Page 8 of 39 FirstFirst ... 67891018 ... LastLast
Results 281 to 320 of 1560
  1. #281
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    You can ask but but I won't tell :)
  2. #282
    Veteran Member Four Rings RoguesGambit's Avatar
    Dec 19 2012
    Eatontown, NJ
    Not even a hint?
    JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
    More to come
    Also, my story: https://www.amazon.com/Sage-Mike-Fra...7646774&sr=1-1
  3. #283
    Veteran Member Four Rings vortexjunkie's Avatar
    Sep 12 2009
    Manteca/Lathrop
    Quote Originally Posted by Jake@JHM View Post
    Quote Originally Posted by RoguesGambit View Post
    Not even a hint?
    Jake's kinda a don't ask don't tell type a guy...
  4. #284
    Feb 06 2009
    328d, Tacoma
    Woodland Park, Colorado
    Quote Originally Posted by vortexjunkie View Post
    That's been repealed......
    EFR 6758 by UM
    Info:
    Build
    Pics
    Feat'd AZ'er
  5. #285
    Aug 31 2011
    Lathrop
    Haha. Sorry for the thread jack! I can try and steer them this way if you want..
  6. #286
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    YEAH JAKE! what were you thinking clogging up Operators thread, I'm so furious I can't even think straight, the only thing that could ever bring me down below hulk levels would be to know what turbo you are thinking of....
  7. #287
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Oh also...my shifter has this squeaky noise when I go side to side...is that normal? or do you think some of those delrin bushings got misaligned or need more lube?
  8. #288
    Aug 31 2011
    Lathrop
    Haha!
    Can you identify what part of the assembly the shifter is coming from? All the parts come lubed but if they are going in and out a lot it can need to be relubed.
    Jake
  9. #289
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Jake
    bahahahah thats what she said. But no I don't, I just noticed today. Might be the weather, its been chilly recently. What type of lubricant would you recommend?
  10. #290
    Aug 31 2011
    Lathrop
    LOL!
    You will want to use an all weather petroleum based lube. The stuff we use is SIL-GLYDE
  11. #291
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    cool looks like an easily attainable product at most stores. Thanks Jake!
  12. #292
    Aug 31 2011
    Lathrop
    Anytime!
  13. #293
    Senior Member Three Rings chucklando's Avatar
    Jul 23 2012
    Oswego, NY
    I'm a huge fan of what you guys are doing for our platform. I feel like there's still a huge fan base for the B7 but there was a bit of a void in tuning companies dedicating new, high quality products to us. I just got my second B7, my first being a tiptronic I had for 2 years and this one being a 6 speed, and I'm really excited to start upgrading components with your company's products. I'm currently running a K0R with RAI test/down pipe and AWE exhaust, but I'm definitely like the exhaust you guys just put out and I'm interested to see this big turbo upgrade you guys are developing.
    A few questions for you:
    1) Do you plan on upgrading your clutch from stage 1 to 2 or 4 with the new turbo? Or is the stage 1 sufficient for your plans?
    2) In your drag racing videos, did you do anything in terms of weight reduction to help with those times? Remove rear seats, minimum gas, etc?
    3) Do you have ESP on or off for your launch? (I've just started practicing launching my car, you seem to nail it)
    4) Will your turbo package you're developing use the test/down pipe you guys just released or will it use a separate one due to the position of the turbo? If it uses a different one I might hold off on buying that test/down pipe.
    Thanks.
    2007 RS4 Daytona Gray
  14. #294
    Veteran Member Four Rings Salt n Peppa's Avatar
    Apr 04 2012
    Schwinn
    Minneapolis, MN
    Pretty sure he launched the hell out of it using the built in launch assist in the jhm tune. Correct me if I'm wrong though Jake. And I'm sure if the new turbo needs a different test pipe they would make it in a way that would mate up to the downpipe they make.
    Sent from my SGH-T989 using Tapatalk
    -Ed
    2006 A4 2.0TQ Arctic White Storm Trooper
  15. #295
    Aug 31 2011
    Lathrop
    Quote Originally Posted by chucklando View Post
    Thanks.
    Thanks man! I appreciate the kind words! To answer your questions, I as of now I don't plan on upgrading my clutch as the stage 1 has the ability to hold more power than a lot of these 2.0Ts even make. However, if I get into the bigger power levels I will use this disc and demonstrate the limits of it. (considering I launch the car a lot). At JHM, we strongly believe that all of our 1/4 mile runs need to be done with not major weight reduction. The only thing I removed from my car was the spare tire. However, we do make lightweight parts to help with acceleration and performance. ESP MUST be off when launching, or else the car is just going to apply the brakes and cause other issues. That being said our launch assist makes launching a breeze! We haven't decided if we are going to make a completely new test pipe, or make an adapter to run the current one. More info on that to come!
    Quote Originally Posted by Salt n Peppa View Post
    Yup, JHM LA FTW! If we decide to go the adapter route, you can use our current test pipe. However, our DP-Y will definitely be the same .
    Jake
  16. #296
    Veteran Member Four Rings ericpaulyoung's Avatar
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    YEAH JAKE! what were you thinking clogging up Operators thread, I'm so furious I can't even think straight, the only thing that could ever bring me down below hulk levels would be to know what turbo(s) you are thinking of....
    Fixed. All the rage today is multi-tubo systems. Vendors making single turbo kits are so last week :)
    epy
    Epy
  17. #297
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    Quote Originally Posted by ericpaulyoung View Post
    epy
    I get enough headaches with just one turbo, the last thing I need is to add another level of PITA to my car.
  18. #298
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    ^^ this. lol
  19. #299
    Aug 31 2011
    Lathrop
    Lol! Maybe we will offer twin superchargers instead, and be ahead of the curve!
  20. #300
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I like your thinking! But given that turbos are more efficient up top, and chargers down low, I propose the system have both a charger and a turbo rather than two chargers.
    epy
    Epy
  21. #301
    Aug 31 2011
    Lathrop
    epy
    All you need to do is get two different size Centrifugal blowers, and have the smaller one's pulley on a centrifugal clutch so that it will disengage at a certain RPM so the power of the larger blower won't overspin the smaller unit .
  22. #302
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I like it, but I don't think it will make a blower more efficient than a turbo at the top end. So I say we combine the ideas, still use the clutch on a small blower, and have a big turbo up top. :) That is basically what VW did on the 1.4L variant, but with an electronic clutch.
    epy
    Epy
  23. #303
    Apr 04 2012
    Schwinn
    Minneapolis, MN
    You sure don't know much about forced induction, do you? Lol
    -Ed
  24. #304
    Aug 31 2011
    Lathrop
    epy
    Sounds like a plan! But what shall it be called? It needs a 1337 name.
    Haha we are just being crazy.
  25. #305
    Feb 24 2011
    '08 a4 b7 6MT
    Eugene / OR
    I would call it the "JHM Twin Induction System for FSI engines"
    Epy
  26. #306
    Aug 31 2011
    Lathrop
    Hmm.. That does sound fascinating. However, if we are combining ideas it will need to be the JHM/EPY Twin Induction System for FSI Engines!
  27. #307
    Apr 04 2012
    Schwinn
    Minneapolis, MN
    The JHM Twin Induction System for EPY engines
    -Ed
  28. #308
    Senior Member Two Rings Hopperstien's Avatar
    Jul 29 2011
    2007 Corvette
    Palm Beach, FL
    ^^ I like it. How's that 2.0t Tune coming along? Public release date?
    '14 Q5 3.0
    pw211:I would owon it ND THEN beat the **** aout of it witeh a god damn penguin
  29. #309
    Aug 31 2011
    Lathrop
    Quote Originally Posted by Hopperstien View Post
    It is coming along well! We are getting closer to getting a release date =]
    You have a PM.
  30. #310
    Aug 31 2011
    Lathrop
    Derp!
    It appears to be what was left over from a broken gardening tool.
  31. #311
    Senior Member Two Rings TsmithA4's Avatar
    Nov 13 2012
    Santa Monica, Ca.
    How will the the 2.0T tune work with a cvt trans.... As well as other JHM upgrades?
    2007 A4 2.0T | VAG COM | 034 SD Mounts
  32. #312
    Aug 31 2011
    Lathrop
    Quote Originally Posted by TsmithA4 View Post
    We have a local customer with our CVT tune, JHM Test Pipe, and JHM DP-Y with a modified stock B6 S4 catback (fwd cars have a different gas tank than quattros) and that thing is quick! It was nearly as quick as my car. I was VERY impressed with it.
    Jake
  33. #313
    Nov 13 2012
    Santa Monica, Ca.
    Jake
    Tranny tune or ECU tune?
  34. #314
    Aug 31 2011
    Lathrop
    Only the ECU was tuned. The CVT seemed to shift relatively quickly on its own.
  35. #315
    Nov 13 2012
    Santa Monica, Ca.
    Yea... I'm hesitant on my tune upgrades as I keep reading that the cvt can't handle the additional power that well. also found a guy on here who swapped in a S4 trans.
  36. #316
    Aug 31 2011
    Lathrop
    The B6 A4 had a pretty unreliable CVT. However, in the B7 we have seen them last much longer. There are even users on this forum that has gone over 200k miles with their CVT.
    Jake
  37. #317
    Nov 13 2012
    Santa Monica, Ca.
    Jake
    Good to hear!! I'm just at 70k mi so I'm hoping mine will go the distance.. Especially once I start with mods
  38. #318
    Aug 31 2011
    Lathrop
    Well, there is only one way to find out!
    Jake
  39. #319
    Nov 13 2012
    Santa Monica, Ca.
    Jake
    Very true!
  40. #320
    Sep 12 2009
    Manteca/Lathrop
    Jake
    LOL!
    Or for whatever reason on the shelf in the bathroom at work for the past year....
