Page 324 of 324 FirstFirst ... 224274314322323324
Results 12,921 to 12,949 of 12949
  1. #12921
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by daught View Post
    That's for answering my questions. So you don't think it's worth replacing the trans mount? It looks ok, but I want to make sure I eliminate all possible sources of slack.
    Also, is it necessary to drop the subframe or lift the engine to replace the engine mounts on the 3.2?
    I wouldn't, but that's me. You can always start with the engine mounts and if you are not happy move to the trans.
    I haven't done a 3.2 but I have on a 4.2 and you definitely need to lift the engine a bit. I honestly don't remember if we dropped the subframe or not. It will certainly make access easier as it's very tight.
  2. #12922
    Active Member Two Rings theguysinger's Avatar
    Nov 25 2017
    Ephrata, PA
    That seems like a lot, but it's hard to tell in pics. An ounce or two is normal
    Alright, thanks man. It was roughly .3-.5 of a quart which seemed a little excessive. Iíll have the valve cover off in a few weeks so Iíll check it out and hopefully a new gasket helps a little.
  3. #12923
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Just replaced my front shocks and all 8 control arms as well as installed B5 spring perches which lowered the front end about 3/4". Didn't touch the tie rods as I'll need to replace my steering rack sometime soon.
    Question is, should I get an alignment done now or wait until I do my steering rack in a month or two? How important is it to have an alignment after doing control arms and lowering the front a bit? I don't notice anything out of the ordinary with drivability since doing the work. The best alignment shops in my area are booking for at least 2 weeks from now anyway, but wondering if I can get by for longer without burning up my tires? I'll likely rack up at least a few thousand miles in the next month. Any advice?
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Motor/Trans Mounts - APR Snub Mount - S4 RSB - 034 Turbo Inlet Hose - JHM Short Shifter - Brembo Q5 Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension - Black Alcantara Recaro Interior - Summer: 19" OEM S5 wheels, 19x8.5 ET32 w/ Conti DW tires - Winter: OEM 18" USP wheels, 18x8 ET43 w/ Nokian Hakkapeliitta studded tires - Dolphin Grey FTW!
  4. #12924
    Oct 28 2014
    ON
    On 1.8s I just dremel off the bolt that is sticking out the past the nut. That allows the mounts to come out by only lifting up the engine a bit. Last time I dropped the subframe the welded nuts stripped. I want to avoid touching the subframe.
  5. #12925
    Veteran Member Four Rings pAid4's Avatar
    Apr 15 2013
    Golf Clubs and Snowboards
    Minneapolis, MN
    Took the recaros out of the A4 and went back to stock. Forgot about swapping back my passenger occupency detection module and got the airbag light...swapped the module back, light still on...assuming I need vag-com to reset the light?
    -Nic
    2008 Ibis White A4 Avant 2.0T S-line 6MT / 90K Miles / APR Stage II / 034 HFC / STaSIS Exhaust / Alcantara Recaros / 19x9.5 TSW's / Other Stuff
    2013 Glacier White Q7 Prestige 3.0T S-line CPO / 70K Miles / Black Headliner / Sport Wheel / Sport Seats / Advanced Key / Navigation / Side Assist
  6. #12926
    Senior Member Three Rings Dondbg's Avatar
    Mar 12 2016
    MB w203
    New Zealand
    Got a B7 2.0T Quattro Avant, will it make sense / a difference / ok to swap the rear sway bar with an S4 B6 Sedan one. ?
  7. #12927
    Mar 12 2016
    MB w203
    New Zealand
    Quote Originally Posted by pAid4 View Post
    Correct
  8. #12928
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Do you need the special VAG fuel pump tool to remove a B7 fuel pump like prior models have needed? The 2.0T is not listed in the description.
    https://www.ecstuning.com/b-genuine-...tool/3307~oev/
    No just use a flat head to push the clip in and pull it off.
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
  9. #12929
    Dec 04 2011
    Kansas City, KS
    For the lock ring just use a flat head and a hammer to knock it around.
  10. #12930
    Feb 15 2016
    Cambridge Ontario
    https://www.ebay.com/itm/U281-Code-R...EAAOSwQFVar7GI
    holly cow its gone up !! I paid 12 for mine !! lol
    2014 Nissan Murano
    2006 A4 2.0TQ 6spd
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  11. #12931
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Dondbg View Post
    The S4 one is slightly larger. There is no difference between avant & sedan to prevent it from bolting up.
  12. #12932
    Mar 12 2016
    MB w203
    New Zealand
    Larger as in thicker.
    I know it will bolt up
    What Iím asking: is it ok to swap only the rear bar, and no drama after a while and will have to go back and swap something else ?
  13. #12933
    Apr 13 2018
    San Diego, CA
    My dumb question is, do these cars ever run right?
    I just picked up an '08 A4 S Line from some friends with 53k original miles. I've had it for a month, had a CEL for the intake manifold flap motor, which was under warranty for 100,000 mils or ten years, luckily my car turns 10 next month. But it seems like there are a lot of inherit problems with the 2.0T engine. I guess all I can do is keep up on the maintenance and hope for the best?
  14. #12934
    Aug 18 2009
    A Unicorn
    Portland, OR
    Correct, larger as in thicker. And yes, completely fine to just swap the rear. Most people on here don't find much benefit in upgrading the front
    Quote Originally Posted by Tenbender View Post
    Of course they run right if you take care of them
  15. #12935
    Oct 28 2014
    ON
    Are the 3.2 sway bars also thicker? The 3.2 b7 with OEM sport shocks at 190km has way less body roll compared to my old b6 with koni fsd.
  16. #12936
    Senior Member Three Rings supple's Avatar
    Jan 27 2016
    I don't have a garage
    Woburn, MA
    Engine didn't change the sway bars, as far as I know. I believe there's 4 sizes to the B7 rear sway bar:
    Base - 16mm
    Sport Suspension / S-Line - 18mm
    S4 - 20mm
    RS4 - 22mm
    Then there's bigger aftermarkets
    2007 Brilliant Black A4 Quattro | Unitronic Stage 1+ | Bilstein Sport + H&R Sport | Apikol Snub | GFB DV+ | 034 Turbo Inlet, Street Density Motor Mounts, RSB & End Links, Upper/Lower Control Arms | Pipercross Filter
  17. #12937
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by supple View Post
    Base - 16mm
    S4 - 20mm
    RS4 - 22mm
    That's correct. Engine between the A4 doesn't matter, just sport suspension
  18. #12938
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    Agree with pat. These are not maintenance free vehicles....in fact they need more TLC than most. But if you keep on top of things they run great. Mines at 218k and all is great. To put things in perspective.....I've done the following in 2018
    - oil change
    - cam follower replacement
    - replaced the coolant temperature switch
    - change the PCV
    Less than $100 in parts this year.
    Last year I spent $1800, but that includes $500 for recaro's and about $500 for a set of tires. The other $800 was spread around a battery, new HID bulbs, tie rod ends, OEM thermostat, set of ignition coils, several oil changes, and few minor things (wiper blades, expansion tank. etc...).
    So taking out that $1000 I've put in about $900 over 18 months. Way more than I've spent on the xB over that same period....but very reasonable.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
  19. #12939
    Established Member Four Rings
    May 20 2017
    New Hampshire
    Quote Originally Posted by vvenom800tt View Post
    Removing the outer ring isnít an issue. I have brass and wood punches for that. I was only asking about the pump body itself. These B7 fuel pumps use a pin and spring to keep the lower pump secured in the tank now. Found that out the other day.
    Thanks for the reply though.
  20. #12940
    May 20 2017
    New Hampshire
    Wait until you start tuning them. Then shit really starts to break.
  21. #12941
    Dec 04 2011
    Kansas City, KS
    Ohh yeah it just sorta slots into the main basket. It took a few goes to get it sorted for me.
    Nothing special though once you get the pin in the hole
  22. #12942
    Established Member Two Rings geerd's Avatar
    Aug 18 2013
    frozen north
    flex pipe broke is there a bolt /clamp on option? (middle of divorce so cash strapped )
  23. #12943
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    SF Bay Area
    Quote Originally Posted by geerd View Post
    Take it to a muffler shop, they'll have flex pipes on hand and can weld one in and it really doesn't cost that much. Take the car in dirty because they always give better prices to non-enthusiast types. lol
    IG @lolzhax // agilitydrives.us
    C7 S7 4.0tt | LX7U | STG1 ECU+TCU | RFX7 | EVO2 | EUROCODE SWAYS | CETE ASC | RS7 FR+R | Indicator Delete | Hardwired | Straight Piped
    b7 a4 2.0t | Stage 2+ | Recaro | Klutch KM20 | Pirelli P1 | 034 TP | Custom AWE | IE HPFP | JHM FMIC | ECS Slotted Rotors | Hawk Pads | Podi | 034 RSB + End links | DTM | Relak CF | OSRAM Headlights | Custom Steering Wheel | Android Multimedia | JL Audio| CF Wrapped Trim | Tinted | [sold]
  24. #12944
    Apr 15 2013
    Minneapolis, MN
    Correct
    Since my original module was only missing for a moment, do I need to do any kind of "adaptation" with vag-com or is it literally just clearing it?
    -Nic
  25. #12945
    Mar 12 2016
    MB w203
    New Zealand
    Have a lot at:
    Step 7: Checking Fault Codes & Applying the Basic Setting to calibrate the Pressure Control Module
    http://nickscarblog.com/diy/how-to-i...-warning-light
  26. #12946
    Established Member Two Rings bigheadb7's Avatar
    Jun 02 2017
    New Jersey
    So after replacing valve cover, oil filter, oil cooler gaskets 2k miles ago. My car started burning a lot of damn oil. No sign of leaks anymore btw. Car used to burn about half quart to quart every 2500 miles, now car is burning 1 quart every 500 miles. And every time I floor it i see white smoke on the rear view mirror. Any help?
  27. #12947
    Sep 30 2009
    08 A4, 87 Jag XJ6, Lex RX300, HD Street Rod, Grumman Yankee AA1A
    Indiana
    Quote Originally Posted by bigheadb7 View Post
    How do the plugs look? At a rate of 1 quart/500 miles they would likely be very sooty and black. Do a compression check to eliminate the rings and valve guides/seals. If compression is good, check the IC piping for oil. If there is no or little oil there you might have a bad bearing seal in the TC and be pushing oil into the hot section and out the exhaust. If there is significant oil in the IC piping, that would usually indicate a bad VC (even though you recently replaced it). Check the front passageway in the VC to see if it holds pressure or a vacuum (from the PCV valve, left side of VC, to the large port going to the pre-TC port, larger hose on right front of VC). It's an easy check.
  28. #12948
    Sep 21 2004
    Changed my oil today and did a BG EPR treatment before changing the oil.
    I took the car out for a test drive after the oil change and noticed that my oil pressure is a bit higher than normal. Same oil, same weight as last time.
    Iíd say pressure is about 3-5psi higher at idle and at 3k rpms. Is this normal? Maybe I just havenít ever noticed but seems a bit odd. Used an Mann oil filter this time and I think I used OEM last time, guess that could be whatís causing the difference in pressure?
    Is this anything I should be concerned about? Thereís no way the filter could have ended up out of alignment in the housing or something is there?
    Iíve done oil changes on my car dozens of times but havenít ever noticed this. Doing a big road trip tomorrow so want to make sure thereís not something I need to be concerned about!
  29. #12949
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    One of my o2 sensors keeps failing when I check via vag com, but no codes telling me which one. Any way to tell?
    2007 Burnt Orange Audi A4 | S-line | Titanium package | JHM Stage 2 | 034 HFC | Techtonics DP | Stasis exhaust | PSS9 coilovers | AWE FMIC | JHM HPFP | FLY LED V4 + CC | RS4 grille | S4 mirrors | AWE boost gauge | P3 gauge | 034 TIP | recaro seats | Carbonio intake | BSH catch can | GFB DV+ | APR snub mount | 034 street mounts | Cupra lip | vmr 710 |
