Results 921 to 960 of 1495
Threaded View
    Veteran Member Four Rings sciblades's Avatar
    Mar 20 2009
    North Salem/Palm Beach
    C7 A6/A7 & S6/S& VAG COM list and help
    C7 A6/S6 VAG-COM mods
    Okay guys, there has been a lot of requests lately for a VAG-COM DIY. The purpose of this DIY is to walk you through the steps to do several VAG modifications.
    So far we have the following:
    • Disable amber corner lights
    • Disable NAV & Phone warning messages while entering data at speed
    • Disable Seatbelt Chime
    • Enable Adaptive brake lights
    • Enable Automatic Gear selection shown in DIS
    • Enable Double Disarm Beep
    • Enable Hidden menu in MMI
    • Enable Import CDs to MMI's HD
    • Enable Independent Fogs control with high beams
    • Enable Lap Timer
    • Enable Remote Operation windows&sunroof
    • Enable TPMS
    • Enable VIM on MMI
    • Set Audi parking system - Switch OFF Speed
    • Adjust LED Brightness
    • Beep on lock
    • Adjust bluetooth microphone sensitivity
    • Enable Auxiliary ventilation
    • Enable Drivers Memory Seat
    • Increase radio play time after car is turned off
    • Enable coming home/leaving home function DRL
    • Tail lights on with front DRLs
    • Change the Adaptive Cruise Control Preset distance
    • Enable power trunk to close from key fob
    • Disable start/stop
    Equipment Required:
    Laptop with Vag-Com software
    Vag-Com Cable
    Many people get very intimidated and uneasy about messing around with the car settings on the computer. The most important thing to know is that everything you do in this DIY CAN BE UNDONE. There is no reason to get nervous, you will not do any damage to your car. Simply follow the instructions and you will be fine.
    I am doing all of this via Ross-Tech Vag-Com with USA factory settings. If you are outside the USA the stored values might vary. Also, other conventional vag-com units can be purchased to do these modifications. The process is probably somewhat the same.
    Step 1: Hooking up the Vag-Com
    First step is to plug in your Vag-Com to the OBD-2 port. It is the purple connector located right behind the hood latch under the steering wheel. Once you have plugged it in, connect it to your laptop device.
    Make sure you are running the most recent version of Ross-Tech's software. You will most likely be prompted if you are not.
    ***HAVE YOUR KEY IN THE IGNITION TURNED ON ACCESSORY MODE (hit the start button once). VCDS WILL NOT WORK IF THS IS NOT DONE***
    Step 2: Let the fun begin!
    Start VCDS
    First thing you want to do is to make sure the VAG-COM is properly connected to your car. Click OPTIONS in the bottom right corner.
    You will now be taken to the Program Options menu. Under Port and Protocol Options select TEST as shown below.
    After you hit test the program will test the connection between the Vag-Com and the cars computer. After a few seconds you will get a screen shown below. Make sure the Status reads READY.
    Hit SAVE and return to the make screen.
    To access the hidden menu, hold down Car and Menu together for 5 seconds
    To reset the MMI 3G+, press Menu, Big Knob, and Top Right Soft Button simultaneously
    Use this hidden menu at your own risk.
    Caution: Keep away from the "Bootloader"
    Okay so this is a compilation from other forums trying to place everything together so that when people try to do vag com mods to your car you will feel more at ease and know the ones that work.
    *Suggestion: Print this and check off the mods you've activated and store it with your owner's manual - Will come handy when you need to re-do the coding after an ECU flash.
    Here's the list I've compiled so far:
    • Enable Lap Timer
    • Enable TPMS
    • Enable VIM on MMI
    • Beep on lock
    Audi A6/A7 & S6/S7 C7
    VCDS (VAG-COM) codes
    ________________________________________
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 0
    Bit 2-4 – Seat Belt Warning inactive
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    [46 - Central Conv.] [Adaptation - 10] -> Channel 63
    Add 4
    change 0 to 1
    [Hidden menu]
    Main/Diagnose/Settings
    Import Media
    Set to 4 of 4 "Copy/Ripping"
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 4
    Bit 1 – (Front) Uncheck the box or change :Bit 1 to 0
    Bit 2 – (Rear) Uncheck the box or change :Bit 2 to 0
    Enable Lap Timer Shown in HUD- also enables shift light
    [17 - Instruments] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 - Check the box for "Lap Timer active"
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    Enable TPMS
    * You need the 1AT ABS unit – check your stickers (1AS does not work)
    [Hidden menu] [car] [cardevicelist] [RDK] Enable
    [Hidden menu] [car] [carmenuoperation] [Tires Air Pressure Control] Set to 5
    [03 - ABS Brakes]
    [Security Access - 16] (probably with login code: 61378)
    Bit 3 - Tire Pressure Monitoring (PR-7K6) active (1 = active)
    The TPMS need to be enabled in the Instrument Cluster:
    [17 - Instruments]
    Bit 0 - Tire Pressure Monitoring (TPMS) installed (1 = active)
    Reset MMI
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    Adjust LED brightness
    [09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3
    Set between 5 and 100
    BEEP ON LOCK Chirp the alarm siren briefly when the alarm activates (ie all doors are closed and the car is locked)
    [Select]
    [46-Central Conv.]
    [Coding - 07]
    Click on byte 1 and in bit 2 you'll see the selectable option: "Anti-Theft-System: Horn Confirmation active"
    Check this option
    [Do It!]
    Hidden menu
    Diagnose
    Settings
    Mic sensiblity - choose -6db/0db/+6db
    http://www.audienthusiasts.com/VagCom_AuxVent.html
    [5F - Information Electr.] [Coding - 07] -> Long Coding Helper -> Byte 6
    Bit 1 – Set to 1
    [Hidden menu] [car] [cardevicelist] [Auxiliary heating] Enable
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    36: Seat Mem - 07 Coding - Long Coding Helper - change Byte 2, bit 0, to 1
    Seat memory will be there however greyed out in MMI
    Press and hold down unlock button on key fob for 5 seconds for the windows to come down
    Press and hold down lock button on key fob for 5 seconds for the windows to go back up
    In MMI, Seat Adjustment you are now able to find Driver's seat, you can set Key memory on/off. Set it "on" for both keys separately.
    In the Hidden Menu:
    From the main screen select 'onofftimer', set 'Standby delay'. The maximum value is 30 minutes.
    [Select]
    [09 Central electric]
    [Coding - 07]
    [Long coding helper]
    Click on byte 6 and disable bit 4
    Leaves the low beams off when unlocking the car and just have the DRLs on when its dark outside, similar to some other Audis. Much cleaner look.
    [Select]
    [09-Central Electric]
    [Coding - 07]
    Click on byte 2 and enable bit 7
    Turns on rear tail lights DRLs during the day, for a more aggressive look.
    [Select]
    [13 Distance Regulation]
    [Adaptation - 10] --> channel 7
    Change from 0 to 1
    Reboot MMI
    Will now have an option in your MMI under Car --> Driver assistance --> Adaptive Cruise Control to set which of the 4 preset distances your car will default to when you activate your ACC.
    Disable rear side markers in US vehicles
    [Select]
    [46-Central Convenience]
    [Security Access] enter 16017
    [Adaptation - 10] --> channel 209 for left rear side marker
    Document your existing number should you need to re-enable rear side markers later
    Change existing number to 0
    Channel 210 for right rear side marker
    Change existing number to 32
    Turn off parking brake when in park mode
    [Select]
    [53-Parking Brake]
    [Adaptation - 10]
    Click the drop down channel menu
    Select the "Automatic parking brake for selector lever position P"
    Change to Not Activated
    __________________________________________
    Disable/memorize/invert Start & Stop:
    - module 09-Cent. Elec.
    - enter Security Code (20113)
    - Adaptation on Channel 34:
    subtract 4 to the value --> Start&Stop always disabled
    add 32 to the value --> memorize last status (the Start & Stop status at engine startup will be the one at last engine shutdown)
    - test & save
    In addition of these values, if you add 64 to the value, the Start & Stop button light will be reversed: off if Start & Stop is disabled, and on if Start & Stop is enabled
    Quote Originally Posted by uttevrec View Post
    Here are some new details and mods to (hopefully) add to the first thread.
    Because I've seen multiple people asking about / having trouble with remote window up and down, here the expanded details to get this to work:
    Operating Windows and Sunroof with Remote
    This will allow enables remote closing of the windows and sunroof by holding the Lock button on the remote control. In addition, it adds an menu item in the MMI to optionally allow opening the front windows/rear windows/sunroof by holding the Unlock button on the remote.
    • [46 - Cent. Conv.] -> [Coding - 07] -> [Long Coding Helper] -> Byte 2-> Bit 2
    • Check "Comfort Operation: Remote Control active" box.
    • Save
    Windows and Sunroof will now close with long button press of Lock button on remote.
    To Open Front Windows and/or Rear Windows and/or Sunroof with long press of Unlock button on remote:
    • Reboot MMI to make sure the menu item appears (press Menu, Big Knob, and Top Right Soft Button simultaneously)
    • Use the New MMI Menu to Change MMI Settings to allow remote down
    • MMI: [Menu]->[Car]->[Car Systems]->[Vehicle Settings]->[Central Locking]->[Long press to open windows] -> Set Front Windows, Rear Windows, Roof to “On”
    New Mods not listed in this thread:
    A7/S7/RS7 Only: Close the trunk (a.k.a. boot) remotely using the key fob and/or interior trunk switch (and retain the opening feature)
    Go to Module 46 (cent convenience), coding, long coding helper
    byte 2, bit 2 "Comfort operation: Remote control active" should be checked, so no need to change it, just confirm that it's set.
    No Change, Original Coding: Bit 2 checked
    Then got to module 6D (Trunk Electrics), security access and enter security code "12345". Then still in Module 6D, click Adaptation, channel
    and there are 8 options for "Activation using rear lid. . .". Change the two "number 4" settings to active.
    Original Coding:
    • (1)-Activation using rear lid opening button in remote key - Touch function for opening: not active
    • (2)-Activation using rear lid opening button in remote key - Tap function for opening: active
    • (3)-Activation using rear lid opening button in remote key - Touch function for closing: active
    • (4)-Activation using rear lid opening button in remote key - Tap function for closing: not active
    • (1)-Activation using rear lid remote unlocking switch - Touch function for opening: not active
    • (2)-Activation using rear lid remote unlocking switch - Tap function for opening: active
    • (3)-Activation using rear lid remote unlocking switch - Touch function for closing: active
    • (4)-Activation using rear lid remote unlocking switch - Tap function for closing: not active
    New Coding:
    • (4)-Activation using rear lid opening button in remote key - Tap function for closing: active
    • (4)-Activation using rear lid remote unlocking switch - Tap function for closing: active
    Changing the first "number 4" allows closing of the trunk lid with a quick press of the trunk button on the remote control.
    Changing the second "number 4" allows closing of the truck lid with a quick pull of the trunk switch (in the driver's side door)
    The trunk is still opened as before. It will beep when remote closing.
    Change the time before the heated seats auto-change from level 3 to level 2
    When the heated seat is set to full (level 3) it will only stay on full power (level 3) for 10 minutes before automatically dropping to level 2. To increase (or decrease) the amount of time this takes, go to
    Module 08 (HVAC) -> Adaptation -> drop in down box select the option 'time until heated seat stage withdrawal from 3-2'.
    Enter a new value. Save.
    The default is 10, which is 10 minutes. I set it to 15 minutes. Change it to zero to prevent it from auto-switching from level 3 to level 2.
    There is also an option for auto-changing from Level 2 to Level 1. This is disabled by default (set to zero.) If you want to enable this, enter a value in minutes.
    Hope this helps others!
    Again, I take no credit for this information, most of the above is available on these forums and specialty websites as well as Ross-Tech's support pages. I only wanted to group all the info of the pertinant VCDS mods to our s6/s7.
    Any extra ones I will gladly add
    Huge thanks to TunTap below is information he compiled
    how to lower you car 17mm
    I finally accomplished lowering the S6 with VCDS. Some said it can't be done, but it most definitely worked for me. It should be entirely reversible in case you decide to revert the settings. All research was done through Google and playing around with software settings, none of this information was provided by Audi or Audi dealers. This method is an alternative to Lowering Links (which are great if you don't have the electronic tools/would rather go the mechanical route), or H&R lowering module (which is also great, and allows for on-the fly adjustments vs. having to mess with car systems).
    I figured that since all the tools and information required to do this have already been made public on the internet, it is just matter of time until someone posts a step-by-step guide, so here it is.
    DISCLAIMER: I am not responsible for anything that these changes may cause, or if your car breaks, or if dealership finds out and denies your warranty if something goes wrong... Try this at your own risk.
    0) Set your car to "Auto" mode (not dynamic, comfort, etc.). Make sure car is on level ground. Close doors. If any doors are opened during the procedure, it will be interrupted. Make sure your car is NOT in a towing or tire changing mode.
    1) Load up VCDS, go to Module 34 - Level Control
    2) Go to "10 - Adaptation", take note of 4 values titled as "Body height front left wheel house edge" - mine were set to around 384 from factory.
    3) Take the values you noted above, and ADD your desired drop in millimeters (mm) to each value, write it down... So if your left front wheel was 384.5, your new value will be 401.5. Repeat for the other wheels. It is not critical to be 100% precise here, rounding the values is fine. Note that maximum Audi-approved drop is 17mm from what I've gathered. You can go lower, but if you go lower, you're also affecting other systems, such as cameras, adaptive cruise, etc., so be careful.
    Technically, if you want this procedure to be done properly, instead of taking existing values, you will measure all 4 wheels after completion of the step 7, and then add your drop value if desired. Suspension height values are measured from the center of the wheel to the edge of the fender.
    4) Go to Security Access, enter code provided on the following website, under VCDS section, item #3 (I'm not posting this directly to avoid spreading sensitive data, although it's been posted on other forums in past) http://www.stemei.de/pages/coding/au...ng-des-aas.php
    5) You should get a message stating that security code has been accepted - if you don't, something failed, stop doing what you're doing
    6) Go to 04 - Basic Settings
    *** IMPORTANT: Whatever you do, DO NOT select "Reset All Adaptations" - this is not undoable, and will require a visit to the dealer. ***
    7) Select "Activate Level Control", hit "Go", wait for it to complete (should only take a second, until it says "not running").
    8) Select "Delete Calibration For Level Control", hit "Go", wait for it to complete, your car will throw a fault code and you will see an error message stating Air Suspension Malfunction - this is normal.
    7) Select "Start Up to Reference Level", hit "Go". This step will take about a minute, and your car will go up/down during the process (you'll hear hissing noises). Wait for it to complete, until it says "not running".
    9) Select "Go Back", go to "10 - Adaptation" on the previous screen.
    10) Next you will need to enter new adaptation values for all 4 wheels. Select "Body height front left wheel house edge", then enter new adaptation value, and hit "Do it", then repeat for the other 3 wheels. I did it in the order the menu was arranged (FL, RL, FR, RR) - not sure if the order matters, but just in case. Each time you enter a value, you should get a message stating that it has been accepted.
    11) After you're done entering adaptation for all 4 wheels, select "Go Back", and return to "04 - Basic Settings" again.
    12) In basic settings, select "Calibrate Level Control" and hit go, it will take a few seconds. Wait for it to say "not running". If you get an error during this step, you either missed a step, or something went horribly wrong.
    13) Select "Activate Level Control", hit "Go"
    14) You're done, now go to "02 - Fault Codes" and Reset codes.
    If this did or didn't work - please share your experience with the rest of us here
    Printable version
    https://onedrive.live.com/?authkey=%...AACCDFFF88F25F
    2016 RS7 Stinger VIP laser and radar, Unitronic Stage1+
    Gone
    2013 C7 S6- v1 and LI- Unitronic tuned]
    B8 S4
    06 a3 Full Votex Kit, Unitronic III, apr tbe, precision 750 FMIC, apr HPFP forge dvi, EVOMS cai, BSH gt3076r turbo kit, IE rods, sb stage IV, LSD, on meth
