Results 1 to 40 of 83
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    Crikey :( Ever have one of those eureka moments with a problem only to release it was your own stupidity that caused the problem in the first place? Solved the condensation issue. When I reassembled the lights I accidentally reversed the rubber gaskets for the bulb covers and installed the drivers gasket on the passenger housing and vice versa. The mismatch wasn't enough to cause a pooling leak, but it was enough to allow moisture in. Put the gaskets in the proper housings and voila, not more condensation... and the first Pineapple Express of the year dumping 200mm of rain on Vancouver this weekend has been a pretty good test ;)
    Current: 2012 Q7 Prestige 3.0T
    Former: 2008 FSI V8 Touareg, Galpagos Grey Metallic on Sienna interior… self-immolated due to low pressure fuel leak on exhaust manifold
    Former: 2002 S6, Silver on Silver Pearl w/ Alcantara insert.... stolen, used in a targeted gang murder and given a Viking funeral
    Former: 2000 A6 4.2L... killed by a distracted driver
    Sep 11 2009
    NE
    Excellent, you found the issue without undoing the whole lights.
    I got lucky with my projectors, they are aligned well, no dark spots and the low beam starts in the right section of hot spot so no overly bright foreground. No need to take them apart
