Page 2 of 411 FirstFirst 12341252102 ... LastLast
Results 41 to 80 of 16435
  1. #41
    Veteran Member Four Rings B7Joe's Avatar
    Apr 02 2012
    4Runner SR5 4x4
    SoCal - USA
    Quote Originally Posted by alensi View Post
    What is the tiny little filter underneath the driver rear fender?? Curious
    Just saw this yesterday. Wondering the same now. There is a larger filter in a plastic canister next to it as well. My guess is emissions crap.
  2. #42
    Nov 10 2006
    B7 A4
    Detroit Michigan
    Not sure if serious?
    Yes I am, there was a guy that added AFS Bixenon ( the ones that steer) to his car but I cant get in touch with him. These cars are very old now Im sure all of the parts could be obtained from junk yards. The issue would be getting part numbers for everything.
  3. #43
    Veteran Member Four Rings Kubus's Avatar
    Aug 10 2009
    2017 Audi S3
    Montreal, QC
    Nice thread Axis
    I need to make new spacers for my Thor skid plate. What material should I use for it? Originally it was some plastic thing but it ended up getting flattened after being over-tightened during oil changes and began rubbing on my front sway bar. I took the skid plate off but now winter is coming and I'd like to put it back.
  4. #44
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    Quote Originally Posted by B7Joe View Post
    Leak detection pump. Tied in with the charcoal canister.
    Sent from my Throne using Crapatalk.
  5. #45
    Sep 23 2012
    Atlanta
    Don't know what vag com cable to get. Bought one from amazon but can't get the drivers to work on windows 7. It has a windows 7 driver but says it won't start properly. Looking for a new cable with drivers that work with windows 7. Any body have one working properly? If you could provide a link to the one you have it would make me feel more comfortable in buying it instead going in blind.
  6. #46
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by eyesolution View Post
    http://www.europaparts.com/vag-com-d...ross-tech.html
    No issues with it ever, even when using it with Vista.
    -Adam
  7. #47
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Does the trunk of your car get dirtier than the rest of the car? After a fresh wash I can drive 10 miles and the back of the car will be full of dirt again.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
  8. #48
    Senior Member Three Rings Jhad's Avatar
    Aug 03 2012
    '11 Touareg
    SEPA
    Quote Originally Posted by Solarsuplex View Post
    yes, filthy.
    My question is will you ^ ever sell your wheels? Or will you make it to 10,000 views with no deal on vortex?
  9. #49
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by Jhad View Post
    yes, filthy.
    They will never sell. Every single trade offer I get. Is for cast 17x8 wheels. And they got the freshly powder coated so it should be a straight trade.
    -James
  10. #50
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    - What's the hook under the car on the frame, is it a tow hook?
    ....Is it a safe jack stand point? I keep rubbing that thing like crazy over speed bumps
    2008 A4 S-line 2.0T
    JHM Stage 2
  11. #51
    May 15 2012
    United States
    Quote Originally Posted by jsandor91 View Post
    do our cars have a engine to ground cable ?
    +1 for this question
    05.5 quattro 6MT
  12. #52
    Nov 15 2011
    Montreal | I sell in USD
    Is 13.8 volts while engine on and 12.6 volts while engine turned off normal? Takes a couple cranks to start when cold and im wondering if my battery is on its way out.
    *****I sell in USD*****
  13. #53
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Quote Originally Posted by Axis View Post
    you want to see it spiking to 14v while on and anything 12.5v or under is pretty much a dead battery
    2008 A4 S-line 2.0T
    JHM Stage 2
  14. #54
    Veteran Member Four Rings jsandor91's Avatar
    Jun 10 2011
    dead hookers
    South Jersey
    why do my headlights have trouble coming on / flicker when its cold ?
    Quartz Grey B7 A4 Quattro 6MT
    Maestro + Epy Tuned / GTX2867r / S3's / Spintech Non-Resonated 3 Inch Exhaust / Cold Side Synapse DV / TR18 + 2.5" Piping / Hpfp S1 Pump
    Bi-Xenon retrofit + Fly's leds / ST Coils + Rsb / 18x9.5 Miro 111's
    Dat Der Build Thread
    Coming Soon: Boost Manager +, Drakes Performance Stage V Clutch
  15. #55
    Active Member Two Rings brothaug's Avatar
    Nov 20 2012
    Los Angeles, CA
    Quote Originally Posted by Schweini View Post
    +1 for this one too, i always wondered this. especially with the screw in tow hook location for the front bumper
    2007 A4 2.0T 6MT AWD
    REVO Stage 1 | RS4 Rear Sway Bar | STaSIS Exhaust | AR Slotted Rotors | EBC RedStuff | 034 Snub | RS4 Mesh Style Grille | Smoked Side Markers | AWE Boost Gauge | Tint: 35% Front, 20% Rear | Debadge
  16. #56
    Senior Member Two Rings kp^'s Avatar
    Oct 01 2013
    PDX
    With an RSN-E - US version, 4gb (not SDHC) cards. Some mp3s are visible, while some are not. Is there a limit to length of song, ID3 tag compatibility etc? I notice that I wont see a track in the list, so I take out the sd card, edit the file length on my PC, plug SD card back in and the song is recognized. I know there is a 512 file limit, but not sure about the other limitations.
    Also, whats the flap behind the rear view mirror? I always forget to take a pic, but I will try and grab one today.
    ______
    2008 Dolphin Gray Metallic A4 2.0T Quattro Ti S-Line 6MT | Magnaflow cat | Stasis catback exhaust | Stasis coil overs | ECS LED kit | deAutoLED D1S 5500k | Hoen yellow fogs | XTRONS: IB79AA4RP | TODO: Thor skidplate, 034M RSB, Recaro seats, stage 2,
    RIP Black 2007 B7 A4 3.2L 6MT Quattro S-Line @ ~99.997 miles
  17. #57
    Sep 23 2012
    Atlanta
    Quote Originally Posted by kp^ View Post
    The little tab is to change between day time driving and night time so the light won't bother you. It's sad our cars never came with auto dimming. But it's simple, cheap to manufacture , and works.
  18. #58
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by brothaug View Post
    The hook in the back is a tow hook. Do not jack from it as it's not designed to take a load from that direction. The screw in tow hook is if you need pulled from the front and the hoop in back is if you need to be pulled out of a ditch or something backwards.
    -Adam
  19. #59
    Nov 15 2011
    I think he meant the tab behind the mirror. Its a sun visor.
  20. #60
    Sep 23 2012
    Atlanta
    Questions you thought were too dumb to ask
    Lol I see now. It's overthinking straight from Germany. It's a small sun visor it also helps to block off the red light from the sunroof controls when you're driving at night with the rear view mirror in nighttime mod. Without it you'll see red glare on the mirror
  21. #61
    Senior Member Three Rings Khaotic's Avatar
    Feb 21 2011
    2001 Audi A4 Avant 1.8T Quattro
    Sweden
    Yes, as long as you mean engine to chassi and thats underneath on turboside. Hard to explain exact location but you kind of figure it out since its between the block and frame, short black wire bolted in both ends with nuts with black protective cups over.
    2007 Audi A4 Avant 2.0 TQ 6MT S-Line
    Exterior: Bi-Xenon Retrofit | 30% Tint | KW V2 Inox | 19" VMR 701
    Interior: LED Lighting | Black Headliner | RS4 Shiftknob | oCarbon Trim | TTS Steering Wheel | Audio build
    Engine: REVO Stage 2+ | STaSIS Exhaust | R.A.I HFC | Custom CAI | AWE FMIC | HPFP Stage 1 | RAI Catch Can | JHM Flywheel & Clutch | USP Metal Slave & Clutch Line | JHM SS Trio
  22. #62
    Jun 10 2011
    dead hookers
    South Jersey
    is it visible from up top or do you have to be under the car to see it?
  23. #63
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Thank you sir
    2008 A4 S-line 2.0T
    JHM Stage 2
  24. #64
    Oct 01 2013
    PDX
    Yeah, this thing. I'm 6' 4" so I will prolly never use it. Thanks tho!
    ______
  25. #65
    Oct 01 2013
    PDX
    Found the RSN-E Manual --
    Memory cards must be formatted using the FAT or FAT32 methods.
    The file/folder name must not exceed a maximum of 64 characters
    in length. Files with longer file/folder names are not played. The file
    names for the MP3 files must have the extension “.mp3”.
    MPEG-1 layer 3 format is supported by the MP3 player. For
    compressing MP3 files, we recommend a bit rate of at least 160
    kbits/s. Fixed bit rates of 32-320 kbits/s are supported.
    In the case of MP3 files with a variable bit rate, there may be a
    discrepancy between play time displayed and the real time.
    The maximum number per medium is limited to 400 files and 256
    file folders.
    If various types of information (artist, album, track name, and so on)
    are to be displayed, an ID3 tag must be attached to the MP3 file. The
    MP3 player supports Versions 1 and 2 of ID3 tags. The display of
    artist and track name is limited to a total of 64 characters maximum.
    The Navigation System recognizes playlists and can play MP3 files
    in the sequence established there. The structure of the playlists
    must conform to m3u format. The file names must have the extension
    “.m3u”.
    ______
  26. #66
    Feb 21 2011
    Sweden
    Not sure, never looked for it from up top, but I doubt it will be easy to find from there.
  27. #67
    May 15 2012
    United States
    Thanks Khaotic I am doing a big 3 upgrade so and I couldn't find it.
    05.5 quattro 6MT
  28. #68
    Nov 15 2011
    Someone as the part number for the bushing on the shifter? The one you can see when you remove the shifter boot, looks like a plastic sphere. When i removed my shifter trim to wrap it I noticed that it's cracked.
    Or any good after market part.
  29. #69
    Jun 10 2011
    dead hookers
    South Jersey
    Quote Originally Posted by 02serv View Post
    i've got 25 ft of shiny red 0 gauge wire sitting in my trunk but no motivation to do the big 3 lol. post up pics when your done!
  30. #70
    Dec 23 2011
    Maybe I missed it but what is the big three?
  31. #71
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by p0isin View Post
    Shit, Shower, and Shave
    jk no clue
  32. #72
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    The big three from a car audio aspect is Alternator, Wires, and Battery upgrades.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
  33. #73
    Jun 10 2011
    dead hookers
    South Jersey
    jk no clue
    big three is a common mod for anyone who has a stereo or alot of electronics in their car.
    from crutchfield -
    "A good, cost-effective improvement is to perform the "Big Three" electrical upgrade. This will vastly improve your vehicle's electrical system, allowing more current to flow easier to all components. This upgrade replaces or augments three key cables in the electrical system with 1/0 or 4 gauge wires: the battery ground to chassis wire, the chassis to engine block wire, and the alternator plus to battery plus wire. This increases your electrical system's current flow capability, ensuring a more consistent voltage under varying demand conditions."
    supposedly either doing the big 3 or making a grounding kit will increase hp a bit by less electrical resistance. not sure if i buy in to that part but it couldn't hurt. overall it will create a better running system that is optimized for a aftermarket stereo and your lights shouldn't dim at all when your roll your windows up
  34. #74
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    from crutchfield -
    Sounds like a pain in the dick! Rewiring someone else's work is never fun
  35. #75
    Jun 10 2011
    dead hookers
    South Jersey
    its really not! throw some new battery terminals on there while your at it. battery to ground is like a foot. battery to alt you need a few feet shouldn't take more then 15 min to do and the engine to ground shouldn't be bad either but evidently its near the turbo somewhere
  36. #76
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    There is one that goes from under the motor mount bracket to under the passenger frame rail
  37. #77
    Jun 10 2011
    dead hookers
    South Jersey
    thanks!
    also nothing says racekor like red wires.
  38. #78
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    thanks!
    Except flames shooting out of the exhaust
  39. #79
    Jun 10 2011
    dead hookers
    South Jersey
    i wouldn't mind a little flame here or there. never heard of a fsi shooting flames, it's basically just running rich and extra fuel getting ignited in the exhaust right?
    also another dumb question, anyone know what resistor i can put in the + for my boost gauge to make it a little more dim to match my dash? its a podi mechanical gauge
  40. #80
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Yeah I think it's just extra fuel.
    I'm not sure about resistors but you could look for the wire that is the dimmer in te cluster ad just tap into it.
