Page 31 of 262 FirstFirst ... 2129303132334181131 ... LastLast
Results 1,201 to 1,240 of 10451
  1. #1201
    Veteran Member Three Rings 13allroad's Avatar
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Bath time and removing vehicle badging
    Current: Quantum Gray Metallic SQ5 / JB4 / Carbon Mirror covers
    Old:
    2014 A6 tdi prestige, HRE FF01 wrapped in Conti, black optic, sport package, LED package, RS7 Pedal Kit, 034 Trans mount, Alu Kreuz, Eurocode sway bars/end links, rear spoiler, Vag Com Mods, piggy back tune.
    2013 allroad tuned and modded.
    Weekend rider - 2015 BMW R Nine t - custom
  2. #1202
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Quote Originally Posted by pandi View Post
    What power washer do you have?
    Old:
  3. #1203
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Quote Originally Posted by MadAboutCars View Post
    S4Per, your car looks really good. Any issues with the 15mm spacers and where did you get yours from? Thanks.
    Thanks! No issues at all, Vagcom lowered and all. Got them from Achtuning.com (which happens to be local, so I could just pick 'em up).
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
  4. #1204
    Veteran Member Four Rings MadAboutCars's Avatar
    Aug 27 2015
    MY18 Audi RS6 P, MY18 Audi SQ5,MY16 Audi S6 (sold), MY12 Audi Q7 4.2L TDI S-line (sold)
    New Zealand
    Quote Originally Posted by S4Per View Post
    Thanks. Can you remember which lug bolts you got for the 15mm spacers and your rims (which are the same as mine). How far did you lower with Vagcom?
    2018 Audi RS6 Performance - Floret Silver, Titanium styling package, 21" titanium 5 V spoke wheels, Dunlop SP Sport Maxx GT 285/30/21, Black sports seats, Carbon inlays, Sports diff, Sport exhaust, Matrix LED headlights, 360 camera, Head up display, Active lane/side assist with adaptive cruise control, Park assist, Privacy glass, Electric tailgate with foot open
    Mods: Dura-Seal exterior/interior, Audi Sport door lights
  5. #1205
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Quote Originally Posted by VeryBadman View Post
    Not today but I replaced my MORR set with stock one since the front right tire was punctured and is now flat. If it is not repairable, I will have to run stock set for a while since PSS 285/30/20 is back order
    Stock! Lol, that looks bad ass!!!!!!
  6. #1206
    Feb 01 2009
    Pa
    Quote Originally Posted by 13allroad View Post
    What do you guys use for this foaming car wash I might have to pick one up in the spring and I think I mat de badge as well!
  7. #1207
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    What did you do with your c7 today?
    Quote Originally Posted by Sd76 View Post
    I use a foam cannon just like this one, fill 1/4 way with chemical guys wash and top with water. Attach to any pressure washer electric or gas and adjust your tip. If you go to Amazon and type foam cannon you can see what they look like.
    Old:
  8. #1208
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Sunday available all day... U bring beer
    Old:
  9. #1209
    Feb 17 2004
    2013 Audi S6
    You bet. From this page, the "R13 Floating (17MM Hex) Black Zinc, 14MM x 1.5 x 42MM" are the ones I bought. Below are my pre and post Vagcom values. I went for 17mm all around and didn't encounter any errors.
    • Pre (LF, LR, RF, RR): 393.5, 391.5, 392.1, 388.8
    • Post (LF, LR, RF, RR): 410.5, 408.5, 409.1, 405.8
    Cheers,
    Per
    Never forgotten:
    2002 S4 Stage 3 Tip
  10. #1210
    Aug 27 2015
    New Zealand
    Cheers,
    Per
    Thanks, Per. Again you're a big help. I couldn't get them from Achtuning, but was able to source the matching parts from Tuner Shop in Germany, using eBay.
  11. #1211
    Sep 22 2013
    Norway
    Quote Originally Posted by Roccorace View Post
    Thanks to MYAUDIS7 I installed this little beauty. Winter wheel setup has the car reading 58mph at 60 on the gps but I wouldn't frown on a 4 second 0-60 on APR 91 map and wheel spin anyhow!
    Sent from my SM-N920V using Tapatalk
    I see a consumption meter in the DIS, I do not have this one in my A7 2012, anyway to enable with vcds ?
    |A7|3.0|TFSI|B&O|NightVision|HeadsUp|Led Headlights|
  12. #1212
    Established Member Two Rings Roccorace's Avatar
    Nov 22 2015
    Minnesota
    My 12 A7 had it, I cant believe yours doesn't. I think you choose the top choice from the menu when you hit the steering wheel button just to the right next to the ok button on the steering wheel, then scroll down through the displays. Ironically it is not under economy programs...
  13. #1213
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    My '12 A6 Prestige has it and you access it as described above.
    Do it right, or don't bother.
  14. #1214
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    I think it's a sub menu of the second item down. It might be below the Short Term Memory screen. Just found it myself after seeing this.
  15. #1215
    Dec 18 2014
    DMV
    I'm snowed in today
    Sold: 15 S4, 16 Tornado Gray S6, 16 Glacier White RS7, 18 White Q5
    Current: Black SQ5, Black V10 R8
    Next: Gemera
  16. #1216
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    I knew I bought a 4x4 F150 for a reason!
  17. #1217
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by Serpent View Post
    I'm snowed in today
    Same here. The A6 is a big, white lump.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
  18. #1218
    Nov 22 2015
    Minnesota
    35% vinyl on tails and markers, no snow today on Minnesota and its warm enough to stand the garage. It isn't as dark as it looks in the pics, came out good.
    2017 Audi RS7 | Daytona Grey Matte
    - Milltek Non-resonated Exhaust
    - Full LED Color-change Interior Lighting upgrade
    - ECS Flush Spacer Kit
    - OBDEleven modified | Lowered 10mm | VIM | Seatbelt Chime | Heater timers
  19. #1219
    Dec 18 2014
    DMV
    I dug my car out
    Next: Gemera
  20. #1220
    Nov 22 2015
    Minnesota
    I dug my car out
    That sucks.
  21. #1221
    Dec 18 2014
    DMV
    She's out!
    Next: Gemera
  22. #1222
    Jun 30 2012
    Woodstock GA
    You don't keep that beaut in a garage? I'd be way too worried about that!
  23. #1223
    Apr 12 2014
    Atlanta, GA
    Took about a half hour to get the car out.
    This crap is ridiculous.
    Almost there:
    Finally out:
  24. #1224
    Dec 18 2014
    DMV
    Its not considered out until there's no snow on top of the car
    Next: Gemera
  25. #1225
    Aug 27 2015
    New Zealand
    Fitted SCC 15mm spacers (Made in Germany and Autobahn approved by TÜV) all round on my 2016 S6, after seeing Per's S6 pictures. Perfect result with stock 20" wheels.
  26. #1226
    Sep 26 2013
    2018 BMW x2 xdrive
    PHX, AZ
    Fitted CCS 15mm spacers (Made in Germany and Autobahn approved by TÜV) all round on my 2016 S6, after seeing Per's S6 pictures. Perfect result with stock 20" wheels.
    Got a link for them?
    Old:
  27. #1227
    Aug 27 2015
    New Zealand
    Sorry it was SCC (I've edited the post above). I got them from Tune Shop on eBay. This is the link to their site:
    http://www.tunershop.com/SCC_Wheel_S...880802_h3.html
    The eBay listing had free shipping for the spacers and the 43mm wheel bolts.
  28. #1228
    Feb 17 2004
    2013 Audi S6
    Adam's rotors and pads finally installed.
    Was going to install the Disc Italia Ceramics, but this :(
    Thankfully, due to a shipping mixup on the rotors, I got free pads from Adam's and used those instead. I was surprised what happened with the Italia's...wasn't cranking on it or anything.
    Never forgotten:
    2002 S4 Stage 3 Tip
  29. #1229
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Washed and waxed the car Sunday only for some motherfu**in winds to blow truckloads of dust on Monday and birds with laser guided shit targeting my car - strange looking greenish black stuff that had already dried by the time I saw it. Did not have time to do a proper wash so took a leap of faith with Optimum No Rinse. Holy crap, that thing works great (granted I did hose the car down with water for a couple of minutes). No swirls or scratches, car looks sparkling clean. Also, I am really impressed by the Klasse AIO and HGS coatings I did. Generally with bird shit, we need to buff the spot but surprisingly what looks etched just washes away during the car wash.
  30. #1230
    Established Member Two Rings turbello18's Avatar
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Tint yesterday, links today.
    '13 S6
  31. #1231
    Established Member Three Rings HackDevil's Avatar
    Jan 23 2016
    chicago
    Quote Originally Posted by turbello18 View Post
    That looks amazing! What wheels are those?
    13 Audi A6 3.0T Prestige Oolong Grey
    Here's my: Instagram / Build Thread / YouTube
  32. #1232
    Nov 12 2010
    08 Q7 Sline
    Manchester
    Thank you. A6 black optic 19's. I believe from 2015.
    '13 S6
  33. #1233
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    Took my girlfriends A6 in for some Valentine's Day goodies at Eurocode. Crystaline window tint all around, blacked out badges and taillights, debadged the rest, and I even custom made some heart rings that shes wanted for over a year.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
  34. #1234
    Junior Member One Ring
    Dec 23 2015
    San Diego
    Well not today but last month..
    I dropped in a honeycomb grill, 20" LED bar and Whelen 100w Siren PA.
    PA is hooked up to a small amp that goes to a 3.5mm Aux cable. Thats connected to an Arduino with 6 buttons to play siren or music clips and also a mic. If anything just plug in my phone. PA is not really visible but its in the top right of the inside of the grill.
    Then to toggle the LED bar and PA amp I used a couple illuminating buttons and made a mount for it.
  35. #1235
    Established Member Two Rings _SILENCER's Avatar
    Jan 14 2016
    Southern California
    Got my oil changed, made arrangements for my stage 1 APR, and broke 110MPH on the way home
  36. #1236
    Established Member Two Rings VPRS7's Avatar
    Nov 01 2014
    Had Unitronic Stage 1+ tune done to my RS7 yesterday afternoon. Haven't had much chance to test it yet as I had plans last night.
    However........the acceleration from rolling is monstrous I hit 175 kph on highway on-ramp in seconds prior to backing off. Gotta get out to some back country roads today to do some launches and have some fun!
    Unitronic claims 691 Hp, 655 Tq and I don't doubt it.
    One of these days I will have to dyno this beast.
    2014 Audi RS7: Daytona Gray / Unitronic Stage 1+ Tune / 21" Corse Werks Agio Monoblock w Michelin PSS / DRC / KW H.A.S. / Eurocode Sways / AWE S-Flo Intake / Sport Exhaust / Carbon Inlay / B&O / VAG mods
    Former: 2012 C63 AMG Coupe, 2012 M3, 2008 M3 Sedan, 2004 M3, 1998 M3 (track-prep), 1998 M3, 1991 M5....
  37. #1237
    Jul 30 2013
    Colorado
    New butt-face lift
    Painted the diffuser and added new Exhaust system.
  38. #1238
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by VPRS7 View Post
    Glad to know that we have another member with Unitronic! At first I had Stage 1+ flashed to my car but being in CA I only had 91 gas in the tank and so the power gain seemed underwhelming because the car obviously ran in low power mode.
    After back and forth with Unitronic I finally have stage 1 program available and flashed it to my car on Friday. Now it seems to run better since the program matches the gas but I don't know if it really makes more power. I will have to schedule with 034 to put my car on dyno again to see the actual numbers.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
  39. #1239
    Veteran Member Three Rings AudiA6A5's Avatar
    Dec 06 2013
    RI
    Quote Originally Posted by cmendes0101 View Post
    Is the 20" led bar suppose to act like a fog light? Any pics with it on at night?
    C7 A6 Prestige - Phantom - Sport - LED - 35% Llumar - Eibach Pro-Kit - EC S+Ls - 034 TM - RS Grill - APR Stg II
    Cayman S - Rhodium Silver - PDK - Sport Chrono| B8 A5 Cabrio - Meteor Grey (for sale) | Pathfinder - Cayenne Red
    past audis: B5 S4 | B7 A4 S-line
  40. #1240
    Established Member Two Rings ayoo456's Avatar
    Apr 23 2014
    queens ny
    Quote Originally Posted by all_kobiwon View Post
    How did you go about painting it?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
