Page 11 of 38 FirstFirst ... 91011121321 ... LastLast
Results 401 to 440 of 1495
  1. #401
    May 14 2015
    Munchen
    Hello gars7,
    Just to inform you that I tried the feature and I set the timer and the ventilation works. I did everything that you described in your post and I also enebeled bit 3 and 4, that are described in my post #393. It is really great feature in these hot days
    And just one more maybe stupid question. Is it possible to code the aux. heater remote control? I do not know if it comunicate to some antenna on the real webasto or it comunicate with the car antenna (same as normal key). The cost of aux. remote is not so big, so it would be nice to have a remote to enable ventilation.
    What do you think about that?
  2. #402
    May 17 2015
    2004 S4 Avant, 2009 A4, 2014 RS7, 2017 A5 Sport
    Atlanta, GA USA
    Mojito:
    Glad to hear the process worked for you!
    I have not looked into requirements for coding a remote key with auxiliary heating/ventilation. My key fob does not have that capability, that is, it has no button for controlling auxiliary heating on the fob. It seems to me that there are two questions: (1) will Audi sell a key fob with the additional button and (2) will they code it?
    If Audi will sell and provision the key fob, then that is probably the best way to proceed, that way all buttons on the key fob will work appropriately, albeit at some expense!
    Instead, if your intention to source and provision an alternative remote control just for the auxiliary ventilation, then I defer to other readers of this thread - they can better advise you regarding what type of remote control to purchase, etc.
    __________________
    2017 A5 2dr Coupe Quattro Tiptronic Sepang Blue Pearl Effect Carbon Optics 2.0T TFSI Premium Sport
    2014 RS7 4dr Sportback Quattro Tiptronic Phantom Black Pearl Effect Carbon Optics 4.0L TFSI V8 Prestige
    2009 A4 4dr Sdn Quattro Tiptronic Phantom Black Pearl Effect 2.0T Premium Plus
    2004 S4 5dr Avant Quattro Tiptronic Light Silver Metallic 4.2L V8
  3. #403
    Senior Member Two Rings McFuzz's Avatar
    Jun 20 2014
    CA Bay Area
    I am still a bit confused on how the aux heating/ventilation feature works... I've tried setting it up on my '14 TDI but I had no additional menus or anything else available...
  4. #404
    May 17 2015
    Atlanta, GA USA
    McFuzz,
    The best explanation I have read of the Auxiliary Ventilation feature was (see below) at http://www.audienthusiasts.com/VagCom_AuxVent.html. Page 1 gives implementation directions (now a bit dated due to changes in the Engineering Menu, see research on this thread by Mojito and me). The second page gives usage directions.
    Last edited by gars7; 06-17-2015 at 04:15 AM. Reason: Removed note about audienthusiasts.com being down - the site is back up!
    __________________
  5. #405
    Dec 10 2012
    TN
    Anyone in the Nashville area with a Vag-Com?
    2012 A7 | Prestige | Phantom Black |
  6. #406
    May 14 2015
    Munchen
    McFuzz,
    I will try to write a little guide on how I eneble aux. ventilation on A6 and A7:
    1. You need to enable hidden menu on your car and you need VagCom to do it. you can enable hidden menu with this coding that you can also find it on the first page:
    Enable Hidden menu in MMI
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6
    change 0 to 1
    2. It is best to do a reset of the MMI (See picture) and after reset you need to open hidden menu. you need to press "MENU" and "CAR" at exactly the same time (this is a little bit tricky) for about 5-6 seconds. You will know that you pressed them at same time if there is no red light on the knob MENU and CAR when pressed. The hidden menu or so called green menu should start loading.
    3. Now you need to enable 2. things.
    Go to car/cardevicelist and find Auxiliary Heating. Enable it by pressing the big round MMI knob.
    Then go back to the main page of the green menu and go to car/carmenuoperation and find Auxiliary Heating line. Select it by pressing the big MMI knob and then set value to 5 by rotating the big MMI knob. Once again press the big MMI knob to conform selection and then exit the green menu by pressing CAR knob (or any other knob (MEDIA, RADIO, PHONE, ...).
    Once again reset MMI.
    4. Now you need to activate another 2 bits using VagCom and the procedure is also described on the first page, but I am posting it again:
    [08 - Auto HVAC] [Coding - 07] -> Long Coding Helper -> Byte 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    Now you need to press the CAR knob and then select Car systems (low left corner) and you should have new menu "Auxiliary Heater". In this menu you can set timers when you want to start ventilaton or how long do you want to keep ventilation on after you leave the car.
    I hope that is understandable guide. :)
  7. #407
    May 17 2015
    Atlanta, GA USA
    Mojito,
    This is a good, clear guide. I have two suggestions: (1) Post it in the tweaks section on the ross-tech site and (2) ask the moderator to make it a sticky here for ease of reference.
    Thanks again!
    __________________
  8. #408
    Senior Member Two Rings Laserrs's Avatar
    Oct 24 2014
    Cincinnati
    What exactly is the auxiliary ventilation and purpose?
    2014 A6 3.0t Prem Plus Ice Silver/Black 19" sport Vag Com
  9. #409
    Veteran Member Four Rings rayray's Avatar
    Sep 17 2010
    ‘19 S5/SB; ‘17 Q7
    Massachusetts
    Quote Originally Posted by Laserrs View Post
    It allows you to set a time when the car will automatically vent the car in hot weather.
    2019 S5 Sportback Prestige | Daytona Gray Pearl on Black | Black Optics | S Sport Pkg
    2017 Q7 3.0T Prestige | Ink Blue Metallic on Nougat Brown | Driver Assistance Pkg | 21"RS Wheels | Towing Pkg
  10. #410
    Jun 20 2014
    CA Bay Area
    Quote Originally Posted by Mojito View Post
    McFuzz,
    change 0 to 1
    Bit 3 – Set to 1
    Bit 4 – Set to 1
    Most excellent - thank you!
    I remember, vaguely, reading that the ventilation can be turned on automatically once the key is detected within range or car unlocked...? Is that true? Also is it possible to set up temperature thresholds as opposed to time?
    May 14 2015
    Munchen
    As I know you only have 2 options:
    1. You can only set 3 different timers, when do you want your car to be ready for departure and the time (10 min to 60 min) for how long do you want ventilation to work before departure time.
    2. You can set the vents for how long (10 min to 60 min) do you want them to work after you turn off your car. This is usefu when you go to some store or when you leave the car for a short period of time, so it stay cool when you return.
    You can not set temperature (as I know) and your car will just ventilate with the air form outside, so your car will not be very hot, but will be roundly so hot as outside air temperature. So in my opinion there is no point to set temperature, because you can not actually cool down your car like with climate control.
    Correction: I found in the manual, that you can set temperature. To be more specific, if you have a real aux. heater installed (which we do not, or we would have aux. heater menu enabeled by default), your car will warm up to the temperature that was last set on your climate control. For aux. ventilation there is no temperature set I think from the reasons I described above.
  12. #412
    Mar 19 2015
    Anyone with VAGCOM in CT? I'll bring the beer?
  13. #413
    Jun 20 2014
    CA Bay Area
    Thank you for the write up, Mojito! It worked flawlessly and actually cooled my car fairly nicely today considering it was 85F when I stepped out!
  14. #414
    Apr 11 2013
    UAE
    I sold My S7 and got a 2014 S8, What features can I unlock on it using the vagcom ?
  15. #415
    Sep 22 2013
    Norway
    Quote Originally Posted by S7_UAE View Post
    http://www.stemei.de/pages/coding/audi-a8-4h.php
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
  16. #416
    May 17 2015
    Atlanta, GA USA
    S7_UAE:
    See link below for A8-related tweaks from an AudiWorld forum. OP was Jack88.
    http://www.audiworld.com/forums/a8-s...ks-a8-2880792/
    __________________
  17. #417
    May 17 2015
    Atlanta, GA USA
    Battery Gauge in MMI
    I have a 2014 RS7 (North American) and am having difficulty enabling the battery gauge in the MMI.
    I have checked the relevant Engineering Menu items in the /car/carextdevicelist and /car/carmenuoperation screens and rebooted the MMI. However, no entry for the battery gauge appears under the Car Systems MMI menu.
    I have made no VCDS entries regarding this functionality.
    Are others having the same issue? What have I missed?
    Suggestions gratefully received!
    __________________
  18. #418
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Added a DIY for those with e-codes to get rid of the bulb out error:
    http://www.audizine.com/forum/showth...LED-Headlights
    The new step that isn't in this thread is step 6!
    2013 S6 | 2006 S4 widebody | 2014 Q7
  19. #419
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Anyone try getting the battery meter to work. Went into hidden menu and enabled but can't see where to set it up through vcds. Any suggestions? The one on the b8 platform gives an error when going to the channel it suggests.
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
  20. #420
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by 13allroad View Post
    Where did you find it in the hidden menu? Do you have a link to the B8 guide? Might be able to use that to find where it would be for the C7 A6 platform.
  21. #421
    Sep 02 2005
    Montreal
    Anyone know how to disable the taillight side marker bulbs? I got the front amber side marker bulbs turned off, but the rear ones are still on, and totally spoil the look of the A6 facelift tails.
  22. #422
    Sep 02 2005
    Montreal
    n/m I figured it out on my own;
    To disable the tail light side marker bulbs on post-facelift A6/S6:
    Central Convenience
    Security code: 16017
    Adaptations
    Enter Channel 207
    Change value to 0 (my stock value was 51201)
    Enter Channel 208
    Change value to 0 (my stock value was 51233)
  23. #423
    Mar 18 2011
    Denver
    Brilliant! Thanks, Rene.
  24. #424
    Jan 20 2010
    Central Convenience
    Adaptations
    Enter Channel 207
    Enter Channel 208
    Do u mind posting before and after pics?
  25. #425
    Senior Member Three Rings Liquidsystm's Avatar
    Apr 30 2012
    SF/CA
    Central Convenience
    Adaptations
    Enter Channel 207
    Enter Channel 208
    would you happen to know how to disable front and rear side markers on a S7?
    14' S7
    Phantom Black Pearl | 21x10.5 ADV.1 Wheels ADV10 M.V2 CS | APR Stage 1 | AWE V2 S-FLO Carbon Air Intake | Milltek Non-Res Exhaust | Airmatic Lowering Links | Eurocode Stabilizer Bars | SPC Control Arms | Flat Bottom Wheel | Black Optics | Carbon Inlay | Xpel
    19' AMG C63 Coupe
    Obsidian Black Metallic | AMG Sports Exhaust | Night Package
    IG: gaberoonie
  26. #426
    Dec 20 2006
    CAN
    anyone know how to remove the passenger airbag warning from the DIS when the car is started?
    i think this is new for the 2016 models because my 2014 never did this. there is a module for airbag in vcds but most of it has to do with "igniters" and i'm not going to monkey around with those but the one adaptation in there deals with either activating or blocking but doesn't seem to help, actually gives a warning if changed from factory status.
    emilyPay.com - Payment Processing for Professionals
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Headliner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
  27. #427
    May 17 2015
    Atlanta, GA USA
    enigma1406:
    I have a 2014 NAR RS7 C7 and was attempting the same tweak. I checked on the Ross-Tech site (I am a VCDS user) with the following thread:
    http://forums.ross-tech.com/showthread.php?3256-RS7-MMI-Battery-Gauge&p=33353#post33353
    I received a reply from vlarsen:
    "The Battery meter is no longer available - if you want the meter, you need to buy an older model - and this can not be one from the A7/S7/RS7 range."
    You may encounter the same difficulty.
    I wish I had more optimistic information to convey.
    __________________
  28. #428
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Unless there is an explorer on the forum who can comb through the settings via vag com on their computer not sure where it is to enable the meter. Under hidden menu its fairly simple, enable and change setting to 5 but no idea where to change in vehicle settings byte.
    Old:
  29. #429
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by gars7 View Post
    enigma1406:
    That is unfortunate
  30. #430
    Dec 20 2006
    CAN
    Central Convenience
    Adaptations
    Enter Channel 207
    Enter Channel 208
    FYI the coding to disable red tail light markers for a 2016 RS7 is the same but the channels are 209/210
  31. #431
    May 14 2015
    Munchen
    Hello guys,
    I found on the other forum another great feature for all the cars that do not have audi connect and google maps installed and I think that was not posted yet here. You can eneble WI-FI via hidden menu (how to enable hidden menu is described in first post of this thread). After that you will get new media source (when you are in MEDIA menu you press source - right upper button and you will have new wi-fi source on the list) you will also have new menu in telephone for wi-fi settings. With this enebeled, you can use audi stream music app on your android phone or iPhone. Now what I am trying to find out is if I can use Wi-FI as a client. with that I could use my phone as a hot-spot and share 3G data with the car. This way I could probabbly use google maps in my car. I know that you can do this on the new VW platform (Golf 7, new Passat) and if this setting can be set on all devices (home computers, phones, ...) I do not see the reason why this wouldl not work in the Audi. I found a guide where you can eneble google maps with AMI+AMI USB cable+router+Ethernet cable+script for MMI... but I do not want to do that hack, because there is to much cable involved and I do not like hacking MMI with unofficial scripts. :) How to enable WI-FI in hidden menu:
    1. /diagnose/settings/WLAN_Settings enable WLAN Activation
    2. /diagnose/settings/tel_settings enable NAD activation and NAD operation mode
    Any suggestions how to use wi-fi as a client?
  32. #432
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    Anyway to have the MMI show the individual tire pressures? 2016 s6
    Thanks
    2016 Daytona Gray S6 w/ Arras Red Designer Interior, Sport Package, Black Optics, Bang and Olufson, Driver Assist, Night Vision, and Cold Weather.
  33. #433
    Veteran Member Three Rings spidey9999's Avatar
    Oct 19 2006
    Hello guys,
    Thank you for posting this. I have a facelift Canadian model so I don't have the SIM card slot plus likely most of the background hardware/firmware so am very interested in using my phone as a Wi-Fi hotspot. However, when playing around with the Media Source function I found this:
    and then clicking on Settings showed this:
    Anyway, I am lost when it comes to this stuff (and VCDS 15.6.1 Beta doesn't appear quite ready for prime time yet) so I haven't attempted any changes.
    Any help will be appreciated. Thanks.
  34. #434
    May 14 2015
    Munchen
    Hello Spidey9999,
    Did you enable wi-fi using my guide with hidden menu or you already have wi-fi enabled from factory?? Only with wi-fi you can not do much (you can only stream online or local music from your phone or tablet with the Audi Connect Music Stream App, that you can find on android market or app store from apple. As you I am also trying to find a way how to send 3G data to the car, so that I could then enable Google Maps in the car MMI. You could only do that if you could set the car wi-fi setting to be a client. That way you could set your phone as a hotspot and then connect your car to your phone having internet connection (but in this way you could not connect other devices to the car wi-fi), but that is not an option in the car settings so no internet with the hotspot. I am looking for solution, where I could retrofit a SIM card feature to my car.
    Now I am asking if someone have installed a car phone (inside the armrest of the car) if they can use google maps and other online services, because in the car phone you must enter SIM card. Just thinking! :)
  35. #435
    Veteran Member Three Rings Demandred's Avatar
    Jul 24 2011
    2016 Merc CLA250 Shooting Brake
    Auckland, New Zealand
    I have the issue on my S6 where I have the sim card slot for google maps - but my cell provider won't / says they can't issue me with a extra sim card that is tied to the same number as my actual cell phone - so if i stick in an extra sim card - i can get data and google maps going but it then boots my cell phone off so i dont get mobile calls through the car via bluetooth.
    just crazy that you cant link the car to use your mobile data as a hotspot for things like google maps etc! if someone can find a work around for that it would be awesome
    Now : 2018 Mercedes E63S
    Previous: 2017 Audi RS6 Performance Avant....Too many other Audis
  36. #436
    Sep 22 2013
    Norway
    http://shop.ontika.net/product_info....lqfi4o0gdi66e6
    This shows that it can be done, should not be different from a phone with internet sharing.
  37. #437
    May 14 2015
    Munchen
    Yes it can be done, with additional hardware but we are looking for a solution, how to change car built in wi-fi from hotspot mode, to client mode. I do not like additional hardware in my car that must be plug on 12V charger the whole time. :)
  38. #438
    Dec 20 2006
    CAN
    someone should try this...
    audirevolution dot net/forum/index.php?topic=2443.0
    link doesn't work if inserted, looks like the mods don't like links to other audi sites... :)
  39. #439
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by CanuckRS View Post
    AR just doesn't let anyone direct link to their site since they are God's great gift to the Audi world
    Anyways, reading that now...
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
  40. #440
    Mar 14 2012
    PHL | BOS | SEA
    I have no idea how to run scripts on the MMI, can someone enlighten me there?
    But on the harware front,
    I'm wondering if it's possible to use the following (#2 below) and not have to have a separate USB hub...
    1.) AMI to Female USB (not sure why it says Mercedes yet sticker has Audi rings)
    2.) TRENDnet USB 3.0 to Gigabit Adapter + USB Hub TU3-ETGH
    3.) TP-LINK TL-MR3020 3G/4G Wireless N150 Portable Router, AP/WISP/Router Mode
    2014 S6 - SOLD
