Hey member's new to the forum but have gotten some good information prior to actual becoming a member. Here is what I need help with and I did do a search as I didn't want to waste anyone's time but didn't find exactly what I was looking for. I recently picked up an 2001 A6 4.2 and I seem to be having the common problem that C6 A6 owners get where you put on the A/C on and if you change the temp from cold to the middle or anything like that you get cold air from the middle vents but hot air from the side vents closer to the window. Based on what I found online it sounds like the heater control valve. My question is does the same apply for C5 A6's and if so where exactly is it located does anyone have a picture of where this is located?
Thanks in advance for any replies
