Page 162 of 262 FirstFirst ... 62112152160161162163164172212 ... LastLast
Results 6,441 to 6,480 of 10449
  1. #6441
    Mar 11 2007
    Colorado Springs
    Quote Originally Posted by infinitereality View Post
    I can't decide if I should do rear calipers in same color, black or leave alone. I have to change pads soon anyways. Seems most do rears as well, but to me it looks kinda funny since they're not beefy like rears on say, a CTS-V or Camaro SS. Any thoughts?
    Well, that depends on what you do with them... Your S7 has Rears that are 336mm and the CTS-v/ Camaro both have 365mm rears. The size difference is only an inch and you could barely notice the difference, especially if the wheels are the same diameter. Additionally they are rear wheel drive cars and manufacturers of RD cars need bigger rear rotors and GM puts more money into their rear calipers on their high performance cars.
    Anyway, you will need to invest a little time and coin for a beefier look with no better stopping distances. However, 336 in back is as big as you can go IIRC, with the exception of Audi Carbon Ceramic which are 370mm rears
    336mm behind 20's looks "beefy" to me for quattro?
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
  2. #6442
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by A6sport View Post
    C7 S6/S7 has 356mm rears... 3/4" larger than your quote.
    A6/A7 has the 330mm rears
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
  3. #6443
    Mar 11 2007
    Colorado Springs
    My comparison was the 336mm S6/S7 to the CTS-V/ Camaro 365mm rears which is approximately 1.0 inch, not the 330mm A6/A7 to the 336mm S6/S7 which is .75 inches. Correct?
    2012 A8L 4.2
  4. #6444
    Oct 18 2016
    WA
    Quote Originally Posted by ichi d View Post
    Silly question but I have a my13 will this apply to me?, thanks
    Dealers typically only update MMI firmware for a handful of reasons,
    -An owner complaining about an issue that's specifically addressed in the change log for the update
    -If the maps are updated and require a newer MMI version to function correctly
    -TSB/Service campaigns
    With a '13, unless you have a 3rd party warranty or the car is somehow still under CPO coverage, you'd probably be paying for the update.
  5. #6445
    Established Member Two Rings CDub_A7's Avatar
    Oct 23 2018
    Ducati 848, Yukon Denali XL, Mini Cooper S
    PNW
  6. #6446
    Senior Member Three Rings NAYCHURKAL's Avatar
    Apr 15 2008
    18 Dodge Durango SRT
    North NJ
    Installed the Maxton front spoiler and gave it a much needed car wash !
  7. #6447
    Veteran Member Three Rings JonnyBravo!'s Avatar
    Oct 26 2014
    2018 SQ5 | 2017 A3 e-tron
    California
    Quote Originally Posted by NAYCHURKAL View Post
    Love your car! What’s your tire/wheel specs?
  8. #6448
    Veteran Member Three Rings infinitereality's Avatar
    Jul 05 2017
    Superlite Coupe (SLC) & CRF50
    Louisiana
    Since calipers had a full week to cure and no drive time, decal time.
    2018 Camaro ZL1 - Black
    - OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
    - RotoFab, Forgestar CF5V ZLE offsets, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
    - Carbon Fiber: Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
    2019 Superlite Coupe: SLC IR/8 - Grigio Telesto
    - 525HP Crate LS3 & Graziano Transaxle
    - 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
  9. #6449
    Oct 26 2014
    California
    That turned out great. 👍🏻
  10. #6450
    Apr 15 2008
    North NJ
    Quote Originally Posted by JonnyBravo! View Post
    Tire is factory 20. Wheels are Vossen HF-5 20x9 et30.
  11. #6451
    Jul 05 2017
    Louisiana
    Thanks! Tried Brembo first and was good to go, satin black is a nice offset.
    Took it for a spin, first drive with fresh calipers is in the rain, lol. I left the weights off, mainly for aesthetics and no issues so far.
  12. #6452
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    Nice spoiler! Does it bolt right on or does it require modifications? And where did you get it?
    18 S6
  13. #6453
    Apr 15 2008
    North NJ
    Quote Originally Posted by Audisthesia View Post
    Thank you, No modifications other then drilling holes. I picked it up on Ecs Tuning. Took 4 months to get. You can also purchase from Maxton designs website, cheaper on ECS though.
  14. #6454
    Senior Member Three Rings mrdouble99's Avatar
    Mar 31 2018
    Montreal
    Very nice !
    Did you put a clear coat on top of the decal ?
  15. #6455
    Established Member Two Rings Bulldog 3.2's Avatar
    Nov 01 2014
    UK Kent
    Finally fitted my RS grill & gloss black lower centre blade & bolted the Maxton spitter on instead of using self tappers. Also fitted quick release number plate brackets.
  16. #6456
    Veteran Member Four Rings esemes's Avatar
    Jul 02 2019
    whirlpool cabrio washer and dryer
    clearwater florida
    I predict a record number of RS grills get installed this year... (even those sitting in the closet collecting dust)
    2016 S6 - sport - optx- atlas - AE nardo
  17. #6457
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Quote Originally Posted by Bulldog 3.2 View Post
    Looks so fresh n’ so clean! Exact same grille I have waiting for me to install.
    The way the outer chrome trim and Audi rings on the grille nicely compliment the chrome trim on the lower vents... dang. Makes me glad I went that direction!
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
  18. #6458
    Nov 01 2014
    UK Kent
    Thanks & mines not a black edition so wanted to keep with the chrome trim.
  19. #6459
    Oct 26 2014
    California
    I love when people match their RS grille to their trim, instead of just defaulting to black optics when they have chrome trim. Car looks great. Only thing I would change is maybe brushed aluminum mirrors instead of the black ones.
  20. #6460
    Nov 01 2014
    UK Kent
    I don’t think the brushed mirror coverswoukd be too noticeable on Floret silver plus I’ve sort of gone for a silver & gloss black theme so far.
  21. #6461
    Jun 19 2018
    NH
    Your theme looks good! Stick with it. I have the silver mirror caps on my S7 and I’m excited to see what it all looks like.
  22. #6462
    Nov 01 2014
    UK Kent
    Gloss black rear diffuser & side spitters.
  23. #6463
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    Me too (MY13). I wonder if I am able to get a free update also so I will join in on your silly question also.
  24. #6464
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Sent from my SM-N950W using Audizine mobile app
    C7 S6 / AWE Touring / -14mm / EuroTails /
  25. #6465
    Established Member Two Rings IssaWrapVinyl's Avatar
    Nov 24 2019
    10’ VW Jetta 2.0t Wolfsburg 09 VW CC 3.6 4Motion -Sold
    I will be copycatting the shyyyt outta you! Lol can you point me to the thread where there’s a write up on this?? Super curious.
  26. #6466
    May 10 2013
    Toronto,ON
    Quote Originally Posted by IssaWrapVinyl View Post
    I fallowed this tread from auid world.
    http://www.audiworld.com/forums/a6-c...-mins-2912393/
  27. #6467
    Jul 05 2017
    Louisiana
    Quote Originally Posted by mrdouble99 View Post
    Very nice !
    No clear coat over the decal, I had already sprayed clear after painting them. Had I figured out what decal I wanted while painting, I may have installed and cleared on top. I made a similar decal, just in gloss, for the SLC's Brembos to put on after powdercoating them and so far have held up great over 1k miles
  28. #6468
    Junior Member Two Rings
    Jul 20 2017
    Kansas City
    Swapped out the wood trim kit to carbon fiber. Big difference.IMG_20200401_194003.jpegIMG_20200406_170718.jpeg
    Sent from my ONEPLUS A5000 using Audizine mobile app
  29. #6469
    Mar 11 2007
    Colorado Springs
    Got my LED headlights covered in lamin-x tint...
    2012 A8L 4.2
  30. #6470
    Mar 14 2019
    Miami, FL
    Quote Originally Posted by Ries View Post
    Installed the eBay RS6 grill I bought. It helped to have ElsaWin this much I know.
    Niice!! No ACC Isues after removing and reinstaling the bumper?
  31. #6471
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    Quote Originally Posted by Cayo71 View Post
    I had zero issues when I did mine after disconnecting the battery first.
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
  32. #6472
    Sep 28 2009
    suburb
    Auto hold switch coded and installed
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
  33. #6473
    Apr 15 2008
    North NJ
    Quote Originally Posted by flyfishing View Post
    Can you elaborate on this a bit ? What's the purpose of the button ?
  34. #6474
    Veteran Member Four Rings Dasquade's Avatar
    Sep 07 2010
    Belgium
    When activated, when you come to a stop and press the brake past a certain point (+-15%) it auto puts the handbrake on and turns it off when you apply gas again. Indicated by a green handbrake icon instead of red one on the dash.
  35. #6475
    Apr 15 2008
    North NJ
    Quote Originally Posted by Dasquade View Post
    Oh nice. Would it work on 2016 S6? If so can you provide part number and coding you used ? Much appreciated.
  36. #6476
    Jul 05 2017
    Louisiana
    Good to see someone else with headlight tint, looks awesome! It's a must to hide the chrome inside.
  37. #6477
    Sep 28 2009
    suburb
    Check out this thread: https://www.audizine.com/forum/showt...-Hold-Retrofit
    part was like 35 dollars and rest was install and then coding with VCDS
    Audi SQ7
    Audi B8 S5 (gone)
  38. #6478
    Oct 23 2018
    PNW
    Been debating if I should do this...
  39. #6479
    Jul 20 2018
    Toronto, ON
    Installed Injen intake today. It's alright I suppose. Only criticisms are there's a 1" gap all around into the airbox and the secondary air injection hose is no longer filtered.
  40. #6480
    Oct 23 2018
    PNW
    Quote Originally Posted by Vinng86 View Post
    You can buy a filter for your secondary air hose (ECS tuning has one). The gap around air box shouldn’t matter. Lots of documentation here that there is no warm air issues or loss of power. I drilled holes in the top of my airbox and have the same Injen CAI
