Results 1 to 8 of 8
    Feb 08 2017
    2003 A6 3.0 sedan 80,000 White, 1997 A6 sedan, Red, sold, 1990 VW Corrado G60 150,000 white
    Lancaster,PA
    Intermitant Low Fuel Warning
    I'm getting an intermittent low fuel warning even when the gauge and fuel are at 1/2 tank. This randomly happens as I put the car in reverse to back out of my garage. Full it doesn't do it.
    This car sat for periods of time in the past because the original owner went to Florida over winters and left the car in the North. I've had the car for 1 1/2 years, this starting to get irritating. Any help would be appreciated.
    2003 A6 quattro 3.0 sedan 80,000 White
    1997 A6 sedan Red/Ecru Sold
    1990 VW Corrado G60 150,000 white (weekend toy)
    2004 Chevy Tahoe AWD, daily driver 182,000 built like a rock.
    May 09 2012
    Virginia
    Check the fuel level sender in the tank.
    Feb 08 2017
    Lancaster,PA
    There appears to be three, do you know the location of the one which triggers the low fuel warning?
    Apr 29 2009
    Quadzilla
    Longmont, CO
    wouldnt hurt to get a vagcom scan done, that might tell which sensor is acting up
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    May 09 2012
    Virginia
    Quote Originally Posted by jimweis View Post
    I believe its the one in the tank under the seat on the rear passenger side.
    Established Member Two Rings Fahrvergnugen's Avatar
    Dec 01 2017
    '03 Allroad yet to be resurrected, '99 VW Cabrio, '99 BMW 323i, '83 VW Pickup, '84 MB 380SEC
    Olathe, CO
    That one is for the pump. The fuel level sender is actually behind the rear seat on the flat section. You will have to remove the carpeted board on the floor of the area behind the rear seat to see it.
    Feb 08 2017
    Lancaster,PA
    Quote Originally Posted by Fahrvergnugen View Post
    I understood there are three senders and the gauge reads a value from all three. The upper one is the first to read low, why would that one be the trigger for low fuel when there appears to be plenty of fuel in the lower portions?
    Dec 01 2017
    Olathe, CO
    Forgive me, I only saw the one on mine... I guess that makes sense why they have 3, give the fact that the tank is such a Goofy shape. As for why, I can't begin to guess. Perhaps if you pull each and check for functionality outside the tank?
