Quote Originally Posted by Spectre1130 View Post
If you want cheap China rods go CXRacing.com. If you want quality stuff, 034 Motorsport carries SCAT rods which alot of people have recommended. With the 058 motor you should have 20mm wrist pins. I think the AWM (06A) is when they switched to 19mm. So you should be looking at rods that are 144mm x 20mm.
034 - https://store.034motorsport.com/rod-...pin-4-cyl.html
CXRacing - http://www.cxracing.com/mm5/merchant...tegory_Code=B5
Thanks for the reply and info! and ye for something serious as internals i will dump money carelessly to get it done right and so forth so no china rod heres lol scat rods are only 400 shipped not too bad at all!
