I noticed that the connector plug for my MAF was failing and ordered a replacement. At the same time I ordered rubber boots for the coil connectors. If anyone is interested, the part numbers are below.
MAF: 1J0973775A
4 Wire Boot: 4B0906102
Here's the original failing connector.
Here's the replacement. You can see that the red retainer is completely missing from the original.
Installing the rubber boots on the coil connectors proved to be more challenging than I thought it would be. Begin by removing the pink retainer.
Then, go raid your girlfriend/fiance/wife/strange girl you met on the street's purse for some hair pins. If you can't find any, drive your HOT German car around until you find some. Cut the straight ends off and bend them as such.
Insert them into the connector above and below the wire pin. Push the hairpins in and
gently pull the wire out. It does not take a lot of force. If it does not want to come out, try repositioning the pins.
This is the point where I stopped taking pictures as it is the most frustrating part. The boots are meant to go over the wires before the ends are crimped on, so getting the crimped ends through the narrow end is a challenge. I used some external snap ring pliers to spread the boot while I stuffed the wire pins through. The best advice I have is to apply lube to the inside of the boot. After some cussing and gnashing of teeth, all eight were installed.
