Results 1 to 8 of 8
    Established Member Two Rings zero|fade's Avatar
    May 24 2012
    Stratford%2C%20Ontario
    Valve Cover Torque Spec
    I'm in the process of re-sealing my valve cover as I had an oil leak on the pass side.
    Anyone know the proper torque rating for the valve cover bolts?
    Veteran Member Four Rings morris400's Avatar
    Dec 18 2008
    2016 VW GTI, 1994 Audi S4
    Alberta, Canada
    Every car I've done them on was 10-11 ftlbs. I just did my 20vt today.
    IF YOU WONT STAND BEHIND OUR TROOPS....TRY STANDING IN FRONT OF THEM!
    2016 VW Jetta 1.4T Daily Driver
    1994 Audi S4 20V Turbo, K24 7400 EFI EXPRESS
    2001 Audi S4 - Gone! Dropped valve cyl 4
    May 24 2012
    I did 8 ftlbs. I tested loosening a couple bolts and it seemed similar to when I took it apart, maybe slightly easier. I haven't fired it up yet, I let the RTV cure overnight. Maybe I'll tighten them a little more.
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Where did you get the new valve cover gasket? Was it a fairly easy DIY?
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    May 24 2012
    Quote Originally Posted by auditd0rk View Post
    I wouldn't say it was a walk in the park. Wasn't terrible either. Removing the HPFP and loosening the timing chain cover were the worst parts as the clearance between them and the firewall/rad respectively are quite tight.
    Also, funny about the gasket, I found up my local dealer and asked about a price on a gasket, turns out they don't have one. But for $120CA I could have bought a toothpaste tube of gussied-up RTV with an audi logo on it.
    I didn't buy the tube.
    May 24 2012
    Here's the only pictures I took.
    You can see the grooves where the sealant is supposed to sit on the cover, and where some sealant was still stuck to the engine.
    Feb 02 2012
    Colorado Springs
    Thanks. I've been thinking about servicing mine... I have a little bit of oil around the valve cover -- not a full on leak.
    May 24 2012
    Mine had progressed to a full on leak. There were some spots on the cover where the gasket material was nearly gone.
