Thanks for the write-up Jim, this really helped! I just completed this job over the weekend. Replaced trashed/leaking OEM mounts with 034motorsports street density mounts. Just a few comments from my experience, which will hopefully help those looking to tackle this.
I decided before starting that I was going to completely remove the brackets instead of just loosening them. If you go this route, no need to loosen/remove the snub mount or jack up the engine, though I did still place a jack under the engine and raised it just to the point of supporting the engine.
Removed (2) 13mm nuts on top of both engine mounts. In regards to the passenger side access, I did not have a stubby ratcheting wrench. I found a set of 4 metric standard length ratcheting wrenches for $9.99 locally at an Ace Hardware, and cut the 13mm wrench down to about 4 inches. For that price I didn’t lose any sleep cutting one of them down…
Removed (4) 13mm nuts holding the sway bar to the brackets, swung sway bar down out of the way a couple inches.
From here, you only want to work on one side at a time. Removed the 13mm nut on the bottom of the motor mount. All of the bolts holding the bracket on were 18mm in my case. The 2 toward the front of the car loosened easily, but the one towards the rear was on there good. Out of laziness, I used a 3/8ths breaker bar on the rear nut, since my ½ breaker was in the basement, and I almost rounded the bolt off. Luckily I was still able to get it off with the ½ breaker…don’t be the ‘3/8ths me’, grab your ½ breaker.
When I removed the bolts holding the bracket from the passenger side, my sub-frame dropped on the passenger side a couple of inches (wish I would have seen SLYCAT’s mention of this in post #46 before)…not sure if this is normal, or points to some other issue. Installed new mount, ensuring nipple on bottom came out same hole the previous mount was. When I went to re-install the 18mm bolts, they would not line up, and on top of that, they were a couple inches shy of being able to engage the threads on the frame. I put a jack under the passenger side of the sub-frame, and jacked it up a couple inches. This allowed the bolts to line up and actually reach the holes. Tightened bracket bolts down completely. Loosely threaded on both the upper and lower 13mm nuts.
Repeated process for the driver side. The only thing I did differently for the driver side was I put a jack under the sub-frame on the driver side before removing the bracket, and raised it just to the point of engaging.
Moved sway bar back in place, and fully tightened (4) 13mm nuts holding sway bar to brackets.
Took for a drive around the block, raised car again, fully tightened down (4) 13mm nuts on top and bottom of both motor mounts.
I have a tiptronic, so there is a sensor on the driver side mount…I decided to see if it would throw a code without the error canceller/resistor bypass that 034 sells before I purchased one. Mine did not throw a code, so I just used zip ties to secure the sensor up.
