Results 81 to 120 of 138
Thread: because racecar
Threaded View
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    because racecar--rs4 widebody inside
    Bringing this thread back from the dead. Heres what Im working with:
    2000 B5 S4
    Exterior:
    OEM RS4 body panels ( front bumper, skirts, front fenders, rear fenders, doors and sills)
    Rear S4 bumper modded to fit
    Eurogear CF vented hood- painted
    Eurogear CF euro trunk- painted
    2 Bennett CF sunroof delete -painted
    Interior:
    RS4 front door cards (cut to fit around door bars)
    RS4 grille
    Ram air headlight to turbo
    Cage installed & designed by Chris @ ScremSpec (painted satin silver)
    Momo racing seat for the driver
    SFI 6 point harness
    on board fire extinguisher system- tbd
    Motor:
    Bel BF block
    stock bore
    JE pistons
    Paulter rods
    ARP studs
    Eurospec Girdle w/custom spacers
    Eurospec Billet mains
    complete rebuild everything brand new OEM Audi, everything!
    Ati Super Damper
    AC delete
    JHM EFK
    catch can
    TFSI coil conversion
    SCCH race port heads 2.8
    hydraulic lifters
    CAT cams 40052
    .5 over sized valves
    Ti springs
    RS4 Intake ported and enlarged belly
    RS4 Throttle body
    RS4 metal TBB
    custom stainless inlets
    SRM sidemounts enlarged to 2.5 in / out w/blow off valve
    ARD tubular manifolds enlarged after collector *ceramic coated*
    turbo support
    Tial MVS 44mm wastegate w/Open dumps
    Screm Spec GTX 2867r custom turbos w/billet wheels
    Tial .86 vband housing *ceramic coated*
    3 inch downpipes *ceramic coated*
    4 inch exhaust + 4 inch Borla X1 + 4 to dual 3 vibrant muffler
    removed liquid cooled oil cooler for air cooled oil cooler
    Suspension:
    KW v3
    moog adjustable upper control arms
    034 billet front and rear subframe bushings
    034 spherical bearing upgrade rear control arm
    034 sway bar end links motorsport front
    034 rear upper control arm adjustable
    034 rear sway bar w/billet subframe reinforcement
    034 rear spherical tie rod set
    Febi control arm kit
    Drivetrain:
    DriveSport.ca Kalmar 6 spd dog box conversion - Long
    Tilton carbon twin disc clutch
    Clutch Masters "Weighted" flywheel
    Clutch Masters Hydraulic Release Bearing
    Quaife front LSD
    4:1 center
    R32 GTR 4:11 Rear diff w/custom cradle
    AP Racing motorsport 4 pot calipers w/328mm rotors
    b6 s4 rear brakes 300mm rotors
    ABS removed and replaced with prop valve
    DSS 1000hp drive shaft aluminum
    DSS 1000hp front axles
    DSS 1000hp rear axles
    Enki RPF1 17X9.5
    Fuel:
    Bosch 044-E85 in fuel tank feeding IE Surge tank w/ 2X 044-E85
    IE fuel rails
    Injector Dynamics 2000cc
    AN lines
    setup for E85
    ECU:
    Custom Engine + Interior Harness
    Maxx Ecu Race
    Aim 10" Display
    Aim PDM 32
    2000 S4 - silver- RS4 OEM widebody racecar
