Results 1 to 17 of 17
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    What BT OBDII reader do you use?
    I plan on using the Torque Pro app.
    What BT OBD II reader does everyone use?
    Pros and Cons of each?
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    Not sure if Carista's obd adaptor will work with Torque but if it does you can kill two birds with it. Carista is pretty easy to use and the app is only 20$. You can check and clear codes plus change a bunch of stuff to personalize your car. Check it out. Search a bit, there is plenty of talk about the Torque app on here.
    http://www.caristaapp.com
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Quote Originally Posted by 14S4GWM View Post
    Yes it does work with Torque Pro. I use it :)
    Sent from my Nexus 6P using Tapatalk
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    Quote Originally Posted by justr0 View Post
    Are you able to show boost on the tq app? I can't get it to work on my iphone. Carista works fine.
    Current: Audi 2018 S6 - DS1
    Former: Audi 2010 S4 DSG prestige - EPL Stage I + DSG tune | AWE intake | Neuspeed exhaust + non-resonated downpipes
    2006 Wrx STI stage II 330hp 315tq | 2005 E55 Eurocharged tune, pulley, headers - Highway monster
    Jul 24 2015
    Quote Originally Posted by Woodybangs View Post
    Yeap, boost widget works fine on my Android app.
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    I use Scan Tool BT with Torque Pro on almost every car I own- its extremely reliable and helpful. I can use live data when towing with my V10 Excursion (and old Android phone) to monitor EGT, Coolant temp, oil and trans temps. I have used live data to trouble shoot bad 02 sensors and bad cats on a few cars too.
    https://www.scantool.net/scan-tools/
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Feb 21 2015
    Ohio
    So which did you go with for the Audi?
    Oct 04 2012
    Berthoud, CO
    Quote Originally Posted by quietcropduster View Post
    I primarily use my VAGCOM from Ross-Tech for my Audi-
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Per my text I ended up with http://www.amazon.com/gp/product/B00...iglink20461-20
    Does what I need it to do for both our vehicles. Funny thought it won't allow me to measure Intakes temps on the S4 but does it on the minivan. It actually does nearly everything in the menus on our van but only about 80% on the S4. Weird.
    I have it connected through Torque Pro to monitor:
    • Boost
    • Trans Temp
    • Coolent Temp
    • AFR's
    • Fuel Levels
    • Timing advance
    • Silly things like HP/TQ high and low values and silly 0-60 times.
    Of course being able to see trouble codes and reset them is valuable but hopefully not necessary.
    I had most of the programming mods done through a friend with a VAGCOM Cable and his laptop but i did pay the $20 for Carista to adjust the sunroof to tilt vs open along with windows and to enable the floor lighting at night.
    I also have registered Dash Command. This is by far the better looking of the apps. I will be playing with this one a bit more.
    Here's a link to what all it provides access to.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Feb 21 2015
    Ohio
    Quote Originally Posted by pdqgp View Post
    • Boost
    • Trans Temp
    • Coolent Temp
    • AFR's
    • Fuel Levels
    • Timing advance
    Ironically I bought the same one, I did find another that was triple the price but no guarantee on what all parimeters it will do.
    ScanTool 426101 OBDLink MX Bluetooth: Professional OBD-II Scan Tool for Android & Windows https://www.amazon.com/dp/B006NZTZLQ..._WvYcxbCAW9HV9
    double thumbin' it!
    Dec 14 2015
    Orange County, CA
    • Boost
    • Trans Temp
    • Coolent Temp
    • AFR's
    • Fuel Levels
    • Timing advance
    How do you get trans temp to work? What are the parameters? I use my iPhone for daily duty, but I am familiar with Torque Pro and use a prepaid Samsung Galaxy S4 I bought from an old co-worker for that app only.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I use this OBD-II adapter. It's not BT, though, it's WiFi (it broadcasts a wifi network and you connect your phone to it). Works great and only $14.99 now. Not sure if it would work with the Torque app, but it DOES work with Carista.
    http://www.amazon.com/ieGeek-Wireles...ilpage_o00_s00
    Oct 06 2014
    Cleveland, OH
    To revive this tread, what BT adapter is everyone using with iPhone/iPad? I bought Dash Command and it does not work with the Carista dongle. So I have to buy another, but it needs to work on iOS.
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    Quote Originally Posted by SR7D1 View Post
    Unfortunately iOS won't work with Bluetooth because Apple does not allow serial communication over Bluetooth so you will have to get a WiFi adapter like the one jsh139 linked above. PLX devices are expenesive but are very well made http://www.plxdevices.com/SearchResults.asp?Cat=203
    2016 S6
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    Damn good looking on that. I was getting ready to buy the dash command and use my Carista dongle lol. I'll order a wifi one off Amazon. Cheap enough.
    Jan 08 2016
    MI
    You can get the ELM off of amazon for cheap. I use it with caristia and Dash command. Dash command however does not support most things audi. Extremely disappointing.
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    OBD Eleven to enable VIM (vehicle in motion) video playback fastest way.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Carista for other mods. Both adapters worked great.
