Page 4 of 20 FirstFirst ... 2345614 ... LastLast
Results 121 to 160 of 788
  1. #121
    Stage 2 Banner Advertiser Four Rings Christian@enfig's Avatar
    Jul 12 2004
    2013 CC Executive Edition VR6 3.6, 2003 GLI VR6, 2005 A4 cab 3.0 V6, 01 GTI VR6. Past 89 & 78 Golf
    Carlstadt, NJ (outside of NYC)
    Quote Originally Posted by jcm15 View Post
    Looking at what I would need if I decide to get this car and put my stereo I just got in it:
    2004 Allroad
    Symphony w/Bose
    Yes on steering wheel controls
    Kenwood DDX371
    No Sirius
    http://enfigcarstereo.com/ENFIG_SRWH_AUD2_HILO.html
    http://enfigcarstereo.com/ENFIG_AAA_VWAUD2.html
    http://enfigcarstereo.com/ENFIG_RMK8_A4B67.html
    http://enfigcarstereo.com/ENFIG_PNP_KEN0016.html
    http://enfigcarstereo.com/ENFIG_SWCL_KEN.html
    http://enfigcarstereo.com/86_9001.html x2
    EnfigCarStereo.com - Audi Car Audio Integration Specialists
    ☎201-490-5015 - Instagram - Facebook - [email protected]
    Want to make some money while posting? Join our affiliate program.
  2. #122
    Jun 25 2014
    Tennessee
    Cheapest way to add MP3 to OEM care audio
    1. Year and model of car: 2003 TT convertible
    2. What radio did the car come with from the factory. (It doesn't matter if you have Bose): AM/FM/CD with external CD changer (wasn't with the car when I bought it)
    3.Does the car have steering wheel controls? No
    4 What is the brand and model number of your new radio? I don't know. Where do I look? It's the stock radio that came with the car
    5. Are you going to be using a Sirius XM satellite tuner if yes which one? No
    I just want a cheap way to hook up my andriod phone and play MP3 music (not iPhone) but not using one of those blue tooth things you tune to a radio frequency. They don't work.
  3. #123
    Jul 03 2014
    towanda, pa
    1. 2003 A4 Cabriolet
    2. Symphony
    3. No steering wheel controls
    4. Pioneer FH-X700BT
    5. No sat.
    Jul 12 2004
    Quote Originally Posted by nwr1cxo View Post
    This is for radio replacement. Email me [email protected]
  5. #125
    Jul 12 2004
  6. #126
    Jul 12 2004
    2004 Allroad
    Symphony w/Bose
    Kenwood DDX371
    No Sirius
  7. #127
    Nov 08 2013
    United States
    2006 Audi S4
    RNSe with Bose
    Has steering wheel controls
    Pioneer Avic Z150BH
    No satellite radio
  8. #128
    Jul 12 2004
  9. #129
    Nov 08 2013
    United States
    Thanks. The google document you have linked on your website says PNP-PIO0236 for the Z150BH (which is apparently different pinout then Z140BH). So I am assuming I should use:
    http://enfigcarstereo.com/ENFIG_PNP_PIO0236.html
    instead of the one you linked?
    And just to verify, the SRWH-AUD3-HILO works with BOSE?
  10. #130
    Jul 12 2004
    Quote Originally Posted by MS3ToS4 View Post
    Sorry my brain thought Z130 You are correct. PNP-PIO0236. And yes it works with bose.
  11. #131
    Nov 08 2013
    United States
    Quote Originally Posted by Christian@enfig View Post
    No problem, the links definitely helped. I just like to double check.
  12. #132
    Jun 25 2014
    Tennessee
    Looking for Recommendation for replacement HU
    Hi,
    looking for something that will replace the HU that has MP3 input (note: Not iPhone / iPOD)
    1. 2003 TT convertible
    2. Factory installed Bose Concert with 6 CD Magazine behind driver's seat
    3. It has some type of steering wheel controls but I'm not sure if they are for the audio system. Just a + / - rocker toggle switch on each side of the wheel. I've tried them but they don't do anything.
    4 What is the brand and model number of your new radio? I am looking for an entry level recommendation. I just want to swap it out with something that has an MP3 input but utilizes the rest of the stuff that is already there.
    5. No Sirius XM satellite
  13. #133
    Jul 12 2004
    Hi,
    This will pit most pioneer entry level radios. Once you pick one let me know and we can also get you the radio. The 4600is a popular one.
    http://www.pioneerelectronics.com/PU...eivers.Compare
    http://enfigcarstereo.com/ENFIG_RMK2_TT.html
    http://enfigcarstereo.com/ENFIG_PNP_PIO01232.html
  14. #134
    Jun 25 2014
    Tennessee
    Thank you for your response. I think at this point, I'm going to just get one of those adapters that hooks to the CD Magazine cable and give you a 3.5 mm male adapter for input.
  15. #135
    Junior Member One Ring
    Jul 15 2013
    F800GS, 996 Carrera S, RS4(track only)
    Washington, CT
    Audi radios put out probably somewhere between 10-12V to the amp. Most aftermarket radios are 2-4 Volts. Without the HILO the sound is low on the rear of all A4's and also low on the front of Bose equipped cars.
    Christian - I wrote you an email. But I will ask it here for others to see as well.
    1) You used to sell the Enfig SRWH-AUD2-B plus the Enfig RWH-AUD2-HILO - this works off of the Aftermarket HU RCA preamp outputs. Assuming a Bose system where the preamps were 10+v on the Symphany II/ is this AUD2-HILO increasing the output form 4v to 10v? If you have non-bose how is this going to make front (non-amplified speakers) the same as rear unless ALL are lowered. . .(doesn't apply for me as mine are Bose front and back, just asking).
    2) More important question - The new Enfig SRWH-AUD2-HILO you sell to combine both of the above is nice. But this does not use the new HU RCA preamp outputs ..... it goes off of the speaker level outputs. Why did you decide to use the speaker level vs the preamp outputs?? Are these higher than 10v and you are then using the HiLo to lower them down? Or are they lower and then are being boosted to 10v?
    I am confused as to why one system was one way and then you switched to a different way on the updated harness.
    Thank you
  16. #136
    Jul 12 2004
    Quote Originally Posted by ultrasport3.0 View Post
    Thank you
    1. It never used the RCA preouts. Always brought down speaker output to a higher preout than aftermarket radios. The RCA's are there because it is a universal add on for customers that did not buy their initial installation products from us.
    2. The only reason we switched out setup is becasue it used to cost you an extra $100 to add the hilo. Now since its one part its only an extra $25.
  17. #137
    Jul 15 2013
    Washington, CT
    Ahh.
    I was mistaken. My apologies. I saw the RCAs on one harness and not the other and assumed your old setup was taking aftermarket Preamp outputs and then sending them off through the factory 'preamp' wires. Looks like what it was doing is taking the speaker level output, converting and then sending it to the factory preamp output wires. I was confused as there were RCAs attached. Guess this is a 'option' for people to send RCA to aftermarket amps. Which only makes sense if someone bought a aftermarket stereo with out RCAs. . ....
    So this means that with the ENFIG_SRWH_AUD2_HILO if I want to run this to aftermarket amps vs the factory Bose Amps I need to purchase Female RCAs with the bullet style connectors on one end? Or... if they are aftermarket amps Id simply not have the problem and be okay with the aftermarket HU's 4v preamp outputs... Got it . .
  18. #138
    Jul 12 2004
    We could also sell you a harness for $30 if you want to use aftermarket amps down the line. The small box is the same.
  19. #139
    Jul 26 2014
    Iquique, Chile
    1. 2006 Audi A3
    2. Symphony II -the one with cassette player, in dash cd changer, Bose.
    3. Yes
    4. Pionner AVH-P4300
    5. No
    I already have:
    http://enfigcarstereo.com/ENFIG_SRWH_AU2.html
    http://enfigcarstereo.com/ENFIG_SWCL_PIO.html
    and wrongly bought this
    http://enfigcarstereo.com/ENFIG_AAA_VWAUD5.html
    Thanks in advance
  20. #140
    Established Member Two Rings Viktor Vaughn's Avatar
    Jan 25 2014
    Boston
    PM sent
  21. #141
    Jul 12 2004
    Quote Originally Posted by CesarLA View Post
    1. 2006 Audi A3
    3. Yes
    5. No
    I already have:
    Thanks in advance
    The hilo will make everything sound better.
    The antenna adapter is below.
    Looks like you got the wrong kit.
    The PNP makes the install easier.
    http://enfigcarstereo.com/ENFIG_RMK8_A3DD.html
    http://enfigcarstereo.com/ENFIG_PNP_PIO0178.html <---- I think you need to move some resistors from the Pioneer harness for this to work.
    To use factory Satellite antenna
    http://enfigcarstereo.com/ENFIG_SAA_SIR_20.html
    http://enfigcarstereo.com/ENFIG_EXT_FAKRA_17.html
    To use factory GPS antenna
    http://enfigcarstereo.com/ENFIG_GAA_PIO2.html
    If car has GPS antenna on roof but not behind radio you will also need this extension.
    http://enfigcarstereo.com/ENFIG_FAKRA_FF_17.html
  22. #142
    Jul 26 2014
    Iquique, Chile
    thanks.. preparingto order
  23. #143
    Established Member Two Rings Sheeple's Avatar
    Feb 22 2007
    2002 Amulet red S6
    Orange County, CA
    1. 2002 S6
    2. Symphony II, Bose
    3. No
    4 Considering PIONEER AppRadio 3 SPHDA210 (thoughts on this?)
    5. No
    Great thread, Thanks Christian!
  24. #144
    Jul 12 2004
    Quote Originally Posted by Sheeple View Post
    1. 2002 S6
    3. No
    5. No
    http://enfigcarstereo.com/ENFIG_SRWH_AUD2_HILO.html Fixes low rear audio
    http://enfigcarstereo.com/ENFIG_SRWH_AUD2_NS.html Does no fix low rear audio, Does not do steering wheel controls.
    http://enfigcarstereo.com/ENFIG_RMK16_A6.html
    http://enfigcarstereo.com/ENFIG_PNP_PIO0235.html
    Not sure if that car has the factory GPS antenna.
  25. #145
    Dec 13 2013
    OK
    1. 2000 C5 A6
    2. Symphony with Bose
    3. Yes
    4. Nexus 7 Android Tablet
    5. No
    I intend on keeping the Bose speaker system, but could you also give me the required stuff if I plan on upgrading to an aftermarket amp/speaker system? I may run some numbers and upgrade if it is worth the cost and within budget.
  26. #146
    Dec 01 2013
    Atlanta, Ga
    1. 2008 Audi A4
    2. Symphony 2+
    3. Yes, and I want to keep them
    4. I haven't decided yet, I am seriously considering a Pioneer AVH 4000 NEX, what are some other good options? I like using Waze and own an iPhone 4s and the DashCommand app looks sick.
    5. No desire for satellite radio
    Is the AVH 4000 NEX pretty much plug and play?
    I have to say, enfig has really impressed me with their web presence overall, and the personal attention you are giving everyone in this thread is great.
  27. #147
    Jul 12 2004
    Quote Originally Posted by Sadiq View Post
    1. 2000 C5 A6
    3. Yes
    5. No
    Pretty sure you already ordered.
  28. #148
    Jul 12 2004
    Quote Originally Posted by berlioz View Post
    1. 2008 Audi A4
    2. Symphony 2+
    http://enfigcarstereo.com/ENFIG_SRWH_AUD3_HILO.html
    http://enfigcarstereo.com/ENFIG_PNP_PIO0237.html
  29. #149
    Sep 10 2014
    Austin, TX
    Hi Christian,
    Cool that you guys are consulting for people in this forum. Good way to earn business. :) Looking for advice on what route to take here:
    1. 2011 A4 Premium
    2. Factory radio: Audi Concert
    3.Steering wheel controls: Yes.
    4 Something like the Pioneer's NEX line or CarPlay compatible unit. The wife is an iPhone user and wants hands-free access to her phone and to its maps. That's the only real requirement.
    5. Sirius XM: If it's possible to hang on to the car's existing Sirius functionality, we'd certainly like to keep it, but not a requirement.
    I guess my question here is: is there an upgrade path that doesn't kill the existing functionality on the B8 A4? The car's whole function seems tied to the display. I don't mind spending some time and money, but not if it's going to disable all the car controls that rely on the display they've got.
    An alternative would just be to get an iPhone mount and figure out how to extend the Audi hookup in the glove box to the dash area - not as elegant as a single catch-all solution but it still gets the job done, and probably much more easily.
    Is there really a choice here? A lot of the threads seem to be for pre-B8 models and given how integrated everything in the B8 is, it wouldn't surprise me to learn that one can't replace the factory head unit at all.
    Any pointers?
    Thanks so much,
    Sam
  30. #150
    Established Member Two Rings Harddrive's Avatar
    May 03 2011
    West Africa
    Christian
    1. 2006 Audi A4
    2. Symphony 2 (non Bose)
    3. Steering wheel controls? Yes (volume and track skip)
    4. New radio: Pioneer AVHX4600BT
    5. No
    00 A4 2.8Q Tip | APR Snub mount | Stern Power Ring | K&N filter. Sold
    06 A4 2.0T Tip | APR Stg 1 | KN Filter | APR Snub mount | Cupra lip | RS4 Rear Sway Bar | AF1 Trunk lip | 034 HFC | OBX Cat Back
  31. #151
    Jul 12 2004
    Quote Originally Posted by Aquitaine View Post
    Hi Christian,
    1. 2011 A4 Premium
    Any pointers?
    Thanks so much,
    Sam
    Call me in about a month. I'm working on a new product for MMI 3 cars.
  32. #152
    Jul 12 2004
    Quote Originally Posted by Harddrive View Post
    Christian
    1. 2006 Audi A4
    5. No
    http://enfigcarstereo.com/ENFIG_SRWH_AUD2_HILO.html Fixes low rear audio and does steering wheel controls with a SWCL.
  33. #153
    May 03 2011
    West Africa
  34. #154
    Registered Member One Ring Peter_D's Avatar
    Oct 04 2014
    2002 A3 8L & Evo 6
    Australia
    Christian,
    thanks for the straight information. There's so much confusion and mis-information on the web re the various adapters that it's great to have someone to go to directly.
    Ok so here goes.
    1. Year and Model: 2002 A3 8L (Australia Delivered shouldn't be a concern as all the wiring should be in the same colour and in a central position.
    2. Factory radio is a Chorus, 1 DIN unit. I don't know how to tell the difference between a 1 and a 2
    4. New head unit Kenwood KDC-X8019BT
    5. No Sirius XM Sat Tuner
    Also what are the stock sizes for the front and rear speaker enclosures.
    thanks
    Pete
    ___________________________________
    2002 A3 8L - Unmodified
  35. #155
    Oct 10 2014
    Salzburg
    1. Year and model of car (20-04-2001, Audi A6, S6, 4B, LAYMF1, FM6EA0R99P, AA-Limousine)
    2. What radio did the car come with from the factory. (It doesn't matter if you have Bose) (Symphoni II, 4B0 035 195 HX, NON-BOSE believe it is NON-BOSE)
    3.Does the car have steering wheel controls? (YES)
    4 What is the brand and model number of your new radio? (JVC KD-R412)
    5. Are you going to be using a Sirius XM satellite tuner if yes which one? (NO)
  36. #156
    Jul 12 2004
    Quote Originally Posted by Peter_D View Post
    Christian,
    Ok so here goes.
    thanks
    Pete
    Email me I need a picture of the radio. WE do not have the single din chorus in the US but I may have the dash kit in stock.
  37. #157
    Jul 12 2004
    Quote Originally Posted by Stagger Lee View Post
    I dont have that kit on the site email me.
  38. #158
    Oct 10 2014
    Salzburg
    Thank you Christian. There are scratches all over front panel so i will buy new one. I will check your list to see what i like most then write new post her, with new CD model.
  39. #159
    Oct 04 2014
    2002 A3 8L & Evo 6
    Australia
    PM with picture sent.
    cheers
  40. #160
    Jul 08 2014
    California
    1. 2006 A4
    2. Symphony II
    3. It does have steering wheel controls.
    4. Kenwood DDX371
    5. No Sirius.
