Originally Posted by
Nully
For those of you trying to get tethering working via USB, I did a guide a while back:
3G+ Tethering and Online services. The MR-3040 is a better choice than the 3020.
You also don't need to leave the router powered up all the time, once it caches the maps in your area and route you can power it off.
Hello Nully,
Ok. I have a few questions about your guide. If I understand you right you use you smartphone hotspot and then connect router to wi-fi of your phone (you configured router to wisp mode to enable that). Than you send 3G data through the trendnet USB to Ethernet cable and AMI usb cable to the MMI (which is set to the right gateway settings with the script in your guide), and you now got the online services working. Now if my understanding is right I have these two questions.
1. Why do you need to enable WI-FI in MMI, since you do not get any data via car wi-fi, but through AMI USB.
2. Now I am thinking if I could do this mod, with only use and Android phone and use USB teather and then connect the phone via usb cable to the AMI USB cable. Then enable all setting in green menu and I think that it should also work. what do you think?? This way I would get carging, internet and also functional car wi-fi.
