Quote Originally Posted by olethalb View Post
Bob - thanks for reply, i had read that thread as did as much research as possible but appreciate the second opinion
Bindi - i read that in the other thread thanks for confirmation
So to continue the story, armed with the above info i thought i’d pick on one coil and go from there
Repinned 2 - 4 to match what bindi confirmed above - grounded pin 4 to coilpack mounting point for testing purposes - still threw ‘open circuit’ code
Next i grounded pin 4 to inlet - same code
Then i ran pin 4 to bulkhead ground behind header tank - same code
I have a few old tfsi coils laying around so tried that, grounded to valve cover - no code
Next for testing repinned 2 - 4 with now pin 2 grounded to valve cover - no code
Dropped a new uprated rs6 coil in left wiring as above - threw a code
Tried another cylinder with tfsi coil and left wiring as was - no code
Also tried a 1.8t pencil coil as above - no code
I guess these ‘uprated’ coils have different inners that the ecu doesn’t like
So the solution is to ditch the fancy coils ?
Sent from my SAMSUNG-SM-N920A using Tapatalk
