Page 2 of 2 FirstFirst 12
Results 41 to 45 of 45
  1. #41
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by A-Rob View Post
    Ok so i was prepping to do a cam chain tensioner replace in the morning and noticed my vacuum pump venting a little condensate. Not enough to make a drip but enough to soak the connectors and get a little buildup on the top. Can i just weld the seam on the back of that bastard? Havent seen any post on someone doing that, but 200 bucks is 200 buck. I can weld it for free lol id post a pic but cant figure out how hehe
    I would not .. there is a rubber seal in there. against the back section . plus the impeller I believe I some type of nylon or plastic. Also it depends on that back surface to be absolutely flat and welding could warp it.
    Aluminum welding is a pretty special skill . If you are skilled at aluminum welding you can go for it as I don't like telling anyone they cant do something. I just don't think it is advisable in this case.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  2. #42
    Established Member Two Rings Ejr's Avatar
    Mar 24 2021
    Duluth, GA
    I fixed mine no problem. Been about 8 months now and no leaks.
    I used yamabond4 which I had lying around and put on a new oring on the front and on the vacuum port. found at an orings place
    Word of caution though. Any extra sealer on the inside will be shaved off by the pump impeller and end up in your oil. That's is not good. When I did mine I could see chunks on the impeller so i picked them out and flushed through the vacuum port before re-installing.
    total cost.to.fix was about 12.00
    I did the vacuum pump gasket, I still have a sort of loose vacuum port and it leaks oil of course. Is replacing the vacuum port oring alone enough or what else would I need?
  3. #43
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Quote Originally Posted by Ejr View Post
    If you replaced the gaskets and missed the o-ring in the port then replacing that should do it.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
  4. #44
    Sep 16 2010
    Central Wash
    I just did the vacuum pump 'rebuild' On my recently to me new Avant - it wasn't leaking but I was doing the coolant flange so I got the stuff just in case.
    How much oil is typically in the vacuum pump when you remove it?
    Mine had about 3oz in there.
  5. #45
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by rollerton View Post
    sounds about right .. its just what is splashed in there from the head .. the issue really isnt the leak , the issue is what the oil does to the coolant flange and seal right below it .
    1976 Yamaha XS 360
