Page 23 of 38 FirstFirst ... 13212223242533 ... LastLast
Results 881 to 920 of 1495
  1. #881
    Senior Member Two Rings Pampedout6's Avatar
    Jun 26 2015
    Southern NJ
    Quote Originally Posted by efithian View Post
    I wrote to Kufatech and asked if it worked on the 2016 A6, and the response was no. No returns if it doesn't work.
    On the German website under A6 4G (your model) I found this:
    https://www.kufatec.de/shop/de/tv-fr...skoda-columbus
    For whatever reason it's listed at €149 when I paid €250 for the S6 version. You're going to have to roll the dice on this one, I personally think it's going to work but that's a €150 gamble YOU'RE going to have to decide to make. I believe their hesitancy in telling you it's going to work is from the fact that they actually haven't had the opportunity to test it on a MY16 version. I don't see why your MMI would be any different than mine, but that's just my 2 cents. Let me know what you decide to do.
    Sent from my SM-G925F using Tapatalk
    2016 with Prestige package, Sports Package, Night Vision, Cold Weather, Driver Assistance, APR Stage 1 ECU/TCU, 21" Vossen VFS1's with Michelin PSS in 255 35 21, Weather Tech Mats, ROC Euro Air Intake, 3M Tint at 20%, Exhaust resonator delete with H-pipe, VAG Mods
  2. #882
    Dec 01 2015
    Madrid / Spain
    Quote Originally Posted by agent47 View Post
    Did all the mods to my 16 that I had on my 13. But I cant find a way to disable the phone/nav warning. Maybe the vagcom menu has changed? Anybody with a 16 did it? Or if anyone with a 13 or 14 wanna share steps to do it in pictures?
    I have a new A6 since mid Nov 2015 (so the 2016 model), and I have tried to enable the VIM without any success.
    You say in another post that the security code was showed by the VCDS windows application, but probably we are using different ways to do the VIM change, as I am not receiving any pop-up help.
    Would you be so kind to tell me which were the steps you followed to activate the VIM?
    I did a try following this article (http://www.audienthusiasts.com/Articles_VIM.html). There are many others in the web, but all of them use the same algorithm to calculate the security code and it does not work with the new A6 models.
    If you used a different method and you want to share it with me, I will appreciate it a lot.
    And ... if you used the same method, could you please send me your module serial number, and the security code you used to access to the Adaptation Mode?
    Many thanks in advance.
    eklalj
    P.S.: I am part of a very good Audi forum in Spain, and there are several people looking for the way to activate the VIM in the new Audi models. So you will also help other people as I would share the solution if it works.
    Just to give you some additional info. I am using a VagCom cable version 15.7
  3. #883
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by eklalj View Post
    eklalj
    VIM not available through VAG com at the moment until someone figures out security access, as of now, the only way to do it is with either a VIM dongle from kufatec.de or supposedly there is another cable on the market that is apparently capable of doing this
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
  4. #884
    Dec 01 2015
    Madrid / Spain
    Quote Originally Posted by richib86 View Post
    Thanks for your fast response, richib86 ...
    I have also seen this other solution https://www.youtube.com/watch?v=tyElC7VYuGQ and have been in contact with them through http://kaptrader.com/tvfree_Audi_4G_A6_2016_Year.html
    The solution is less expensive than the Kufatec one, and has the possibility to enable or disable the VIM pressing a button for 10 seconds, which is really good. But the cost of the shipment to my country (Spain) from Korea is near 70% the price of the solution, and if finally I was requested to pay local taxes for it, the total amount is too much from my point of view.
    I have also read that it is possible to activate the VIM using the VCP instead the VagCom, which could be another option. But it is really a pity to do not know the new vagcom security code.
  5. #885
    Established Member Two Rings waynegz1's Avatar
    Apr 30 2013
    San Antonio, TX
    I went in today to try and disable the rear side markers using the information below:
    7) Disable rear side markers in US vehicles
    [Select]
    [46-Central Convenience]
    [Security Access] enter 22790
    [Adaptation - 10] --> channel 209 for left rear side marker
    Document your existing number should you need to re-enable rear side markers later
    Change existing number to 0
    Channel 210 for right rear side marker
    Change existing number to 32
    When I went to channel 209, I got the message that security code must be entered (which I already had).
    I waited an hour and went back to try again, same result.
    Anyone else have this issue?
  6. #886
    Established Member Two Rings davelong9050's Avatar
    Oct 09 2015
    Gold River, CA
    Quote Originally Posted by waynegz1 View Post
    [Select]
    Yes and I gave up.
    I eventually wrapped up the bulb assembly and reattached it in the side marker compartment so it does not show any illumination. Fronts are off but backs do illuminate, you just can't see them.
    Keeping an eye on this thread and waiting for someone to figure this out for S7 facelift.
    2016 Audi S7 (C7.5) // Ibis White w/ Black Interior/ Contour Seating/ Driver Assist/ Sport Package/ Carbon Inlay/ Power Assist Doors/ Head Up Display
    Aftermarket // APR ECU Tune/APR TCU Tune/ Xpel/ Opti-Coat/ 30,50,70 Ceramic Window Tint/ 20” Rohana RF1’s (refinished silver)/ Painted Calipers/ Slotted Rotors/ H&R ETS Lowering Module/ RS7 Grill/ Carbon Fiber Rear Valance/ Upgraded Sub with Dedicated Power Amp/ Escort 9500ci Radar Detector/ VAG-COM Mods
  7. #887
    Apr 30 2013
    San Antonio, TX
    Quote Originally Posted by davelong9050 View Post
    Yes and I gave up.
    I gave up too but planned on getting the color matched side/rear markers from TAG. So I am on a mission to find out how to stop the back ones from turning on.
  8. #888
    Oct 09 2015
    Gold River, CA
    Please let us know on this thread if you have any luck. I'm sure there are others that have discovered the same thing.
    I did check with the shop foreman at my local Audi dealership to see if he was aware of any reference material such as service/ maintenance manuals that would contain VCDS coding. He was not aware of any centralized resource. This seems to be "poke around experimentation with hit and miss as the primary technique used to make changes."
  9. #889
    Apr 02 2014
    2005 Porsche Boxster, 2006 Lexus LX470
    Upstate South Carolina
    Quote Originally Posted by Delurker View Post
    Any way to have the emergency brake not come on when I crack the door open to check if I'm between the parking space lines? (engine running, but in park with my foot on the brake - jeebus that's annoying)
    dunno if you ever solved this but on my [early] 2014 A7 TDI, the VAG-COM tool allowed me to modify:
    [53 Parking Brake]
    Adaptation
    Channel (1) Driver Out Apply stored value: activated
    I was able to change this value to deactivated although it required security access first. Happily VAG-COM supplied the security code suggestion of "78713" which allowed me to modify this value.
    And yes, the default/shipped operation (opening driver door activated the emergency brake) was a PIA.
    Cheers!
    LouB in SC
  10. #890
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    So i went outside to see my drl light mod since i changed them from 26 to 51 and i have to say it's pretty nuts..
    i think i'm gonna turn them down to about 36 and see how i like it,you guys who turned them up to 100 i don't understand it.
    different strokes for different folks but set at 51 it's hard to tell the drl's from the headlights at night.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
  11. #891
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by bonafyd View Post
    I set all mine that I do at 80!
  12. #892
    Nov 27 2008
    New Jerz
    Quote Originally Posted by HyperM3 View Post
    Maybe i gotta let it grow on me but like i said i think it's hard to tell the drl's from the headlights at night.
  13. #893
    Feb 16 2015
    Midwest
    You guys who turned them up to 100 i don't understand it.
    The big problem with turning them us is that the DRLs are omni-directional, so they look like high beams to oncoming drivers. I was driving in font of someone from work who had the DRLs turn all the way up at night. I thought he was pissed at me and was "high beaming" me. Nope, just did the mod without thinking about implications to other drivers.
    I tested it against a white wall. I was shocked at how bright the light scatter on the wall and ceiling was from the turned-up DRL. I think I turned mine up to 36. Anything higher and there was too much high beam effect. There's a reason the default setting is so low...
  14. #894
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    I tried mine at 65. Went crazy bright tbh. Turned it down to 50. Its still bright but looks good. No high beam kind if effect yet.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  15. #895
    Nov 27 2008
    New Jerz
    Quote Originally Posted by uttevrec View Post
    I'm gonna try 36 and see how I like it because 51 is too bright for me.
  16. #896
    Nov 27 2008
    New Jerz
    Hey does anyone know what can be done in the hidden menu? is it something i should bother with entering??
    I tried searching but nothing specific..
    Did anyone with a c7.5 A6 do these mods?
    Disable NAV & Phone warning messages while entering data at speed
    [5F - Information Electr.] -> Adaptation -> Set channel 2 & 3 to 250
    Disable amber corner lights
    [09 – Cent. Elect.] [Coding - 07] -> Long Coding Helper -> Byte 10
    Submodule 0
    Bit 3 - Set to 0 to disable amber side markers (U.S. vehicles)
    This one my #'s are reverse i wonder if Audi switched it Left is 0 Right is 32
    [Select]
    [Security Access] enter 16017
  17. #897
    Apr 30 2013
    San Antonio, TX
    Anyway to turn off the amber blinkers while the headlights are on at night? I noticed mine stay on while the headlights are on.
    PS, still cannot find out how to turn off the rear side markers. Still get the that security code must be entered message when going to channel 209.
  18. #898
    Veteran Member Three Rings SlickMachine's Avatar
    Feb 21 2012
    2018 Ford Explorer Sport
    Aurora, CO
    Submodule 0
    [Select]
    I also cannot find anything anywhere on what exactly you can do from the green menu. Only thing I'm aware of is activate the ability to rip a CD to the hard drive. Anybody have a good list of features in the green menu?
  19. #899
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Does anyone know if the auto high beam disable speed is settable and if so where? Thanks.
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
  20. #900
    Feb 26 2010
    Los Angeles, CA, USA
    Quote Originally Posted by MadAboutCars View Post
    Got this from the web....it was in German and had Google translated into English. I tried to change the settings in my 16' RS7 but unable to locate the channel # (VCDS does not have channel descriptions therefore can't locate the exact channels to change the settings). This may work for older models.
    Customization of the high-beam assistant
    In the control device of the high-beam assistant, you have the option of the Audi A7 4G adjust the low beam and Aufblendgeschwindigkeiten. If you want that the wizard can be activated for remote lighting control, for example, earlier you can adjust / modify accordingly so as described readily.
    The following code is to be applied:
    select STG 20 (High-beam assistant)
    STG adjustment -> function 10
    Select channel Aufblendgeschwindigkeit
    (speed at which the beam can be displayed according to the environmental conditions)
    Value For example, on 30 Adjust - standard 57 km / h
    Select channel Abblendgeschwindigkeit
    (speed when dimmed, the high beam and the high-beam assistant is deactivated)
    Value For example, on 10 Adjust - Standard: 27 km / h
  21. #901
    Aug 27 2015
    New Zealand
    Quote Originally Posted by chucky0731 View Post
    Thank you! My car is MY16 as well, but I will have a look in that area and see what I can find.
  22. #902
    May 17 2016
    Finland
    I did this mod
    "Activation of Ambiante Lights
    Select Control unit 09 (Central Electrics)
    Control unit Long Coding
    Byte 17
    Bit 3 Activate - MMI settings
    Bit 2 Activate - front footwell lighting
    Bit 1 Activate - door lighting
    Select Control unit 5F (infotainment)
    Adaptation
    Select channel (6) Menu operation vehicle-menu_display_ambient_illumination
    value to adjust activated
    Select channel (8) Menu operation vehicle-menu_display_ambient_illumination_over_threshold_h igh
    Channel (15) vehicle function list BAP interieur_light_0x08 Select
    a value to adjust activated"
    The problem is that the MMI background light menu is grey and cant use it.
    Footwell lights are on when headlights is on but very low brightness. Any idea? My car is A6 2015 model.
  23. #903
    Senior Member Two Rings cNEGOTIATOR's Avatar
    Feb 29 2012
    Canada BC
    Has anyone figured out how to disabled daytime LED turn-signal wink on a 2014-2015 rs7?
  24. #904
    Apr 30 2013
    San Antonio, TX
    Still cant figure this out:
    Anyone able to turn off the amber blinkers while the headlights are on at night? Mine stay on while the headlights are on.
  25. #905
    Established Member Two Rings TD_05's Avatar
    Dec 19 2013
    2016 Audi S6 2005 BMW M3 1994 Nissan King Cab
    Midwest
    Anyone find a way or know if it's possible to crank up fan speed / intensity / cooling ability of the ventilated seats on comfort seating package?
    Thanks
  26. #906
    Oct 06 2015
    San Jose CA
    I have a 2016 Audi S7 and the programming for the VIM in MMI is not coming up . I followed the instructions and cannot get the security code to work. Has anyone else with a similar vehicle year had the same problem? Do I have to unlock the secret menu first and then proceed to program the second code of:
    Enable VIM on MMI
    [5F - Information Electr.] [Advanced ID - 1A] Note 1st Serial number
    [Security Access] Enter Digits 6, 13, 10, 14, 11 of the 1st Serial number
    [Adaptation - 10] -> Channel 48
    Set to 255
    Reset MMI
    I would prefer response to someone who is 100% sure or has experience on the 2016 Audi s7 with current MMI for that model year. THanks guys.
  27. #907
    Nov 05 2006
    Fair Lawn
    it would behoove you to read on after the first page haha, VAG com will NOT unlock VIM until someone cracks the security code for adaptations for the 16 models, also no more green screen, thats all done through adaptation channels now. For the 2016 models the only solutions are this new VCP cable thats been popping up lately or get the VIM dongle from kufatec.com
    - - - Updated - - -
    Quote Originally Posted by PlatinumS7 View Post
    Enable VIM on MMI
    Set to 255
    Reset MMI
  28. #908
    Anyone know how to enable aux heater menu with mmi low??
  29. #909
    Jun 05 2008
    Carmel, IN, USA
    I might have missed something, but does anyone know how to enable windows up on the fob and at the door on a A7/S7 2016? I don't recall an issue when I did it on my S6 Also, does anyone know what enabling advanced key and window regulator features in the VCDS byte do?
    '14 S6 Prestige Phantom Black Pearl Effect/Black: Sport Rear Differential, Head-up Display, Night Vision, Driver Asst Pkg, Contour Seating, LED Headlights, Layered Aluminum/Blk Wood, Sunshades, Cold Weather Pkg, Rear Airbags, Side Tint, Auto Hold, Audi Platinum Protection 12/'21 96,912 mi
    ’13 Mercedes Benz E 550 4Matic
    '16 Honda Odyssey Touring Elite Obsidian Blue Pearl
    Sold: '05 A6 C6 3.2Q Stratos Blue Loaded
  30. #910
    May 15 2016
    atlanta, GA
    Quote Originally Posted by spidey9999 View Post
    I downloaded VCDS Version 15.7.0 today and was able to make some changes, but not others to my 2016 RS7 as follows:
    1) Disable amber corner lights
    Submodule 0
    This worked but there is no supporting text in the Long Coding Helper. Bit 3 was checked and I simply unchecked it
    2) Disable NAV & Phone warning messages while entering data at speed
    I was not able to do this. The choices in the Adaptation settings are way different than I have previously seen
    3) Enable Adaptive brake lights
    [46 - Comfort System] [Coding - 07] -> Long Coding Helper -> Byte 8
    Bit 0 – Emergency Brake Flashing via Turn Lights active (1 = active)
    Bit 1 – Emergency Brake Flashing via Brake Lights active (1 = active)
    The coding was accepted but I won't know if this worked until I have someone follow me (not too closely!) and then be in front of me
    4) Enable Automatic Gear selection shown in DIS
    [02 – Auto Trans] [Adaptation – 10]
    Select “Single Gear Display” from top channel drop down menu
    Select “D on/S on” from New value drop down menu
    The coding was accepted but I didn't drive the car today so won't know if it worked for a couple of days
    5) Set Audi parking system - Switch OFF Speed
    [10 - Park/Steer Assist] [Adaptation - 10] -> Channel 23
    Set to 20 (max value in km/h)
    I was not able to do this. Park/Steer Assist is no longer an available module
    6) Tail lights on with front DRLs
    [Select]
    [09-Cent. Elect.]
    [Coding - 07]
    [Long Coding Helper]
    Click on byte 2 and enable bit 7
    This worked for me but again there was no supporting text in the Long Coding Helper. I clicked bit 7 in byte 2. This also turned on the rear marker lights so I had to disable them as shown below.
    [Select]
    VCDS also showed me a security code of 22790 but I used 16017. My original codes for the left was 51201 and 51233 for the right
    8) Enable coming home/leaving home function DRL
    [Select]
    [09 Central electric]
    [Coding - 07]
    [Long coding helper]
    Click on byte 6 and disable bit 4
    Leaves the low beams off when unlocking the car and just have the DRLs on when its dark outside, similar to some other Audis. Much cleaner look.
    This worked for me, but again no supporting text in the Long Coding Helper
    9) Change the Adaptive Cruise Control Preset distance
    [Select]
    [13 Distance Regulation]
    [Adaptation - 10] --> channel 7
    Change from 0 to 1
    Reboot MMI
    Will now have an option in your MMI under Car --> Driver assistance --> Adaptive Cruise Control to set which of the 4 preset distances your car will default to when you activate your ACC.
    I now have the option in MMI and made a change.
    10) Turn off parking brake when in park mode
    [Select]
    [53-Parking Brake]
    [Adaptation - 10]
    Click the drop down channel menu
    Select the "Automatic parking brake for selector lever position P"
    Change to Not Activated
    This was already set to "Not Activated" in my car.
    11) Enable window closing with remote (opening is already an option in MMI)
    46 - Cent. Conv.
    Adaptation - 10
    Channel 62
    Change value from 8738 to 48059
    Test
    Save
    I did what CanuckRS did and added 1 to the existing value of 8738 and the close feature for the windows was now functional (but not the sunroof). VCDS showed adding 16 to the number would allow the closing of the sunroof with the remote and it did.
    I hope this helps you folks.
    I will appreciate any input as to how to make the 2 changes I was unable to do - Set Audi Parking System switch off speed and turn off the NAV warning message.
    Thanks.
    +1!!! I did the same thing and had the same outcomes!
  31. #911
    Established Member Two Rings neddy191's Avatar
    Dec 30 2014
    NC
    Im ordering the rosstech vcds soon. I have a c7.5. How do I disable the radio mute that happens every time I put the car in reverse?
    2016 S6 (Daytona Gray)
  32. #912
    Nov 05 2006
    Fair Lawn
    Quote Originally Posted by neddy191 View Post
    By going into your cars system volume settings/parking assist menu....no need for vagcom
  33. #913
    Feb 24 2011
    Derry, NH
    Tried for about 1/2 hour to find something in the channels that looks like it would work on someone's C7.5. No luck. I did it no problem on my old '13 C7.
    2016 Cardinal Red Mercedes Benz C63 AMG S
    2018 Navarro Blue Q5
    *HEX-USB+CAN VAG-COM Available for those in Northern MA/Southern NH: Will Mod for Beer!*
  34. #914
    Jun 05 2008
    Carmel, IN, USA
    I had no problem doing this on a 16 S7 as I did on my 14 S6. I think I used the AudiZine list though, so I'm not sure if it was the same instructions
  35. #915
    Mar 15 2016
    Seabrook(Houston), TX
    So I did this........
    ______________________________________
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    And nothing has changed! Or I'm missing something. How do you use remote operations? On my Infinitis its with the unlock on key pad. Also my chirp stop working when I lock car LOL HELP also any word on being the hack for Bluetooth music on C6???
  36. #916
    Veteran Member Three Rings Demandred's Avatar
    Jul 24 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    Hey guys - question on this
    Is there a way / code to enable the front camera so it will keep going at any speed ? You know put the parking sensor button and it will stay on until to switch it off ?
    Thought it would be cool to have the front driving camera being able to play at speed
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
  37. #917
    Jul 27 2013
    indianapolis/indiana
    [Select]
    this worked for me, after changing 209 hit test go look and then hit save
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    2016 RS7 Stage 2, Mythos Black Metallic, SRM/DS1
    2025 RS6 Daytona Grey Pearl, executive package, carbon package, alcantra package, soft close doors, B&O, res delete
  38. #918
    Jul 27 2013
    my issue is when trying to adjust the drl, i don't get channel 3 it show as turn signal dimming i believe
  39. #919
    Oct 09 2015
    Gold River, CA
    Quote Originally Posted by dab View Post
    Big difference depending on what model year.
    All of the initial instructions are based on Pre Facelift 2016.(C7)
    Many of the changes don't translate to Post Facelift.(C7.5)
  40. #920
    Jul 14 2016
    Denmark
    Lane Assist
    Hi,
    I was just playing a bit about with my VCDS on my facelift A6, and found a nifty setting that i haven't seen posted before.
    In Module 8E using the newest version of VCDS, you can actually adjust the lane assist a bit more. I found the following settings to be working:
    1. Change intensity of steering wheel vibration for lane assist
    There is actually setting besides whats in the MMI, so you can adapt this a bit.
    2. Change intensity of steering input for lane assist
    Works like a charm to change this one, though i actually prefer the medium setting, as high is pulling to hard and low makes me fear to crash :P
    3. Change driver inactive threshold for lane assist
    Great setting - factory is medium which by a totally Scientific method of counting in my head will pop the message and disable assist after approx. 10 sec. Low is a bit quicker to annoy with 8 sec. and high gives a bit more time with approx 12 sec. Just enough to not get the message all the time when driving straight ahead with both hands on th Wheel.
    4. Change sound for lane assist warning
    You can actually turn the chime of - og select an even more annoying gong sound.
    Perhaps we should get a new thread going for the C7.5? Since i can see many questing are repetitions about stuff you can do on the older models, and not on the facelift yet.
    I can see around the forums that you actually can make VIM and Green menu available on the facelift, you just need a VCP cable from http://vag-tech.eu/ since VCDS does not support this yet. There is also a older mod using a database injection through sd Card, that should Work.. but for now i'm waiting for the NeXT VCDS version.
