Results 1 to 9 of 9
Hybrid View
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Problem after replacing the serpentine belt
    I apologize, my searching ability is getting rusty.....found threads but cannot find the right answer
    Anyways, finally tackle the job of replacing the serpentine/drive belt along with coolant flush and oil change.
    --My mechanic didn't able to replace the serp. belt along with the timing belt coz he didn't have it in stock.
    After the install, loud high pitch noise can be heard from the belt and it does go away once engine gets warm. Tried bleeding the coolant but once I turned the A/C on, the noise came back and it's loud as F***. Looked at the belt and it looks kinda wiggly...turned off the car coz the noise was too annoying.
    Tried it again after an hour or so, noise is still there til' the engine gets warm. Left the car running without doing anything and the noise came back once again
    such an easy job and is now giving me a headache.....
    Checked power steering fluid....its good
    I also made sure that I put the right amount of oil and coolant.
    More info:
    car is an 02' 1.8T quattro MT
    forgot where I bought the belt but IIRC, I input my VIN to make sure I get the right one
    -Part number: 06B 903 137 D
    I compared the new belt with the old worn out belt and I can tell that the new one is longer or bigger in diameter.
    Any help/tips/advise would be great!
    Thanks in Advance!
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Apr 30 2009
    4motion passat
    Houston, TX
    I'm not sure if you have the correct belt installed; but the sound you mentioned = loose belt
    Veteran Member Three Rings Jflow23's Avatar
    Apr 09 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    ^^This
    Sounds like you need the shorter belt.
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    The noise that you describe is the belt slipping. You need a smaller one
    Use the old belt to buy the new one
    Good luck
    Jun 30 2008
    Erie, Pennsylvania
    The belt you gave is the correct number for 2002>early 2004 1.8T's.
    06B 903 137 D = 1590mm length
    There is a vin split in the 2004 model year (8E-4-191 000), above which a shorter belt is used:
    06B 903 137 J = 1572mm length
    I'm not certain what necessitates the shorter belt. As far as I can tell, the rest of the parts are the same: crank pulley, alternator, power steering pump, bracket, idler, tensioner, etc.
    In any case, if your new belt is longer than your old one, you probably need to a get a shorter belt. If you can't read or determine what that is, I'd probably start with the "137 J" belt from the 2004 model.
    Oct 08 2009
    12 more rings
    Northridge, CA
    Thanks for all the feedback!
    Buying the other belt was my last resort and I guess that's the only solution I have. It is the culprit after all.
    Only reason I asked is I've read somewhere that the belt does adjust, tighten itself but I guess that's not the case here
    Thanks again!
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    I had a similar problem when I did my timing belt job. It ended up being the idler pully (not the tensioner, the pully/roller under that).
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Established Member Two Rings a4udios's Avatar
    Jul 07 2013
    Glendale
    There's two belts 1570 and 1590, you need the 1570.
    Apr 09 2007
    Beaverton OR
    I had a similar problem, finally fixed for good with this. It has teeth instead of grooves.
    1570mm belts (OE, Continental and the cheap belts at the local auto stores) all screamed. I saw rave reviews about these belts in a domestic forum...and gave it a try. They are around $20 on amazon. I used part no 4060620, it's 1575mm vice 1570, but appeared to be shorter than the Continental 1570 that is in my possession with only 1000 miles on it, it's thicker as well. When I threw it on, I noticed the tensioner sat different and created much more tension. Not a peep since.
