Ok, have a 2003 A4 3.0 that I purchased used with 147,000 miles. In the last cupple of months I sent it into Limp mode twice while reving the motor to the yellow. Shut car off both times and it reset itself out of limp mode. Last week my daughter was driving the car at 30 mph and it again went into limp mode. Would not reset and I had the car towed to the audi dealer in Reno. They called me and told me the car showed multiple misfire codes and that they checked the coils and injection ports finding nothing wrong. Did a leak down test on the motor and found #5 cylinder had 55lbs compression and determined that there was an issue with the exhaust valve on the number 5 cylinder. Quoted me $6000 to fix the problem. I picked the car up and trailered it to my local audi mechanic. While loading and unloading the car I noticed it sounded fine. Yesterday my local mechanic called me and told me the motor sounded fine so he did a compression test and all cylinders had over 150-160 lbs. I had him take the car home then back to work with no issues. Any ideas. I already purchased a low mileage used 3.0 that I was going to have my local mechanic put in but am thinking that would just be a waste of money at this point. There must be some explination as to why the motor shut down and the audi shop gave me a bunch of BS when I told them the car was running fine. Any advise would be greatly appreciated. Thanks
