VCDS-Lite Version: Release 1.2
Friday, 13 September 2013, 17:41:34:64184
Chassis Type: 8E - Audi A4 B6
Scan: 01,02,03,08,09,0F,11,15,16,17,18,36,37,45,46,55,56 ,57,65,67,69,75,76,77
Address 01: Engine Labels: Redir Fail!
Controller: 8E0 909 518 AF
Component: 1.8L R4/5VT G 0002
Coding: 0016751
Shop #: WSC 63351
VCID: 749BA56B57A3
2 Faults Found:
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal
16840 - EVAP System: Very Small Leak Detected
P0456 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Controller: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04277
Shop #: WSC 06435
VCID: 2D2D700FF409
1 Fault Found:
01424 - Yaw Rate Sensor (G202); Reference Wire
57-00 - Electric Circuit Failure
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Controller: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11788
Shop #: WSC 63351
VCID: 7297A3732DB7
5 Faults Found:
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-10 - Faulty - Intermittent
01560 - Passenger Door
59-10 - Can't Unlock - Intermittent
01561 - Left Rear Door
01562 - Right Rear Door
Do you think this has to do with my driver side door wire harness?
