Results 1 to 40 of 46
    Veteran Member Three Rings bpat1017's Avatar
    Jun 29 2012
    Torrance ca usa
    Audi a4 2.0 engine siezed. Non spam!!!!
    My engine siezed when I went to start my b7. Drove about 40 miles around town. Car ran fine. I went to park at the store and stalled out when I parked thinking I was in neutral when I was still in first. I returned from the store and went to start the car. The engine cranked over two or three times and it just stopped. I went to try and start it again and the starter engaged but didn't turn with the engine resistance. Went through the steps to see what was going on jump start, charged battery and found out the engine is locked up. Well what the tow driver told me. http://i901.photobucket.com/albums/a...p/image-12.jpg Put a socket on the crank and tried to turn it by hand. Not sure how much pressure to apply to turn it by hand but I put at least 100ftlb of pressure and nothing. Also the timing belt did not break. Car has 87xxx miles total with 9xxx miles stage 3. What is the next step I should take to see what is locking it up?
    PLEASE do not trash my post if your not going to help thanks. Yes this is my second post because the last one i was accused as a troll. Also I am active duty so it's impossible to work on my car everyday so excuse me if I don't reply frequently.
    Oct 16 2008
    South Florida - Ft Lauderdale
    When you trying to turn the engine with the wrench, are the spark plugs removed?
    Phil
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    troll again. damn, how did you get the picture when the car was already towed,., . ah nevermind, I won't feed the troll
    Epy
    Mar 24 2013
    Oakdale, CT
    I doubt you put 100 ft-lbs on it with that ratchet. You still should have been able to turn it though if the plugs were out and the car is in neutral. If you think it really is siezed, you really don't have a lot of options left. You could boroscope the cylinders and look around, but you are probably going to have to start taking stuff apart. Drain the oil through some cheesecloth and look for bearing material or metal shavings.
    -Adam
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    No way you put 100ft-lbs on the crank using that. Seriously. Are you absolutely sure that the starter is still good?
    Do you have a metal drain plug? I'd start with Adam's recommendation: check the oil for any metal fragments. If you have a metal plug, so much the better. If not, cheesecloth should work just fine.
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Aug 09 2011
    calgary, AB, CANADA
    It looks like you're running a BOV. Without knowing what tuning you're running, it is entirely feasible that you have been dumping metered air (from the MAF) out to atmosphere, and as such your car has no idea what its doing with the fueling. I could be out to lunch here, but this could have somehow led to a totally jacked A/F ratio. It's entirely possible you got a lean condition and melted something. As stated above, try to boroscope it. Should be pretty obvious if something is toast inside. That, or pull the head. It isnt that tricky.
    Jun 27 2011
    Do you even lift bro?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings slvrb7's Avatar
    Dec 28 2011
    2016 Polaris RZR 1000, 2016 Jeep Wrangler JKU, 2017 Range Rover, 2018 Land Rover Discovery
    North Texas
    first off did you check the oil level in your car to make sure there is enough oil in the pan because the low oil light does not always come on until it's to late.
    Kris
    Mar 24 2013
    Oakdale, CT
    Nope
    -Adam
    Veteran Member Four Rings 4rings5stars's Avatar
    Jul 31 2011
    He's back!!
    The fleet
    2000 S4 EPL tuned Stage 3 -- Silver/Panda -- Latest fun project
    2002 S4 Avant 6spd -- Nogaro/Silver -- Long term rehab project
    2012 A8L -- Night Blue Pearl/Nougat
    2013 VW Touareg VR6 Lux -- Flint Grey/Black
    2001 BMW 540iA Sport -- Steel Blue/Grey
    2001 BMW 750iL -- Night Blue/Ivory
    2004 Jaguar XJ8 -- British Racing Green/Tan
    2005.5 A4 Avant 6spd -- Quartz/Black -- Sold
    Jun 27 2011
    If at first you don't succeed, try try try try try try......
    -CP
    2017 Q7 3.0t
    Veteran Member Three Rings Flexcj5's Avatar
    Sep 23 2009
    B7 2.0t Tiptronic
    Greenville, SC
    Serious answer here because I'm tired of all the ridiculous posts you make.
    1)Put car in neutral
    2)Set parking brake
    3)Disconnect coils
    4)Pull plugs
    5)Put large breaker bar and socket on crank
    6)Push/pull on bar
    Does engine turn over? If yes, not seized.
    If no, push harder.
    If still no, rebuild engine.
    Silver 05 2.0t B7 REVO stage 2+ w/ ER SMICs, RAI DP & Stasis exhaust.
    Debadged and tinted on Eibach/Koni FSDs rolling on Euromesh 3's (245/35 R19 et33)
    Jun 27 2011
    Quote Originally Posted by Flexcj5 View Post
    2)Set parking brake
    3)Disconnect coils
    4)Pull plugs
    6)Push/pull on bar
    If no, push harder.
    This. I mean, its not rocket science here.
    -CP
    2017 Q7 3.0t
    Senior Member Two Rings Hopperstien's Avatar
    Jul 29 2011
    2007 Corvette
    Palm Beach, FL
    Just going to leave this here...
    http://www.audizine.com/forum/bpat1017 33 started posts of wasted space
    http://www.audizine.com/forum/showth...jector-install
    Quote Originally Posted by shiro1745 View Post
    Do you have any idea what you're talking about?
    Quote Originally Posted by fordyoz View Post
    definitely not. this guy starts a thread every day about how his car wont work.
    Make the insanity stop!
    '14 Q5 3.0
    pw211:I would owon it ND THEN beat the **** aout of it witeh a god damn penguin
    Jun 27 2011
    Quote Originally Posted by Hopperstien View Post
    This. We keep trying to throw this kid a bone but he throws it back then starts a new thread...
    -CP
    2017 Q7 3.0t
    Jul 31 2011
    <sigh>
    Some people shouldn't own a car, let alone an Audi
    The fleet
    Nov 03 2012
    CA
    Call ECS. Ask them if they have any audi's in stock. If not, ask them to order one from Germany. Then, ask them to pull the engine and ship if to you.
    Then, come back and start a thread reporting on the customer experience.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Are you turning the crank the right way? Who hasn't killed an engine by letting the clutch out accidentally in first gear? That does not weld engines together.
    2021 Audi S4, P34 Intake
    Jun 29 2012
    Torrance ca usa
    First off its probably not the best to have a bov. Haven't had any problems with it. I did have a forged diverter valve but the main o-ring went and I've been lazy to try and order the o-ring.
    I have had all the tuning done by a shop gp motorsports in Rockville md. They mainly did a unitronic stage 3 flash.
    The oil level was good.
    I did remove the spark plugs when I tried to turn the crank clockwise. Exactly what is a safe amount of torque I can apply to try and turn it?
    When I first get a chance I will drain the oil and look at the drain plug.
    Thanks for the help guys. I do agree that it's crazy to hear of the engine locking up on start up. But I'm not making any false accusation. The car literally ran perfect before and all I tried to do is simple try and start the car. I simple started this thread because myself and two shops Gp autogroup and New German Performance have no clue on what the problem is.
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    I said it last time, don't feed the fire
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
    Jul 14 2012
    Eastern Shore,MD
    I forgot to ask, did you check the muffler bearings and blinker fluid?
    Veteran Member Three Rings -Billy's Avatar
    Feb 13 2013
    Altoona, PA
    Quote Originally Posted by B7AudiSline View Post
    OP can get all the parts and supplies he needs here: http://kalecoauto.com/
    Established Member Two Rings parki3n's Avatar
    Nov 03 2008
    Norwalk, CT
    Quote Originally Posted by peb View Post
    This post made me laugh. A lot. Well done.
    2006 A4 Avant 2.0T Tip | Dolphin Gray | Stock | Sport + Premium Package | Quattro
    Veteran Member Three Rings gdlkn84as's Avatar
    Apr 25 2012
    2006 B7 A4 S-line 2.0T (Sold) - 2008 PT Bruiser (Long Story) - 2003 Kawasaki Z1000
    Greenwood, IN
    Quote Originally Posted by -Billy View Post
    Actually just bought the $6,000,000 sub. Can't wait to replace my factory one with this one! I might need to pick up that left handed metric screwdriver to do the install though.
    2006 B7 A4 S-Line 2.0T - SOLD
    -Making my return to the 'Zine-
    2016 B8.5 Allroad
    PP+, Sport Interior, DS, VAG'd
    2003 Kawasaki Z1000
    Veteran Member Four Rings yeoj112689's Avatar
    Aug 17 2013
    Rossford, Oh
    How crazy would it be if this kid really needed help and everyone is just assuming he is trolling.
    If not he may just not have experience.. Suppose they should do some research first though.
    || 2006 Audi A4 Quattro 2.0T || Mods and stuff
    Veteran Member Three Rings swaggerwagon's Avatar
    Sep 28 2012
    NC
    Quote Originally Posted by yeoj112689 View Post
    He's been on AZ before and always asks questions but his stories/details never add up. Look at his pasts posts. If I recall correctly his dad "owns a shop sponsored by Garrett" and he mentioned somewhere that two reputable shops can't figure his car out yet he's only had this problem for this week, he has "no time to work on his car because he's AD" but has time to go to two shops and try and do work on it himself?
    If it walks like a duck and quacks like a duck, then...its a duck.
    B8.5 3.0T/ B5.5 1.8T
    Jun 29 2012
    Torrance ca usa
    So today I finally was able to get the crank to turn. I turn it over many times and cannot figure out with is going on. I put the starter back on and cranked the engine. Still had no problems. i put some things back together to start the car to see if the timing was correct. So I started it and got a clicking sound from the head. Before I do anything else I would like to check the timing. I have a slight idea how this is done but want to make sure on an a4. Would somone explain to me on how it's done or send a link. I couldn't find one on the forums.
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by bpat1017 View Post
    So it went from being seized, to running? I'm confused
    -Adam
    Jun 29 2012
    Torrance ca usa
    I finally was able to get the crank to turn over. It just went like something broke. So Im thinking it was hung up on a valve and I eather broke or bent the valve when I got the crank to turn. I turned the crank over multiple times. So then I started the car and it ran but their was a loud noise coming from the head like a valve was slightly hitting. I noticed the cam and crank pulley where not aligned with the timing marks on the covers. I then took the timing belt off and I aligned the cam pulley to the arrow and the crank mark to the arrow. http://www.audizine.com/forum/showth...=timing%20belt When I turn the crank it hits the valves. So yes when the crank and cam are aligned at the marks. The pistons hit a valve. What does this mean? That is the right way to set the timing correct? You align the cam and crank mark to the aligning marks?
    Mar 24 2013
    Oakdale, CT
    There could also be an issue with the timing chain. That would cause the cams to be out of time with each other.
    -Adam
    Jun 29 2012
    Torrance ca usa
    I'm guessing that is a job for the shop?
    Senior Member Three Rings MNB5Tuner's Avatar
    Sep 02 2009
    Colorado Springs
    Car is broke, sell it to someone for cheap and buy yourself a Huffy pedal bike
    2007 A4 Avant S-Line 2.0TQM APR Stage 2
    Mar 24 2013
    Oakdale, CT
    If you don't know enough about it to figure out what is broken, you should probably just bring it somewhere.
    -Adam
    Aug 17 2013
    Rossford, Oh
    +999999999
    Jun 29 2012
    Torrance ca usa
    Well I decided to start breaking the head down. I realized that the valves aren't all closed at top dead center. The intake valves seem to be out of sink explaining that the timing chain may have skipped. I just hope the teeth aren't worn or tore up. Also I'm tired of the banjo bolt setup for the fuel pump. Decided I will buy the fitting and the line from an 08 a4 using the fuel hose. Did it on a friends car so ill definitely be posting pictures if any one wants.
    Jun 29 2012
    Torrance ca usa
    I put together and installed the big turbo kit had some early issues for tuning but I think i can take a dive into this problem and figure it out.
    Mar 24 2013
    Oakdale, CT
    Best of luck. If your cams are out of time, you'll probably have a lot of work ahead of you.
    -Adam
    Jul 31 2011
    Why on earth would you assume that the valves would ALL be closed at TDC???
    Unless I'm missing something about this motor, the #1 cylinder would be closed. Not sure about the others.
    The fleet
    Jun 29 2012
    Torrance ca usa
    Well I haven't found the problem but I decided that buying a new head is a better solution. http://www.audizine.com/forum/showth...09#post9073509
    Nov 03 2012
    CA
    I have to say, it really doesn't seem like you are trolling anymore, and if so (no trolling) you have a ton of patience and maturity with how you responded.
    Good luck!
