Page 13 of 13 FirstFirst ... 3111213
Results 481 to 508 of 508
  1. #481
    Senior Member Two Rings 4Loops's Avatar
    Feb 21 2013
    1999.5 A4 B5 4.2 Quattro, 2007 GL320 CDI
    South Central Indiana
    Quote Originally Posted by Audihere! View Post
    I just got done installing the rs6 sandwich plate and external cooler on my avant, the car has been running much hotter than i want it to. After driving it late last night, it seems to be running about 10-15 degrees cooler(maintained 205 and when id get on it a couple times it would get closer to 210) but i havent yet driven it in the las vegas heat. From here, if this doesnt cure the 220-225 degree temps, its changing the mkiv radiator(2 row) out for 3 or 4 row and possibly deleting the ac if that takes up too much room.
    So to the sandwich plate install. I ordered an entire upper engine mount bracket with the sandwich plate from germany, I got it for $120 shipped which is pretty awesome, especially vs prices here in the states. I had bought an aftermarket sandwich plate with a thermostat and it wouldnt fit over the 4.2 m24×2 thread size and the machinist i took it to drug his feet for over a month so i got fed up and ordered oem, and im glad i did. The rs6 version has a 2 step thread size for the sanwich plate which youncan see in the pics, this unthreads from the housing so you can do this without pulling apart the whole side of the engine and having to drain coolant etc with the cooler being inside the bracket.
    Hey Audihere!, you said you ordered an RS6 upper engine mount bracket/oil cooler with the sandwich plate. It sounds like you simply removed the sandwich plate and the threaded pipe from the RS6 engine mount bracket/oil cooler, and installed them to your engine's mount bracket/oil cooler -am I right? So all you really needed here was the sandwich plate and the threaded pipe?
    -If that's the case, I was considering doing the same, but I have found an oil cooler/engine mount with the sandwich plate and the threaded pipe holding these together, from a 4.2 Toureg. I'm thinking this should still be fine, since I should expect this oil cooler should be the same as the RS6's oil cooler mount -with a removable threaded pipe, long enough to hold on the sandwich plate.
    http://www.ebay.com/itm/Olfiltergeha...0AAOSwSlBY0tSi
    What do you think about this plan? Nollywood, do you think this is a good way forward? I could keep my oil cooler that's already on my engine, and replace the threaded pipe and add the sandwich plate. -I hope this will work, as the mount/cooler from the toureg is half the cost -or less- than the RS6 specific mount.
    1999.5 A4 B5 4.2 Quattro (My V8 Swap Project)
    2002 Jetta TDI ALH
    2000 C5 A6 Partout (<--click here for link)
    2007 GL320 CDI
  2. #482
    May 24 2011
    Sin City, NV
    Yep, thats exactly what i did but when the engine was out I did change out the plastic coolant tube to the billet one so I had zero reason to remove the entire bracket again. I did have to order additional fittings to go with the external cooler etc but that is exactly what I did
  3. #483
    Feb 21 2013
    Awesome! Great to hear, I'll give that a shot then.
    Yea, I also changed out the coolant tube with a gruven aluminum pipe while the engine was out.
    Do you know remember what size fittings you got to fit the sandwich plate fittings? -I've got to order an oil cooler and lines too. Any recommendations?
    2002 Jetta TDI ALH
    2007 GL320 CDI
  4. #484
    May 24 2011
    Sin City, NV
    The sandwich plate fittings are m22-1.5, i used 10an fittings for my set up so ordered a set of those and then got the external cooler off ebay(came with the cooler, braided lines, and a sandwich plate that youll not use), its the cheapest route i could find. I'll also be receiving the fabbed aluminum core support for mine soon too so ill have more room for the coolers(have matching coolers for oil and power steering). The size of cooler i used required removing the fog lights on the s4 bumper
  5. #485
    May 27 2016
    Westchester, NY
    Good info. Wonder if a fan with a thermoswitch would help in this case or maybe even a bigger cooler.
  6. #486
    Feb 21 2013
    Excellent, I'll check out that route too.
    Wish I could find an S4 bumper. Sure would help with airflow. That, and it looks a bit better.
    So did you find that the stock power steering cooling pipe just wouldn't do the job? -Or did you install a finned P.S. oil cooler as a 'just in case'?
    2002 Jetta TDI ALH
    2007 GL320 CDI
  7. #487
    Veteran Member Three Rings Midnightblkb5's Avatar
    Jul 31 2013
    06 a4 b7 3.2 tip
    central jersey
    good stuff bro! hard work pays off
    His 03 a4 cabby 3.0! quattro swapped 0A3 6 spd 2.7t single turbo holset hx40
    Hers 06 a4 b7 3.2 tip
    build thread@ http://www.audizine.com/forum/showth...2#post12428942
  8. #488
    Veteran Member Three Rings pee quu's Avatar
    Jan 25 2009
    Oceanside, NY
    I just did the same exact thing!
    I had ordered an rs6 oil cooler plate and it came with the motor bracket and the oem hard lines off the cooler to the plate. worked out great. I actually got my set up with the help of Nolly. I have also noticed a 10-15 degree drop in oil temp. It hasn't gotten super hot here in NY but I have noticed the difference on the oil temp gauge
    2000 B5 A4 / C5 S6 V8 swap / B5 S4 driveline swap / PVW Nov 2016
  9. #489
    Feb 21 2013
    Quote Originally Posted by pee quu View Post
    Wow, that setup looks fabulous. Pretty genius place (and way) to fit the oil radiator. Shrouding looks good. Wish I were ok-ish working with aluminum.
    Say, what fans are you using there, Mr. Pee Quu? I can assume they keep your temps well in check? This is my next (and hopefully last) bottleneck.
    2002 Jetta TDI ALH
    2007 GL320 CDI
  10. #490
    Jan 25 2009
    Oceanside, NY
    My buddy does all the fab work I just help with the ideas. Yeah we wanted the air to be guided into the fan once it went through the oil cooler
    Fans I honestly couldn't tell you, my buddy ordered them. They work great temp stays planted in the middle. Only time it ever creeps is sitting in traffic in the middle of July and Aug, but it only goes past the half way mark MAYBE half way to the next line on the gauge and once you get moving it goes back to normal.. That or if I really beat on the car, I'm talking red line every gear and getting the speed past 100mph it will creep to the same point and once I get back to normal driving it will go back down. I have yet to meet anyone with a 4.2 swap who hasn't said the temp creeps in the same situations. Even my cousin who works at audi says the 4.2s are knows to creep a little in the dead of summer. its been this way over the last 3 years. at first I was a little iffy with it but I'm ok with it now. I did the oil cooler in attempt to help this, not sure if it will even do anything as far as motor temp, but we will see once summer fully kicks in
  11. #491
    Nov 03 2011
    All Over!
    Looking great, guys.
    To help with engine bay / under hood temperatures, I've ordered a spare hood. I'm actually getting Audi Sport Quattro-style vents stamped into it.
    1986 Type 85 Audi 90 quattro
  12. #492
    May 24 2011
    Sin City, NV
    When i did my swap i added a smaller and longer cooler for the PS behind the grille but have found that i needed to relocate it to the driver lower front like a sidemount IC so i could configure my fans in a staggered set up. Ill be custom mounting an eaton m112 ford cobra supercharger so need to save room and run as cool as possible. The fabricated core support should free up a decent amount of room.
    Side note, i have a silver s4 bumper available if you're lookin
  13. #493
    Jan 25 2009
    Oceanside, NY
    I have thought about doing a second hood with a custom cowl or tracking down a carbon fiber hood that doesn't look to ricer. Than I question water getting into the vents and falling on the motor/electrical parts.
  14. #494
    Jan 25 2009
    Oceanside, NY
    what else are you planning on doing to the motor to go along with this? I have seen a lot of guys make custom intak manis and slap s/c under them and call it a day. I have thought about this but if I did do a custom blower I want it to be super reliable for the long run.
  15. #495
    May 24 2011
    Sin City, NV
    Ill either be using a ctsv liquid intercooler or a cobra intercooler in the manifold, a killer chiller to refridgerate the intercooler(it splices into the ac, also off a cobra), ill either be using rs6 pistons or stacking gaskets/decompression plates to lower the compression(another guy is tryin this on his now with a single turbo set up so we'll see how that pans out), and possibly going to e85/e50 fuel with larger injectors.
  16. #496
    May 24 2011
    Sin City, NV
    My hoods vented now, engine bay gets a lil dusty but rain hasnt been a real issue sonce the vents are over the edge of the valve cover above the exhaust manifolds so the coil packs arent being drenched but I also live in las vegas so rain isnt a big issue here
  17. #497
    Feb 21 2013
    Interested to see how these vented hoods look. I've seen bhusted here in his thread working on installing vents, but I don't think I saw the finished product.
    Very excited to see a charged v8 in the b5! How do you plan on tuning the ECM for all these changes?
    Your bumper is not the one with the shark-gilles on the sides is it? I am not partial to that look myself, a bit too aggressive for me. -At least for my current style liking.
    I'd have to see how much Greyhound freight or the "bicycle shipping" services would cost to ship, to see if it's worthwhile having it shipped a third of the way across the country, or if I should just keep my eye out for one locally. Hopefully paint wouldn't kill me on price, too. But afterall, I have considered getting the hood and front quarters resprayed anyway..
    2002 Jetta TDI ALH
    2007 GL320 CDI
  18. #498
    May 24 2011
    Sin City, NV
    I put up photos of my vented hood on this thread a ways back, pesonally i like it a lot. Tuning so far was done by Daz but he has since passed away so id be likely using the guy that has done his best to replace him named Mirza.
    The bumper is an actual b5 s4 oem bumper, the ones with the shark gills are usually rs4 knock offs but the oem rs4 bumpers are quite nice but very expensive since rs4 wasnt available in the states. Greyhound would cost about 100 bucks to ship, ups etc are likely well over 300.
  19. #499
    Feb 21 2013
    I saw your pics earlier of the cuts on the blue hood, the vents in the primered black hood, but I just haven't seen what they look like as a finished product -on the car, with the whole car assembled. I imagine they look quite at home.
    I'll have to keep Mirza in mind. I've discovered that the intake I ordered from the A8 is a two stage manifold, where my motor wants the 3-stage -and I think Daz's tune for the 4.2 in the B5 w/ manual was for a 3 stage. So I'll have to get that sorted out.
    Didn't know the RS4 wasn't offered here. Figures. All the really good stuff never seems to come here. The wide body definitely completes the B5's sleek look to give it that proper aggressive look.
    Yea, I guessed shipping would be somewhere in that ballpark. I'm trying to budget funds for this project more tightly as of late. The bumper's not a complete necessity at this point, but I'm curious what price you have in mind for it. -I could PM you on this I suppose. Maybe I should also price out the cost of a respray, to see if it's in my best interest to look for an in-tact and in good shape s4 bumper from a black car.
    2002 Jetta TDI ALH
    2007 GL320 CDI
  20. #500
    May 24 2011
    Sin City, NV
    The s6 and s8 have 2 stage intake manifolds and a6/a8 have 3 stage. The tune can be adapted to you particular set up, my tune is a euro s6 manual trans file that Daz wrote the CEL into because euro didnt have it at the time.
    S4 bumpers generally cost between 450-600 for decent to great condition, anything cheaper will be a basket case and/or missing lots of items like washer caps, filler plate, and grilles etc Id be lookin for 500 for mine(just parted out an s4 so have the spare)
  21. #501
    Feb 21 2013
    Which vents? The nostril-type vents of the sport quattro, the single one on the side (maybe doubled, one on each side?), or the vents on the rear of the hood? Or all of 'em? Would certainly look neat!
    2002 Jetta TDI ALH
    2007 GL320 CDI
  22. #502
    Feb 21 2013
    Yep, I was thinking they would be up there. I'll surely have to hang around for the right time for this part. I'll just be happy to get it back on the street!
    2002 Jetta TDI ALH
    2007 GL320 CDI
  23. #503
    Nov 03 2011
    All Over!
    Quote Originally Posted by 4Loops View Post
    The vent in one side, but I'll have a mirror image vent on the opposite side, too. The vents above the grille as well.
  24. #504
    Jan 16 2021
    Looking at your message, I am guessing the ECU from the 2002 S6 AT 4D0907559B will not be compatible?
  25. #505
    Senior Member Three Rings zatta's Avatar
    Sep 02 2018
    Ohio
    Anybody have any recommendations for downpipes for the 4.2 swap? Seems like if I’d like to go catless the only option is something custom at this point
  26. #506
    Active Member One Ring nekodynamo's Avatar
    Apr 26 2023
    Garage isn't big enough
    No one makes downpipes from 4.2 as far as I can see. I'll be seeing what I can do with 2.7t downpipes.
  27. #507
    Jul 05 2016
    Bloomfield NY
    Quote Originally Posted by nekodynamo View Post
    Can use factory downpipes for a 4.2 or 2.8. I used S8 downpipes and modified them to fit on my swap.
    Sent from my SM-S908U1 using Tapatalk
  28. #508
    Veteran Member Three Rings Cactus Avant's Avatar
    Dec 15 2012
    Quote Originally Posted by bhusted View Post
    Got the DTS installed and it does make a difference. Under power before I could feel the transmission squirm around now it seems to totally stay put. There is of course some additional NVH, but really only at idle and I can live with it.
    Today I also installed the correct clutch switch for the new ECU. How much of a difference could a switch to tell the ECU if the clutch is in or out make? Major improvement! I don't know how to describe how it was before other than "jerky". It made me feel like I didn't know how to drive. Now it's much smoother. For the record, If you're running the ME7.1.1 ECU, the switch needs to be "normally closed". I wrongfully assumed that the switch from the 2.8 would work, but it is "normally open". I ended up using a brake light switch I got from the pick-n-pull.
    Last few things on the list to do before buttoning it back up:
    - hook up CEL wire. This had to be removed for the new ECU, but I'd like to get it figured out for future reference.
    - figure out which of the vacuum solenoids is activated by the ecu. The new ECU only actuates one of the intake manifold flaps.
    - move the VSS signal to the proper pin on the ECU. The cruise control stopped working after the ECU swap and I think it's a VSS issue.
    I realize this was over 9 years ago, but do you remember how you got your check engine light to work again? I have an ART engine and harness and did the same thing as you, installed an AWN ECU into the car. I have a code P1650 - "Powertrain Data Bus Missing Message from Instrument Cluster".
    Did you hook the check engine light up using the same pin from the ART ECU, or did you somehow get the CAN BUS communication working? Thanks!
