Page 101 of 411 FirstFirst ... 519199100101102103111151201 ... LastLast
Results 4,001 to 4,040 of 16437
  1. #4001
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    I don't used the keeper bolt, or what ever it is called. I just line it up before putting the wheels on. Btw I was able to save maybe 2 of those screws. The others I had to drill out. So I had no choice.
    What ever makes sense go with the opposite and you got it
  2. #4002
    Established Member Two Rings tware4021's Avatar
    Aug 20 2009
    2016 Audi RS7
    Syracuse, New York
    So I just got a tip downpipe (used) but I got it when I traded wheels. I know there is a difference in tip and manual DPs. My question is, will a tip DP fit a 6 speed? I know the tip tranny is bigger, but audi wouldn't change the whole direction of the exhaust due to the tranny right?
    2007 A4 2.0T 6MTQ Dolphin Gray- Unitronics stage 1+, Forge Dv, Podi stepper boost gauge, 3000k fogs, KrautoParts LED interior+ DRL+license plate lights and reverse lights
  3. #4003
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    Quote Originally Posted by tware4021 View Post
    I don't believe they are interchangeable. The trans makes all the difference in exhausts for the B7
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
  4. #4004
    Aug 20 2009
    2016 Audi RS7
    Syracuse, New York
    Quote Originally Posted by Avant4me View Post
    It would make sense on why the manual one wouldn't work on a tip, because the tip tranny is bigger, but a tip DP with a smaller tranny would seem like it would work.
  5. #4005
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by Fernieeet View Post
    Quick question; so I got these new rotors and it appears they don't have the smaller hole for the little bolt that mounts it to the hub. Is there another way to mount these without using that smaller bolt ?
    You don't need it. Just have to line everything up and be aware that when you remove the wheel, your rotor can rotate.
  6. #4006
    Established Member Two Rings Fernieeet's Avatar
    Dec 17 2012
    Napa, CA
    Quote Originally Posted by Biged243 View Post
    Quote Originally Posted by B7Joe View Post
    Hmm, okay. I'll keep that in mind when swapping them out. Thanks !
  7. #4007
    Veteran Member Three Rings B7OrangeA4's Avatar
    Nov 27 2012
    South Jersey
    Questions you thought were too dumb to ask
    I have a 034 HFC and just put replaced the rear o2 sensor and keep getting the code lambda signal too low. Not a hard code. Can i pass emission with this code? Everything on readiness says passed except catalytic converter
  8. #4008
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    Quote Originally Posted by B7OrangeA4 View Post
    Do you have a spacer?
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
  9. #4009
    Nov 27 2012
    South Jersey
    Quote Originally Posted by 2pointOh View Post
    Yea i have a J spacer in currently. Will i pass inspection with that code? And 034 HFC i know jersey isnt as anal as states such as Colorado ot california
  10. #4010
    Dec 08 2013
    Buffalo, NY
    Hm idk man. I have the 034 spacer with mine and didn't have any issue with inspection at the dealership. Maybe go somewhere in da hood haha
  11. #4011
    Nov 27 2012
    South Jersey
    I had the 034 spacer and still tripped a hard code. Replaced with a j spacer and new bosch 16986 sensor and i keep getting p0036 oxygen sensor b1 s2 heating circuit malfunction/open circuit. I ve checked the wiring and the connections and surrounding connections and nothing seems out of the ordinary
  12. #4012
    Aug 18 2009
    A Unicorn
    Portland, OR
    You're question is Jersey specific. Ask in the regionals
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
  13. #4013
    Aug 09 2011
    NOVA
    Remove your spacer. You should be able to run a HFC with o2 sensors in normally and get 0 codes.
  14. #4014
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    How do you remove the back seat?
    I know the bottom part just pulls up, but how do you remove the back rest portion?
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
  15. #4015
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by DannyDeez View Post
    Fold the seat backs down. Remove plastic cover from center hinge. Remove T30 screw and steel cap. Lift seat from hinge and pull towards center of the car. Disconnect any connectors for heaters, etc. you will also need to unbolt the seatbelt for the passenger side. 17mm bolt IIRC.
    -Adam
  16. #4016
    Nov 13 2011
    b7 s4 avant
    Spoken like a true veteran of seat removal lol. You should have seen the look the security guard gave us in Philadelphia this past weekend. Seat parts everywhere in this stupid parking garage that cost me 28 bucks to get out of!
    I drive a truck now.
  17. #4017
    Mar 24 2013
    Oakdale, CT
    Hahaha nice! When I went to get my first set of Recaros, I showed up with only the drivers seat installed in my car. I got wierd looks from the toll booth people. Glad Brandon was able to get your seats. He was looking at the $2200 set so I pointed him in your direction so he would have enough money left to buy my headlights lol.
    -Adam
  18. #4018
    Nov 13 2011
    b7 s4 avant
    Lol sounds like a win for all of us then! Do you think he got what he was asking for btw? I've never seen a set of Recaros go for that much... But, I was happy to see it because it would make my asking price look much nicer
  19. #4019
    Mar 24 2013
    Oakdale, CT
    No idea, but I highly doubt it. My two sets combined were only $1550
    -Adam
  20. #4020
    Veteran Member Four Rings brandonpham's Avatar
    Dec 06 2014
    If you're pulling the P0036 you won't pass. The minute they see a light or code passes you will a fail. Otherwise NJ is just emissions now which I'm sure you know, but they do do visual inspection so becareful if you are catless DP.
  21. #4021
    Nov 27 2012
    South Jersey
    Quote Originally Posted by brandonpham View Post
    Just the 034 HFC. I have a vibrant spacer in my garage and im debating between which would help clear it run no spacer or i have a vibrant spacer in my garage that has three different size adjustments to limit flow to the sensor
  22. #4022
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I've passed 2 NJ inspections with the 034 cat... they popped the hood once as well.
  23. #4023
    Dec 06 2014
    Worth a shot, I just passed at Wayne DMV stock, but they popped the hood on mine.
  24. #4024
    Nov 27 2012
    South Jersey
    Quote Originally Posted by Hugh@EuropaParts View Post
    Im not worried about that just the soft P0036 code for lambda signal too low
  25. #4025
    Dec 06 2014
    Do you have the original sensor that you replaced the Bosch with? And this code was existent with that as well? I've gotten faulty O2 sensors for customer cars from Bosch before from advance we had to warranty out.
  26. #4026
    Sep 11 2004
    16 Q5
    Westchester, NY
    Thanks for the help Adam!
    Question for both of you guys... Do either of you have experience with putting B6 S4 recaros into a B7 A4?
  27. #4027
    Nov 13 2011
    b7 s4 avant
    Personally no. They are a direct swap as far as I know but I believe that in order to deal with the airbag light you need to do a bladder swap. Adam probably knows more than me lol
  28. #4028
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    damnnn sean and i paid $23 for parking in baltimore and thought that was steep (we were there for 2.5 hours though so we maxed out the rate)
  29. #4029
    Nov 27 2012
    South Jersey
    It went bad and i threw it out. I had a hard code for it. I dont remember the number off my head but it was something about the heating element going bad. I replaced with a 16986 bosch sensor from europaparts.
  30. #4030
    Dec 06 2014
    Was it an oem replacement, as in connector matched up? Some cars are sensitive enough with resistance when having to wire the connector.
  31. #4031
    Mar 24 2013
    Oakdale, CT
    I've done it twice now including the bladder swap. Both my sets were from a B6. What do you need to know?
    -Adam
  32. #4032
    Sep 11 2004
    16 Q5
    Westchester, NY
    Pretty much everything pertaining to the bladder swap. Not sure how comfortable I am with doing it. Im gonna send you a PM.
  33. #4033
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Installed coilovers and adjustable upper control arms last Sunday and booked time for alignment this coming Saturday.
    The ride height needs to be slightly adjusted but I dont have time to do so before the alignment. Should I postpone the alignment till I get the ride height adjusted or?
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
  34. #4034
    Veteran Member Four Rings Axis's Avatar
    Nov 15 2011
    3.0T 6MT Stage III Allroad | A4 B8.5 Sedan
    Montreal | I sell in USD
    Quote Originally Posted by Copen-cisco View Post
    Get your desired ride height before getting the alignment done, so postpone it.
    Wagons are made to haul things, mine is made to haul ass
    *****I sell in USD*****
    Click here to read my seller feedback
    B8.5 Allroad 3.0T 6MT Sport Diff 034 Stage II+
  35. #4035
    Sep 06 2013
    Dublin, CA
    got it. thx
    Kristian
  36. #4036
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    hate to ask another question like this, but are 17's really too small for b7's, i plan on being quite low, bagged in the future. 17x10 oz futuras. 215/40 falkens
  37. #4037
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by Danaldson View Post
    Personal preference, but yes.
  38. #4038
    Active Member Four Rings waiapasi2006's Avatar
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Not really Tank,
    I still have 17'' BBS running on mine.
    Waiapasi2006
  39. #4039
    Aug 18 2009
    A Unicorn
    Portland, OR
    Quote Originally Posted by waiapasi2006 View Post
    Not really Tank,
    And it is my personal preference that they are too small. So yes really
  40. #4040
    Feb 01 2011
    Suzuki Alstare RIP
    SFL
    Personal preference, can't help you there.
    Waiapasi2006
