Page 6 of 10 FirstFirst ... 45678 ... LastLast
Results 201 to 240 of 394
  1. #201
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sam,
    Try re-adjusting the bars ontop of the FMIC to reposition it. Agreed, it needs to be centered for that symmetry eye-catching feel.
    For some reason I was able to keep it centered:
    Really want to see that core on your car so I hope you can make it work. There is a solution out there somewhere. Need to keep brainstorming.
    This the PS type cooler I was referring to on IG
    -Doug
  2. #202
    Saint Cloud, Fl
    Yea, I'm going to have to figure something out Doug.
    I've also been thinking about wrapping the headliner and pillars in red suede. I may just wrap my stock gray parts and then if I hate it, just throw in the black S4 parts instead.
    instagram ------------> low_enforcement
  3. #203
    Saint Cloud, Fl
    Looks like I'm going to need a new driveway. I've also come to the conclusion that the parts S4 Avant that I purchased was definitely a flood vehicle. I'm thinking that it was probably submerged from the doorblades down. The engine was removed and placed into another S4 and is running strong.
    I only purchased that car for the rear bumper and seats. Everything else I'm pretty much selling. Now that the car is in the driveway the creative wheels are turning and got me thinking that I would love to completely gut this car and turn it into a track/auto-x only car.
    I think that I'm also going to snag the the rear brakes because they are massive compared to the A4 along with the black headliner in such.
    Looks like I'm going to need a bigger driveway.
  4. #204
    Veteran Member Four Rings Knives1010's Avatar
    Mar 17 2014
    2006 Dodge Charger SE, 96 K2500 Suburban
    Tacoma, Wa
    Quote Originally Posted by 7speed View Post
    I think you may need to see an addiction counselor, also your job must pay REALLY well
    Oscar "The Grouch": Is now dead thanks to a drunk driver RIP
  5. #205
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    Awesome by a large amount.. Keep up the good work and cant wait to see em rolling around kissimmee
  6. #206
    Saint Cloud, Fl
    I need Oettinger sides. Does anyone know someone that might know someone ?
  7. #207
    Saint Cloud, Fl
    Buy this stuff
  8. #208
    Mar 17 2014
    Tacoma, Wa
    Is that black or grey?
  9. #209
    Saint Cloud, Fl
    It is the black Avant S4 headliner
  10. #210
    Mar 17 2014
    Tacoma, Wa
    Damn it, if only it were for a sedan.
  11. #211
    Saint Cloud, Fl
    Still buttoning up the engine
  12. #212
    Dec 24 2009
    South Bay, CA
    Quick question:
    since you are putting your engine together, do you think that one would be able to change out the oil pump and oil pick up without having to take off the TB if the engine is still in the car and assuming the oil pan is dropped
    In theory, one would need to loosen the tensioner but I don't think you can access it unless you remove the front crank cover which also means removing the TB?
  13. #213
    Apr 07 2011
    I see no where in the manual that it mentions removing the timing belt.
    https://www.dropbox.com/s/u594w3dctp...0Sump.pdf?dl=0
    https://www.dropbox.com/s/i8jggoamj8...0Pump.pdf?dl=0
  14. #214
    Dec 24 2009
    South Bay, CA
    That's make sense to remove the sprocket.
    Thanks for the links.
  15. #215
    Established Member Two Rings Wakeskate124's Avatar
    Jun 29 2013
    salt lake city /Utah/USA
    Quote Originally Posted by Turbavanttro View Post
    Congrats! That is a rare piece indeed, let alone a NEW one. I'd like to hear how that happened. By the way, I have a set of front S4 recaros I need to sell.
    I'm interested in the recaro seats are they still available ?
  16. #216
    Saint Cloud, Fl
    Made some more progress on the engine today.
    Then today I got bored so I began a B8 A4 to B6 A4 seat swap..... just to see if I could do it. Yes the frame rails are a direct bolt in. But the wire harness and plusg are not. There is a lot of trial and error. As of right now I got every function to work except for the lumbar support.
  17. #217
    Saint Cloud, Fl
    Today I received the final part needed to button up the bottom of the engine. Tomorrow I install the baffle and the oil pan.
  18. #218
    Saint Cloud, Fl
    Still doing a little bit of mock up here and there. I'm still waiting on my timing belt and roller to arrive to button up the engine. Tonight I mocked up the turbo and oil and coolant lines. I forgot how much of a pain in the ass it is to run the lines for the coolant with the SPA manifold. As is stands I'm debating on the following
    - Purple powder coat the Valve Cover, Coolant tube and air tank
    -------------------------------- or------------------------------------
    - Copper powder coat the Valve Cover, Coolant tube and air tank
  19. #219
    Veteran Member Three Rings BerNur's Avatar
    Jan 31 2009
    Brandon FL / Astoria NY
    Nice stuff.. My vote would be copper.
  20. #220
    Jan 24 2008
    Pennsylvania
    copper or bronze
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
  21. #221
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Did you do purple once already?
    2019 SQ5 Prestige
  22. #222
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    coming along very nicely. Good jobs Sam.
  23. #223
    Saint Cloud, Fl
    I have not done purple, UFfitz did on his additions to my old engine. I like it alot though. Just want to add a bit of color to the bar other than the typical red.
    I also put in one of the B8 seats and was albe to get it all wired up. The motor in my driver's seat was toast so this was a great free replacement. I just need the power wiring harness from another power passenger seat to wire up the other seat.
  24. #224
    Saint Cloud, Fl
    Today I ran various errands and collected several parts to worl towards finishing the engine.
    I collected the following parts today
    I plummed the lines and the caps for the bottom of the intake manifold vaccum lines
    The day prior I dropped off my A7 for service and they gave me an A6 as a loaner. It a very dull and dismal styling. I feel like a much older man driving it.
  25. #225
    Saint Cloud, Fl
    Oh and I sold the car too .....
  26. #226
    Veteran Member Four Rings Samsonite's Avatar
    Apr 15 2013
    Golf Clubs
    Minnesota
    WTH!?
    2020 Range Rover Sport • HSE Dynamic • SC 5.0 V8 • Santorini Black
    2016 S6 • Ibis White • Black Optic • Sport Pckg • APR TCU/ECU Stage 3
    2013 S6 • Phantom Black • Sport Diff • Revo Stage 2
    2013 Q7 S-line 3.0T • Glacier White • Sport Pckg
    2011 S4 6MT • Ibis White • Black Optic • Sport Diff
    2008 A4 S-line Avant 2.0T 6MT • Ibis White • APR Stage 2
    2008 A4 S-line Avant 2.0T • Dolphin Grey
    2005 A4 Ultrasport 3.0 6MT • Dolphin Grey
  27. #227
    Veteran Member Four Rings DiertyEuroSpec's Avatar
    Aug 21 2009
    Fairfield County, CT
    The one you're doing all this work on?
    2003 A4 1.8T Quattro | 18" BBS CH | KW V3 | FT F21 Mixed Flow | MOTOZA | RA4 Stage 1 w/SMFW | Milltek | Uni HFC/3'' DP Combo | 3'' TIP w/MAF | 550cc | TR1.8 FMIC | USP F/R | H-Sport F/R Sway | APR Snub | RS4 Motor Mounts | Stern Trans Mount | Skid Plate | Solid Tie Rod Ends | Short Shifter | Euro Shift Knob | VMR Boost Gauge | S4 F/R Brakes | Tyrolsport Stiffening Kit | ECS S.S. Lines | Hawk HPS Pads | 034 PCV
  28. #228
    Jan 24 2008
    Pennsylvania
    You sold the 7, right?
  29. #229
    Saint Cloud, Fl
    Yup sold the Avant. Got an offer I could not refuse. I sold it with the airbags and Boer hood...... otherwise it was completely stock.
    I still have the heart of the beast in my garage waiting for a car that needs a heart transplant.
  30. #230
    Aug 21 2009
    Ohh okay well that makes a little/tiny bit more sense
  31. #231
    Mar 17 2014
    Tacoma, Wa
    Why is there a police car in your driveway?
  32. #232
    Veteran Member Four Rings krew53's Avatar
    2023 RS6 - 2013 B8.5 S4 - 2003 B6 1.8BT quattro
    Simi Valley, CA
    Quote Originally Posted by Knives1010 View Post
    Cause he is low_enforcement
    So you gonna pick up ANOTHER B6 Sam?
  33. #233
    Saint Cloud, Fl
    Yep what Krew53 said. That's my daily driver.
    I will be picking up another B6 as well. The sale was a strictly monetary move. The proceeds of this car will allow me to buy another..... cash.
  34. #234
    Jun 08 2007
    Orlando, Fl
    Want to buy a very well kept Black sedan with the cleanest interior of any B6 over 10 years old? Lol
    BetaAlphaTauMember #39 GTRS Powered/Revo Tuned
  35. #235
    Saint Cloud, Fl
    How much ?
  36. #236
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    Still have that S4 black headliner interior?
    Wagon parts vulture checking in
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
  37. #237
    Saint Cloud, Fl
    Yes I actually do.....they are not in the best of shape though. I had them sold too. Right as I was packaging them for sale the fabric on the headline began to seperate.
  38. #238
    Saint Cloud, Fl
    Well I bought some wheels for the car that I don't own
  39. #239
    Oct 21 2007
    When you say "seperate"? lol
    I will PM you.
    Nice rotiforms
    I heart wagons.
  40. #240
    Veteran Member Four Rings swededA4's Avatar
    Apr 02 2010
    Usually other peoples Audi's
    Greenville,SC
    Love those wheels Sam
    Motoza PODI BAE Parts4Euro
    BAE turbo, 550 injectors, Greddy FMIC, S4 TB,Snow meth kit, Privat Werks 19 X 8.5, Solowerks Coilovers, 034 end links, RS4 rear sway, Deval Splitter, 15% tint, 3" full exhaust with Borla 40357's, JHM trio, PODI Stepper, Recaro's
