires... not that new tires are dirty or have caused any issues for me in the past, but it makes it easier to just throw them in and not have to worry about anything.
    Jun 10 2012
    Quote Originally Posted by SwankPeRFection View Post
    I have the Tire Rack ones and they work fine. Its worth for me just to have the handles to carry the tires with
    Senior Member Three Rings BLACKS4-10's Avatar
    May 08 2010
    2011 Ford F-150 Lariat 5.0
    Yes indeed.I did when bringing to the installer 4 brand new 19" Michelin pilot S.S with the seat down and tetrisizing carefully the 4 large tires as to not rub on the back of front seats or side panels.I used a big blanket as a buffer pad too..
    2010 S4 Brilliant Black- Black/Magma Nappa-Prestige-B&O-Carbon Atlas inlays-DSG-Nav/camera-35% Solar Gard tints-APR Exhaust-Eurocode Alu-Kruez stabilizer-Tyrolsport RCS kitEurocode Trufit intake-ECS 2-piece lightweight front and rear rotors with Akebono Euro pads=H&R rear sway bar
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    use lalrge black trash bags
    AXA
    Turbo Villains
    Apr 05 2004
    8S TTRS C8 RS6
    pnw
    Kurgo is the OEM manufacturer of tire totes for brands such as Audi, Michelin, Tirerack, among others.
    I prefer the Audi ones compared to the Michelins because they have a clear pocket window for a card insert to write down the tire info (such as position).
    I slip a sheet of bubble wrap to protect the face of the wheels instead of purchasing the optional tire felts. With 4 set of wheels in the garage, the handles on the totes are indispensable for hauling them around.
    Established Member Two Rings Doc Masher's Avatar
    Apr 28 2012
    USA Southwest
    You sure can, I commonly load up 4 18x9.5 wheels with 275/30/18 tires mounted to the wheels, and it fits fine in the back of the car with the seats down. I can even fit a jack and everything else needed for a track day event! Like everyone else stated, just wrap the tires in some sort of protective cover.
    2011 S4 S-tronic, Sports Differential, Titanium Package, Stoptech BBK ST-60 355MM, Alu Kreuz and APR CPS pump with reservoir separator
    Veteran Member Four Rings staticuxo's Avatar
    Sep 16 2008
    sure can.. in fact, i've even managed to fit (4) wheels and (4) tires in the car/trunk
    B9 S4 - DAYTONA | BLACK OPTICS | ABT HAS | AWE TRACK w/ RES DP
    B8.5 SQ5 - SEPANG | BLACK OPTICS | KW SC | AWE TOURING | ROC-EURO | VORSTEINER V-FF 103 21x10.5 | CONTI DWS06 295/35-21
    C5 A6 - 4.2L | 6MT SWAP | H&R | OEM TTRS ROTORS 19x9
    PREVIOUS:
    B7 S4 AVANT 6MT | B8.5 S4 6MT | B8 S4 S-TRONIC | B8 S5 6MT | B7 S4 6MT | B7 A4 6MT
    Aug 05 2013
    N/A
    I think I'm going to pick up some TireRack ones... they'll match my interior colors. lol
    May 17 2012
    Houston, TX
    Picked up the tires and put them in the tire rack totes. Everything fit, just had to move the front passenger seat up a bit.
