Page 1 of 6 123 ... LastLast
Results 1 to 40 of 216
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    APR v2.2 occasionally going into limp mode
    My car was bench flashed in April with stock, 91,93 and 100 program after being V1 91 forever.
    ECU would not accept the write program for ODB flashing...for whatever reason I was told it was a rare "Canadian" thing.
    Anyways...my car will sometimes (20% of time) go limp after first start in am. Normal ignition, back out in reverse from my driveway and then bogs on the road after engaging 1st gear and trying to take rpms past 1000.
    I have to then turn off ignition and restart at which time all operates as normal. It has never happened under other driving circumstances.
    Not sure if its the anti-theft lockout kickin, as its clearly seems to be a software issue. I did just reenter my security code tonight to check
    Or something to do with the cold start feature being deactivated as its seems more likely to occur after a cooler or rainy night.
    Thoughts or experience anyone?
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    EPC light come on during this?
    Senior Member Four Rings The_Transporter's Avatar
    Jul 04 2012
    United States of America
    DSG issue possibly, and not tune?
    All-Black C6.5 A6 3.0T Premium-Plus
    APR Stage 2+
    APR Pulley
    SST 'True' Cold air Intake
    SST Quad-tip Exhaust
    S.T. adjustable Coilovers
    H&R Sway
    EBC dimpled & slotted Rotors
    Exterior Mods:CarbonFiber mirrors, S6 Door Blades, RS6 grill, KimmelEyelids,S6 valance
    20x8.5" O.Z. Ultraleggera HLT's 255/30/20
    Jun 13 2009
    Quote Originally Posted by apexit1 View Post
    EPC light does come on....then goes off after restart.
    Im 6MT.
    2023 Q5 2.0 Technik
    Jul 04 2012
    Quote Originally Posted by adbender View Post
    Im 6MT.
    Oh sorry :( if it's in your sig I couldn't see it. On Tapatalk app
    APR Stage 2+
    APR Pulley
    H&R Sway
    Jun 13 2009
    Quote Originally Posted by The_Transporter View Post
    No worries, its strange...
    I may have mucked around with the security lockout when i first tried program switching and possibly activated anti-theft.
    When the car was adapting...my A/C stopped working and ADS would not switch between modes from the button for 4 days then spontaneously resolved.
    I dont know if I have a funny ECU batch as apparently I can only be bench flashed as well. Just a pain but the car runs like a champ otherwise.
    I just did a security code reset to see what happens.
    2023 Q5 2.0 Technik
    Jun 04 2010
    northern nj
    DO you notice it more in the cold? I get an EPC Light on cold starts and it goes away 99%of the time with a restart. I took it to a shop last spring who took it to a dealer. Dealer said to replace the ECU so the shop had me get in touch with APR. Tech I spoke with said they had seen it before and it should go away replacing a certain engine wiring harness, informed my shop and they said the engine has 1 harness and can't be taken apart. No fix I've found yet.
    Jun 13 2009
    That my situation apexit1...seems like a cold start issue. Come the think of it, it usually happens when im in a rush in the morning and start the car and immediately go.
    Will try and give it a little more time to warm up and wait for a fix.
    2023 Q5 2.0 Technik
    Veteran Member Three Rings S4charged's Avatar
    Oct 11 2012
    West Covina, CA
    Apr stage 2 here. I also get this issue sometimes on a cold start. A simple restart fixes it. I let it warm up a little after I restart it. Giving it gas right away after you turn on the car usually causes this more.
    Ibis White - 6MT
    APR Stage 2+ / Eurocode Headers / End Links / Sway Bars / Alu Kruez / Short Shifter /
    Milltek RESONATED. Carbon Tips / Stratmosphere Intake / H&R SS / RS4 Grill / VAG Mods --- SOLD
    2016 Prius 4
    2018 RS3 Nardo Grey - Dynamic Plus / Technology / RS Design / Black optics / Carbon Inlays - APR Stage 1
    Aug 05 2013
    N/A
    OK, so here's a question. If APR is one "not to mess with factory behavior or safety standards built into the ECU" why did they see fit to disable the cold start routine on ver 2.2? If this is possibly due to that, why disable and cause headaches for a bunch of people?
    Senior Member Four Rings riseabv's Avatar
    Sep 04 2013
    2010 Mercedes C350
    Southwest
    Yeah why?
    14 s4 glacier white | b&o | carbon atlas | h&r OE | SPC uca's | 19x9.5 Stance SC6 | Hoen fogs | 15% Pinnacle Tint | Roc-Euro | Magnaflow exhaust | Special Goodies ...
    Account Terminated Four Rings
    Mar 08 2010
    San Francisco, CA
    It could be your DSG overheating.
    Established Member Two Rings AndrewSuliteanu's Avatar
    May 15 2013
    United States
    Seems like a deterrent from getting a tune... I would go thoroughly frustrated/worried if this was happening to me 1 out of 5 times I get in my car
    Jun 04 2010
    northern nj
    In the cold i get it nearly everyday usually more than just once a day...
    Veteran Member Four Rings schirm's Avatar
    Apr 23 2009
    1999 bmw z3coup M with 5,000 miles Mint
    Forked River nj
    Interesting, I wonder if this will start happening to me,
    2004 A4 1.8t | Avant | 6MT | Stock | Atlas gray |
    2010 S4 | Ice Silver Metallic | Sport Diff | 6 speed | 19 5-Tri-Spoke Wheels | Audi Drive Select | B&O | Silver/Black Nappa Sport Seats | Navigation Pkg | Brushed Aluminum Trim | APR Stage 2+ | Hoen Xenonmatch Fogs | 034 Motor mounts | Roc Euro | black RS4 Grille |
    Past
    2007 A4 | Revo Sg 2+
    2005 Subaru Legacy GT 365WHP
    Jun 04 2010
    northern nj
    It is getting worse, used to be every few days and now I sometimes have to turn it off twice. This is of course in colder weather, only happened once this season so far
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
    Veteran Member Four Rings integroid's Avatar
    Mar 01 2013
    Atlanta, GA
    Have you tried contacting APR? I am on v2.2 and have never had this problem and I typically start and go with my car.
    2024 RS3 Kemora Gray
    Feb 25 2013
    MI
    Will follow this thread, am planning to go stg2 sometime after winter.
    Jun 13 2009
    Quote Originally Posted by integroid View Post
    I should. I anticipate they will suggest a reflash which means a trip to the shop during a crazy fall.
    Will keep u posted.
    2023 Q5 2.0 Technik
    Apr 17 2004
    Socal
    on 2.1 there was behavior that would kick the car into "limp" and at times even result in the car basically being in neutral even though the gear shift was in D or +/- sport mode. This only seemed to happen in cold weather. v2.2 eliminated cold start and the problem disappeared. Guessing it was an anomaly with cold start and getting rid of it eliminated the potential for the problem to happen?
    I would have the car reflashed to stock stock.. drive it for a week and see if the behavior comes back. If not then something is odd with the tune/car combination. Get it reflashed to 2.2 and see if it comes back.
    Veteran Member Four Rings helix139's Avatar
    Apr 21 2010
    Florida
    Quote Originally Posted by SwankPeRFection View Post
    What headaches are you referring to, and how do you know this is related to cold start? All cold start does is run higher RPMs on start and heat the cats for emissions. It's not an OEM component protection safeguard such as (for example) knock sensitivity, overboost, underboost protection, etc. This sounds like something else entirely, and we don't really know if it's tune-related.
    To the OP, try PMing Arin or calling up APR. I'm sure they'll take care of you. Also, have you tried using VCDS to pull codes? That could be revealing.
    2011 S4 Premium Plus 6MT, Sepang Blue Pearl, Black Silk Nappa, Sport Diff, B&O, B8.5 MMI 3G+ Nav, Ti Pkg
    APR Stage 2+ Stock/93/100/Valet, Eurocode Alu Kreuz, Eurocode USS Sways + End Links, Eurocode Meisterwerk SSK, Roc Euro Intake, Apikol Rear Diff Mount, Fast Intentions Exhaust, Escort 9500xi, Laser Interceptor, P3 Vent Gauge, VCDS
    Aug 05 2013
    N/A
    Quote Originally Posted by helix139 View Post
    That's exactly my point. I know what it does smarty pants, I'm not like every other idiot in this thread spouting off that it's a DSG issue when the OP's car is MT.
    However, cold start routines are there for a reason and the ECU does some fact checking each and every time to make sure everything is working properly, especially for emissions. If there is a problem and the ECU doesn't see the expected result, it could drop it into limp mode for the hell of it. Unless we know specifically what the specific problem list is for the ECU to kick into limp mode is, one could easily say a bad cat or bad O2 sensor could cause the same issue. If the cold start routine is taken away, this very well could happen. Problem why some aren't seeing it could be where they are geographically. APR is in Alabama. The guy with no issues is in Atlanta. Other's in Florida, etc. The cold start routine isn't that big a deal in a hotter climate, but in boonville cold frigid hell, it could cause issues. APR has no business playing with these basic startup and diagnostic routines no more than REVO playing with other things that APR blamed them for. Yes, I'm playing the finger pointing ha ha game here, but I do have a legitimate case. I also have personal experience with how picky an ECU can be when you have an O2 sensor issue. On a previous car, I had a sensor with a slow heater element in it. If the car was started cold and the revs weren't held a bit high to speed up the heating, the ECU would trip a code. If the car was restarted after it was up to temp, it would be fine without having to help with the additional exhaust heat generated by a higher idle. Also, a higher idle during cold conditions also serves to move oil through the engine at a higher flow rate than dead idle at 600 RPM. When an engine is cold, the oil needs a bit more help to circulate better, the additional RPMs from the cold start routine helps with this as well.
    Bottom line, there's no reason to dick with this capability. The thought that they're saving you from the dreaded carbon buildup headache is not enough of a reason in my book.
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    You are wrong.
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    Veteran Member Three Rings Luna's S4's Avatar
    May 22 2013
    Cannondale, two Orbeas & a Trek
    Northern Cal
    Quote Originally Posted by westwest888 View Post
    But it's a cold start.
    2011 S4 DSG Prestige w/ Revo! Bilstein B16 PSS10! H&R RSB! AP Racing BBK! Michelin PSS!
    Aug 23 2008
    Auburn, AL
    If you are getting a light on the dash, pull the fault codes and post them. Otherwise we are really shooting in the dark.
    Aug 05 2013
    N/A
    Quote Originally Posted by Arin@APR View Post
    You are wrong.
    What you should be doing is not messing with the cold start routine. There's nothing wrong with it. Leave it the f* alone! Either that or give people the choice of wanting it left alone or not. There are some people out there that don't want anything else out of the flash except the power left on the table by Audi unlocked and nothing more.
    Also, how do you explain all these people having this issue. There's what?... 3 or 4 in this thread alone. I guess they all have "other" issues with their cars tho, right?
    And what's up with the OP's ECU only being able to be bench flashed? Care to explain that one or is it all super top secret that mare community mortals cannot know.
    Aug 23 2008
    Auburn, AL
    Swank, you are strange.
    Anyone with real issues feel free to contact us and we will help. Thank you.
    Veteran Member Four Rings Ynnekdude's Avatar
    Dec 10 2008
    Chicago
    You're such a rebel, Swank.
    2009 A6 3.0T Sedan w/19" Sport Pkg. Phantom Black.
    JHM 93 Stage II. STaSIS Exhaust. SST Intake. JHM HX. Stoptech ST-60. KW V1s. H&R Sways
    Jun 13 2009
    Sure thing....will run a scan on the weekend.
    2023 Q5 2.0 Technik
    Veteran Member Four Rings PaperishPlastic's Avatar
    May 13 2007
    Rats
    San Fernando Valley
    WTF are you talking about? This has been addressed before in a previous thread but you rather try to start shit. With people instead of using the search button that located on the top right of the forums.
    B8 Signal Green
    Jun 04 2010
    northern nj
    I'll check my email to see if I have scans. I've cleared the codes since then.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    You are wrong.
    simple yet effective
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Aug 05 2013
    N/A
    Quote Originally Posted by PaperishPlastic View Post
    Really... Repetitive limp mode with APR 2.2 has been covered before? Maybe the OP's at fault for not searching either. What amazes me is that the people that posted in here having this issue, have just kinda overlooked it up until now it seems. Why would someone just "deal with it" day in and day out?
    Also, I don't wanna hear all this "just call us and we'll take care of it" deal. I want to know why this is happening with more than just the OP because if someone was to get an APR flash, I'm sure they don't want the chance of this happening being in the back of their minds if it truly is linked to the 2.2 flash and nothing else. APR telling people to call in and they'll deal with it without documenting the issue here is hiding the cause/fix of the issue. The OP made a correlation that this issue started for them after the 2.2 update. Are they right, are they wrong? We don't know yet, but I want to get to the bottom of it and want to know exactly what it is. That said, I also don't believe that APR should be messing with the cold start routing on the car. I want a flash, but now have to rule out APR because they don't want to put an OTS flash that doesn't have this change in it. I most certainly don't want to flash my car with a product that's going to cause CEL issues time and time again. Last car I had was flashed at 10k miles and was CEL free all the way up to 130k miles. That's what I want, not viagra needing limp mode day in and day out cuz it's a bit cold outside.
    Jun 04 2010
    northern nj
    It's not a cel, its the EPC light. Search my history and you'll see that I've tried solving this before. Like I mentioned before I've even taken it to a shop.
    I found my thread over on AR. Arin please take a look
    http://audirevolution.net/forum/inde...39975#msg39975
    Dec 10 2008
    Chicago
    Are you seriously going to say that? There are several variables that can cause issues like this. Why would APR attempt to diagnose the issue via forum post instead of actually speaking with the customer on the phone? If anything, as a paying customer, I would be insulted if a company did not offer to speak on the phone.
    I'm sure OP/Arin will come back and update everyone once the issue is resolved.
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    hmmm just noticed that you and the OP both have 2010s (I assume) wonder if its minor ecu difference for that MY, I have no idea
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Aug 05 2013
    N/A
    It's a CEL, don't sugar coat it. Same thing. Also, I don't see anything in those last few posts in that thread that say it solved your issue or that it was something completely different. The dealer was poking fingers around. If you still have this issue, then get flashed back to factory stock and see what happens. If the problem is elsewhere, then it'll continue. As long as the ECM wasn't damaged or somehow corrupted during the flash process, returning to a factory flash should solve the issue if it really is the APR tune or the changed ECM logic they incorporate into their tunes.
    Aug 05 2013
    N/A
    Quote Originally Posted by Ynnekdude View Post
    I'm not saying they should diagnose it via this thread, but you know how things end up dying off as they get resolved and no one bothers to come back and say anything. Heck, up until the OP and a few others mentioned it in here, I had no idea that there "could" be a small chance or correlation between getting an APR tune and possibly running into these kinds of issues. I'm sure there's hundreds of people out there CEL free and tuned by APR, but if there's even 1 that had issues, people would probably want to know about it... no?
    Mar 01 2013
    Atlanta, GA
    Swank - you should probably take a Xanax before before getting on this board. Seems like you are always high strung and think everyone is out to get you.
    I believe paper was talking about why the cold start got eliminated.
    I dont understand what you want APR to do? try to help the customer over a forum that could take days instead of having the customer call them which could take minutes to fix?
    I believe this was bench flashed because he had it done prior to the port flashing being available. He gives the date above in the OP.
    Aug 23 2008
    Auburn, AL
    Perfect. I'll be glad to help. Thank you! : )
