Originally Posted by
Stereodude
So why does the SQ5 reportedly have a different block (stiffer) and different camshaft instead of just a software tune?
This is not correct.
The SQ5 has the CTX / CTU engine code.
The camshafts are as follows:
06E 109 101 BG - Inlet 1-3
06E 109 101 BH - Inlet 4-6
06E 109 102 BG - Outlet 4-6
06E 109 102 BF - Outlet 1-3
These cams are found in the A4, S4, A5, S5, Q5, A6, A7, Q7, A8 and Touareg. They first appeared in 2010 and they are even installed on the low output CTVA Q5 engine.
The CTU engine code is found on the following models:
A6, A7, A8, A8L, S4, S5 and Q5
There are several variations through ECU software only:
A - 310 HP
B - 333 HP
C - 272 HP
D - 354 HP
SwankPeRFection
Cool thanks. I'd be interested more in knowing if Audi made the crank and cam shaft changes to change the stroke of the motor to give it more torque lower (for towing, etc.) Also, the block difference would have come due to either that bore/stroke change and possibly also to allow for that 8 speed trans to bold up if the trans is different than the one in the normal Q5 (could be a different bell housing/bolt pattern).
The the pistons, Crankshaft and Rods are all the same, and were available back in 2008. The bore and stroke has not changed.
