Solo Werks Coilovers for B6 & B7 A4's NOW IN STOCK!!!
At long last, the Solo Werks S1 Coilovers are available for the B6 & B7 2wd and Quattro's!
eurocollective has secured the first 10 production pieces of the Quattro kits and another 10 2wd kits for Audizine members!
As of this initial post, we have already sold the first 3 Quattro Kits so we expect the rest to go quickly!
Here are the full details:
Solo Werks S1 Coilover System - Audi A4 B6 & B7 - Premium Entry Level Coilover Suspension!
- Gold Zinc Plated Housings for superb corrosion resistance
- Silver spring perches - double lock ring design
- Platform Specific Spring Rates and Matched Valving - Front 490lbs, Rear 420lbs
- Front 40-80mm (1.6-3.35") Lowering Range*
- Rear 40-80mm (1.6-3.35") Lowering Range*
- 3 year Limited Warranty
Each Kit contains:
- 2 Front Threaded Coilover Dampers - Heavy Gold Zinc Plated with dual locking ring spring perches
- 2 Micro Cellular Bump Stops
- 2 Front Springs
- 2 Rear Dampers
- 2 Rear Adjustable Perches
- 2 Coilover Spanner Wrenches
Click Here to purchase the Solo Werks Coilover kit for Audi A4 B6/B7 2WD @ $499 #S1AU001
Click Here to purchase the Solo Werks Coilover kit for Audi A4 B6/B7 QUATTRO @ $499 #S1AU002
Here is some additional Information that I know you want to know - and only Solo Werks provides:
Using the Wheel Hub center to Fender measurement as in this image, this translates to
More info & pics in the coming posts!
